CandlePowerForums
CPF Only
User Name
Password
Register
PEAK LED Solutions
Reply
Thread Tools Display Modes
  #1
Old 08-23-2007, 11:40 AM
Flying Turtle's Avatar
Flying Turtle Flying Turtle is offline
Default LED Replacement Bulbs for Nightlights
I was just in WalMart today and noticed these in the electrical aisle by the nightlights. They are about the size of a normal nightlight bulb, but have one LED. It was tempting, but I held off for now. I was surprised a bit by the wattage draw (1.7). They appear to not be nearly as efficient as the LED nightlights (0.3 watts) on the rack by them. You get two for $2.58. Anyone tried these yet?
Geoff
  #2
Old 08-23-2007, 12:05 PM
James Jackson James Jackson is offline
Default Re: LED Replacement Bulbs for Nightlights
When it comes to nightlights, I have about three various LED styles that I've tried.
The first one was a single blue LED behind a clear plexi-glass figure like a ship, or a seashell. It illuminates the plexi-glass and puts out a pretty decent light. Not sure of the wattage, but it's low. I usually leave it plugged in 24/7.
The second one I tried - and was disappointed with - was a single white LED - illuminating a plex-glass seashell, same as the blue LED. However... the brightness isn't the same, or else the blue light works better in the dark... not sure which. Not sure of its power rating either, but it's very low.
The third one - I just got recently - is in a miniature lightbulb screw socket, and is meant to be screwed in to those nightlights that used to be very common with their 4 watt (or 7 watt - if you could find them) incandescent bulbs. Only - this version uses 3 white T-1 LEDs and about 3 rectifiers, and... well, I cannot make it out through the glass.
It appears to have a glass 'bulb' over the entire set of LEDs. I 'clocked' this one on my Kill-A-Watt meter. It took 2 weeks (14 days) almost to the minute - to kick over at 0.01 kWH.
It puts out a decent amount of light - in a darkened bathroom, where I have it.
I figure that it will only cost me about 4-cents per year (or less) leaving it plugged in 24/7.
I don't know if this helped. I know I didn't discuss the particular LED nightlight that you saw. What I will say is... buy it. Try it. You may like it.
Regards,
James Jackson
Oztronics
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
