CandlePowerForums
CPF Only
User Name
Password
Register
PEAK LED Solutions
Reply
Thread Tools Display Modes
  #1
Old 07-05-2007, 08:05 AM
Frobe22 Frobe22 is offline
Default Calculating light output from RGB leds
I am a bit stuck trying to calculate light output from a RGB led compared to regular white leds. Adding the intensity values is probably not the correct way to do it?
My purpose is to try to replace some rgb leds with white, and I want to have the same brightness.
__________________
Frode P. B.
The Norwegian winter require good flashlights...
  #2
Old 07-06-2007, 10:48 AM
PhantomPhoton's Avatar
PhantomPhoton PhantomPhoton is offline
Default Re: Calculating light output from RGB leds
Good question.
I'm no expert, only guessing here...
But I think adding the individual color values will give accurate numbers. It may not appear much brighter than a single color but thats how our eyes handle light. What's the apparent difference in brightness between 1 flashlight and 3 equal flashlights? The second and third to make it seem a bit brighter if you went into a dark room and compared 1 on vs 3 on but don't make it appear 3 times brighter than the first.
Anyone more knowledgeable out there care to chime in? I'm interested too.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
