CandlePowerForums
CPF Only
User Name
Password
Register
illuminationgear.com
Reply
Thread Tools Display Modes
  #1
Old 05-04-2007, 03:20 AM
metroplex metroplex is offline
Unenlightened
Default Least expensive method of reliably measuring moonlight?
Are there any light meters that can read very low light (moonlight) and don't cost a lot of money? This isn't for photography and ideally I want something that I can press a button and tell me the amount of ambient lighting under very low light conditions. Thanks in advance.
  #2
Old 05-05-2007, 07:57 AM
SilverFox's Avatar
SilverFox SilverFox is offline
Silver Moderator
Default Re: Least expensive method of reliably measuring moonlight?
Hello Metroplex,
Welcome to CPF.
In the wilderness, the amount of light from an overcast night sky is reported to be in the 0.0001 lux range. Most light meters will not measure down that low. However, a full moon gives around 0.1 lux, and most light meters will measure that without problems. I have an Extech EA30 that reads 0.01 lux, but it is not sensitive enough for very low light measurements.
Tom
__________________
Behind every Great man there's always a woman rolling her eyes...
Most batteries don't die - they are tortured to near death, then murdered...
  #3
Old 05-05-2007, 08:21 AM
Unenlightened
Hi SilverFox,
That makes a lot of sense. I did some calculations using an EV of -6 and the amount of foot-candles/lux is truly small compared to the 0.01 Lux resolution of most meters.
Is there anything I could do (at a reasonable cost) to take ambient measurements in low light conditions?
  #4
Old 05-05-2007, 09:13 AM
greenlight's Avatar
greenlight greenlight is offline
are you looking for actual readings or just a comparitive test?
  #5
Old 05-06-2007, 12:43 PM
SilverFox's Avatar
Silver Moderator
Hello Metroplex,
Low light measurement can be difficult. You may be able to use the Sky Quality Meter to get a measurement, then, I believe, they have a conversion factor that may make the reading more useful.
Tom
__________________
  #6
Old 05-07-2007, 04:17 PM
2xTrinity's Avatar
2xTrinity 2xTrinity is offline
You might consider using a big focusing lens (such as a Fresnel lens) or a parabolic reflector of known magnification to amplify the moonlight to a level readable by a common light meter. You could even calibrate it by taking a light source that is readable, such as an LED, and measuring the lux without the amplification, then, measure how much it increases by adding the lens/reflector, and use that perecentage change as a conversion factor.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
