Re: Why the wide pitch on RGB LED displays?
Thanks.
I wondered if it might be some sort of "thermal" type issue, but wasn't even sure if LEDs generated enough heat for thqat to be a problem.
Still, with both this and the color spill issue, why don't the tri-color RyG's have this problem, and can be touching each other?
I do see where the RyG's often have different brightnesses in spots (often making the yellows either reddish or greenish in places). But these are small text signs, and it doesn't matter that much. But I don't see such small signs with RGB at all. It appears that they cannot be made with the finer pitch at all, restricting them to the large signs only; rather than the large pitch being used because of the largeness of the signs.
So the thermal issue seems to be the best explanation. Might a greater thermal condition on RGBs be because of the three dies as opposed to two or one; or does it have more to do with the GaN? (I just saw some apparent two-die RmB only LED displays, and they still had the wide pitch).
