CandlePowerForums
CPF Only
User Name
Password
Register
4Sevens
Reply
Thread Tools Display Modes
  #1
Old 06-09-2007, 12:29 PM
metroplex metroplex is offline
Unenlightened
Default Light reduction from using a filter
How much light output is reduced from using a filter such as this:
http://www.showlenses.com/cart.php?t...ategory_id=250
The application is the foglamp on 05-up Mustang GTs and I was thinking about using the yellow lens covers to distinguish them from the headlamps. I heard that these filters can reduce light output by 20-30%.
  #2
Old 06-09-2007, 12:43 PM
2xTrinity's Avatar
2xTrinity 2xTrinity is offline
Default Re: Light reduction from using a filter
That's probably fairly safe to assume. Naturally some light will be lost. In the case of the foglights though, many intentionally use yellow filters like this as the blue component of the light is what is most prone to getting scattered, and obscuring your view in the fog. So for actually using your fog lights in fog the filtered light should work just as well, maybe even slightly better. When it's not foggy, your regular headlights should still be sufficient.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
