CandlePowerForums
CPF Only
User Name
Password
Register
4Sevens
Reply
Thread Tools Display Modes
  #1
Old 05-14-2007, 04:29 PM
RustyKnee's Avatar
RustyKnee RustyKnee is offline
Default Is A UCL 22mm lens tough enough for a mountain bike light?
as the title says. if a stray piece of gravel hits the lens is it going to smash really easy?
I am hoping to do a DIY light housing and want maximum brightness.
Stu
__________________
Mag13100/Mag623, Mag85, Surefire 6P. Fenix P1D CE, P3D CE, L2D, 4xE01, Ledean Mag Aspheric, Lumapower MRV, Elektrolumens QSP (waiting ), Lummi Wee, Zebralight H50-Q5, Novatac 120P. Wolfeyes Boxer 24. POB Hid
  #2
Old 05-14-2007, 04:47 PM
Patriot's Avatar
Patriot Patriot is offline
Default Re: Is A UCL 22mm lens tough enough for a mountain bike light?
RK, I recently accidentally dropped one of my favorite mags face down on some river rock and the UCL lense scracthed but didn't break. It was a 1.90mm thickness. I'll bet the 22.0mm diameter is very tough because of its thickness to diameter ratio. As long as you make you make your housing so that it's easy to replace the lense, I think that's all that's needed. Sounds like a cool project though!
__________________
-Patriot- Life Outreach Veteran Outdoors
  #3
Old 05-14-2007, 06:58 PM
modamag's Avatar
modamag modamag is offline
IMHO, no, they're not even suitable for around the garage (concrete).
You can reduce the change of it breaking by having orings on both side to help "absorb" the shock during crash.
  #4
Old 05-14-2007, 08:20 PM
CLHC's Avatar
CLHC CLHC is offline
*Flashaholic*
Well, I'd have to agree with what modamag stated above regarding the shock absorbing capabilities of duel O-rings. Though in my case, the UCLs cracked when it fell onto the floor/ground from waist high. Maybe it was with those "batch" that I bought.
Maybe Borofloat could be utilized instead?
__________________
LUX'Ottica
  #5
Old 05-21-2007, 04:38 PM
RustyKnee's Avatar
is borofloat tougher...ignoreing thermal shock issues?
Stu
__________________
  #6
Old 05-21-2007, 10:47 PM
CLHC's Avatar
*Flashaholic*
Hmmm. . .Well, here's an excerpt from SCHOTT North America Inc.:
Quote:
What factors have an influence on its impact resistance?
The impact resistance of BOROFLOAT® 33 is dependent, in addition to many other parameters, on the following factors:
* The way the glass is fitted
* Size and thickness of the glass
* The way it has been processed or worked (e.g. edge working, holes)
* The wear and tear the glass has suffered in use
* The type of impact
It is not possible to make any definite statement on impact resistance without knowledge of the specific use and fitting.
__________________
LUX'Ottica
  #7
Old 05-22-2007, 02:04 AM
RustyKnee's Avatar
Quote:
I guess that goes for any glass though.
Are there any polymer lenses available that have lowish losses?
Stu
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
