CandlePowerForums
CPF Only
User Name
Password
Register
FoxFury Fire Helmet & Hard Hat Lights!
Reply
Thread Tools Display Modes
  #1
Old 03-09-2003, 11:27 PM
StarPhox StarPhox is offline
Default LED Grow lights?
So I was sitting around the other day considering the fact that LEDs come in so many different varieties and I began to wonder.....Can you make a lamp out of LEDs that would support plant life? There are UV LEDs and a variety of different colors....
Has anyone ever tried this? It seems like the initial cost of putting something together could be prohibitive but the potential savings for greenhouses/nurseries could be astronomical when you consider the decreased power consumption.
Any ideas anyone? Or any previous threads that have discussed this?
  #2
Old 03-10-2003, 04:09 AM
B@rt's Avatar
B@rt B@rt is offline
Glowing admin
Default Re: LED Grow lights?
The efficency of LED lights isn't high enough to make LED-growing lights ,[img]/ubbthreads/images/graemlins/icon23.gif[/img] but the idea is nice... [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
  #3
Old 03-10-2003, 10:23 AM
**DONOTDELETE** **DONOTDELETE** is offline
Unenlightened
efficiency? why not LEDs? maybe if you got enough LS's together..? but the cost of the lights would be high. fluorescents are more efficient, and cheaper..and may last longer.. now how about using cold cathode fluorescents?...
  #4
Old 03-10-2003, 11:34 AM
Brock's Avatar
Brock Brock is offline
Administratior
I think I read LS's were about 20 l/w ccft were 30 l/w ac regular 4 foot tubes were about 40 l/w.
  #5
Old 03-10-2003, 12:03 PM
James S's Avatar
James S James S is offline
*Flashaholic*
What about something smaller than a big tube? I plan on growing a few individual flowers, probably some interesting orchids or something, in my next office, but they will be far from the only window in the place and I really don't need a bank of nasty grow tubes in there. I was thinking about some of the incandescent grow lights, LED's might be much more efficient than those at smaller wattages.
I am excited by doing some spot lighting on them and trying a couple of UV LS's and perhaps a 5 watt or 2 for regular lighting. It will probably be 6 months before I'm moved in enough to even start thinking about that, so the LED technology will be different then [img]/ubbthreads/images/graemlins/wink.gif[/img]
It's hard to find anything as efficient as long tube fluorescents. But if you want different form factors then LED's have a fair shot.
Is UV really necessary or is it just non-green wavelengths that the plant absorbes and uses?
  #6
Old 03-11-2003, 12:32 AM
This is partially what I'm getting at. Traditional fluorescent grow lights are bulky and unattractive and incandescents generate a lot of heat. It seems like LEDs (aside from initial cost) would be optimal because they generate much less heat than incandescents and are less bulky and awkward than tradition fluorescent gro-lights. I'd be very much interested to hear how your orchid indoor plant plan turns out.
  #7
Old 03-11-2003, 10:43 AM
Wylie Wylie is offline
This is something I have looked into for a few different purposes. Grow lights, jewelry cases, special effects lighting and aquariums are just a few. I have contacted a couple different manufactures and beside lumen power one of the biggest problems I have found that needs to be overcome is the expense of full spectrum LEDs. I was quotes a few hundred dollars per LED and to have the output for the intended purposes would be very expensive. I guess it is possible but very expensive and the heat characteristics would be a great advantage but wouldn’t make up for the differences in cost as far as I can tell. Such is life and I am on to other ideas. [img]/ubbthreads/images/graemlins/icon3.gif[/img]
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
