CandlePowerForums
CPF Only
User Name
Password
Register
Advertising on CPF!
Reply
Thread Tools Display Modes
  #1
Old 09-04-2007, 07:30 PM
Bake Bake is offline
Default Need Help finding a Battery Solution.
Okay, I have already posted this question over on Flashlight Forums so I apologize if this is a repost to some of you. A couple of members there have been helpful with ideas but unfortunately the Bicylcle headlights they recommended I look into will not fit my needs. One of the members there mentioned I may get more response here so I am hoping someone here may be able to offer a little more input.
I want to put together a lighting solution for my wheelchair. I live in a rural environment and am often rolling around in dark areas. I would like to add some light to illuminate the ground in front of me. I don't need to light up the world, I just need to be able to see obstacles in my path. My original thoughts were to use a weatherproof LED strip like these http://www.oznium.com/led-flex-strips on the foot rest powered by a lithium cell, or cells, with a small push button or rocker switch. The light strips that I have found so far are manufactured for 12v use. I really have no Idea what I would need to power the LEDs or if this is even possible. I know that I may have to fabricate a battery box or convert some other device to hold the batteries. I don't think that will be a major issue once I know what I am looking for. One of the foremost concerns is weight. When adding accessories to a chair, believe it or not, ounces can matter. Another is battery life. I want fairly long run times. So, can anyone tell me what I may need to power this system or if I need to look in another direction for a lighting solution. Is it possible that running a lower voltage to these 12volt strips would work. If so, what voltage might I want to try as a starting point? As I said I don't need a lot of light and a dimmer light may even be advantageous so as not to screw with night vision. Thanks much for any thoughts.
-Bake
  #2
Old 09-05-2007, 08:37 PM
Default Re: Need Help finding a Battery Solution.
Did I post this in the correct section??
If not, could a mod please move this to a section where someone may be able to give me some advise?
Thanks.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
