CandlePowerForums
CPF Only
User Name
Password
Register
OLight at Battery Junction
Reply
Thread Tools Display Modes
  #1
Old 03-12-2003, 07:11 AM
StoneDog's Avatar
StoneDog StoneDog is offline
Default Luxeon / LED replacement for US-spec brake light?
Hi all, I tried searching but couldn't find much about using Luxeon or 5mm Nichia arrays to replace US-spec brake light lamps. I've got a 96 Volvo 850 who's third brake light is a pain in the arse to replace. I'd love to come up with a Luxeon or Nichia-based replacement (with or without the stock clear red diffuser).
Has anyone done anything similar to this and/or is there somewhere I can got to read up?
Thanks,
Jon
  #2
Old 03-12-2003, 08:55 PM
highlandsun highlandsun is offline
Default Re: Luxeon / LED replacement for US-spec brake lig
Read the "Luxeon Turn Signals" thread in this forum. Check out the app note on the LumiLEDs web site. It'll tell you everything you need to know to create a brake light that meets legal specs.
  #3
Old 03-13-2003, 07:53 PM
CanadianGuy CanadianGuy is offline
Hey, There's a company called Truck-Lite (www.truck-lite.com) that makes a new lens piece (mostly for semi's and trailer applications though) that uses a single LED (probably a luxeon). See it at
Truck-Lite New Product
It looks like a regular incandescent trailer light, so it should be less theft prone. Maybe you could mount one of these underneath your stock lens? [img]/ubbthreads/images/graemlins/thumbsup.gif[/img]
  #4
Old 03-14-2003, 06:01 AM
StoneDog's Avatar
Thanks guys. I read the Lumileds doc and my head is swimming. [img]/ubbthreads/images/graemlins/grin.gif[/img] The Truck-Lite product might work.
Thanks again for your help.
Jon
  #5
Old 03-14-2003, 04:33 PM
NightShift NightShift is offline
I have one of the amber truck lite (60-)LED arrays. I was going to fit it for one of my front turn signals, but never got around to it.
  #6
Old 03-15-2003, 12:17 AM
For a CHMSL you can get a pre-fab array of six LEDs from LumiLeds, ready to plug in to a 12V power supply. The data sheet is http://www.lumileds.com/pdfs/protected/DS29.PDF (you have to register, no big deal)
Obviously it would be easy enough to mount six red-orange SnapLEDs yourself if you were so inclined. Come to think of it, I mght just pop out my incandescent CHMSL for one of these. The arrays come in three brightness levels, with the dimmest (19-30lm) presumably for an exposed/through-the-glass mount, and the brightest (36-58lm) for a behind-the-glass mount. A single 1W LS will easily provide this amount of light, but I think it might be better using 6 smaller LEDs to get an even distribution of light across the rectangular mount. Hm, I've got an extra red low-dome sitting here. Might have to try it and see how it looks.
Oh, I suppose it's also better to use a bunch of small LEDs in series instead of a single LS. Dropping 13.8V down to 2.2V @350mA requires a resistor/regulator, and it's gonna get real hot.
  #7
Old 03-19-2003, 07:48 PM
Unicorn's Avatar
Unicorn Unicorn is offline
I don't suppose that the original bulb is an 1157? If it is, there are LED lamps that are direct replacements. JC Whitney has them.
  #8
Old 03-20-2003, 10:37 PM
If you still believe that after reading this forum, I've got some prime Florida swam^H^H^H^Hreal estate to sell you.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
