01-17-2008, 07:57 AM
* P60 Flashlight List {host}
{Brand Model}
__________________________________________________ __________________
Aurora SH290, X-06-1/2/3
Blackhawk Falcata
Brinkman Legend, Maxfire (LX models on both)
Brinyte TA-01, TA-02A/B
Cabela's XPG (Xenon models)
Dereelight CL1H (all Versions), Javelin
DealExtreme {DX} HF-19, SKU: 1284, 4226, 14226, 14329, 14597, 14902, 15159 (DIY), 15565, 15561, 24354
Elzetta ZFL-M60 {designed for Malkoff M series drop-ins}
FireKylin Bailiff & Tactical (T95) Series
Fireworm F1 { Titanium}
FiveMega AA & all 18mm bodies
G&P M3, T6, T9, T12, R12
G&R SST-50
Hellfighter X-4, X-8
Huntlight FT-01PJ, FT-01X SE (Luxeon versions on both)
Kaidomain KD Tough, T3 from TLS
Leupold MX series w/ MX-100 bezel
LumaForce LF1
LumensFactory Seraph SP-6, SP-6Ti & SP-9
Malkoff MD2 & 4, Twisty {designed for Malkoff M series drop-ins}
M812
Mega CREE Q2
MTE M6-2
MX Power Cree 2xCR123A , ML-600, ML-660
Nextorch see site
Pila GL2/3/4
Romisen RC-E4, RC-M4, RX-A
SKYRAY S-R5
Smartfire A-1, T1, see Ultrafire models
Solarforce L2 (several Special Edition L2), L2i, L2m, L2r, SF6, SF9, SF12
Spiderfire Q5, R2, X-O3
Superfire C1, see Ultrafire models
Surefire {SF}
3P, 3R
6, 6P, 6PD, 6PL, 6R, 6Z
7Z
9P, 9Z
C2, C3
D2, D3
G2, G2L, G2Z, G3, G3L, GZ2
M2
Z2, Z2-S, Z3
>> Surefire Weaponlight models
> 617FA, 617FGA, 617FLG, 617LF
> 618FA, 618FGA, 618LF, 618LFG & 620LT
> 621FA, 621FGA, 621LF
> 623FA, 623FGA, 623LF, 623LFG
> 628, 628F, 628L, 628LF
> 636FA, 636FGA, 636LF, 636LFG & 660
> M951XM07, M952XM07
Tank007 Pt10
Trustfire T1-Q5, TR-B1/2/3, TR-C1 & 2, TR-C6, TR-Q5, TR-Q8
TR-C2
Ultrafire 6P, 9P, 12P, C1, C309, Alpha-C1, L2, SG.DX-B, WF-501A/B/C/D, WF-502B/C/D,
...WF-503B/C + extension option, 504B
UniqueFire L2, M2, R5
Vital Gear F2
Wolf-Eyes See Notes:
XLight HA-III Cree Q3 kit, HA-III Cree Q5, HA-III 14500
XTAR P4
Other Custom & mod designs.
The Boker BO006, Pelican M6, Pentagon Light X1 & Tactical Operations Products Stryker
all need modifications to work as P60 host.
~ Add any lights I missed, or compatibility issue.
Thanks for the input...
__________________________________________________ ____________________________________________
Notes:
*: The P60 is a light engine/reflector size, initially developed by Surefire.
This 'drop-in' size is now industry standard for many LED engine & host chassis manufacturers.
I: Depending on your host light, you may need a retaining/contact spring to complete P60 install.
Springs may need to be 'trimmed to fit.
II: Wolf-Eyes lights are designed specifically for Wolf-Eyes drop-ins.
Their drop-ins will work in other P60 hosts, with the addition of a contact spring.
III: P60 ~ D26 can be interchanged, double check your light.
IV: Remember your Voltages...
^ Dereelight CL1H V1 & AW 18650 ^
Reason: additions
01-17-2008, 09:30 PM
Re: * P60 Flashlight List
The HuntLight FT01X SE (HAIII) and PJ (type II) with LuxIII U-bin modules are P60 compatible, but the CREE X-RE model is not. DereeLight has forward clickys while HuntLight has reverse clickys, but the multi-mode DereeLight modules work fine in the Huntlight hosts. Both have AR glass and retaining rings to keep the glass and o-ring from falling out when you change modules. I have a Q5 SmartFire T1 in the mail from DX, and it looks like a blend of CL1H and FT01X designs. The Ultrafire 502B is an inexpensive host that resembles the HuntLight FT01X, but it is type II and has plain glass. Most will want to knock out the plastic insert at the top of the battery tube by inserting a dowel from the tail end and rapping it sharply. The Alpha C-1 is made by Ultrafire and Trustfire. Both are type II with plain glass. In my opinion, the o-rings and threads are better on the Ultrafire while the clip is better on the Trustfire.
Reason: additional info
01-17-2008, 10:24 PM
The SF G2Z and M2.
__________________
强光手电是我最爱得
01-17-2008, 10:59 PM
This needs to become a "sticky" . Maybe with the word "host" included.
01-18-2008, 02:14 AM
Wolf Eyes lights will not work with "P60" drop-ins such as Malkoff, BOG, Dereelight, DX modules etc.
The Wolf Eyes drop in will however work in P60 hosts with the adition of a contact spring.
Here's a couple of cheap ones to add to the list:
Solarforce L2 (From ebay = Solarforce L2 ebay add )
G&P T6
01-18-2008, 06:29 AM
Re: * P60 Flashlight List {host}
Additions placed.
Thanks for input.
01-18-2008, 06:51 AM
Quote:
Originally Posted by orbital
Huntlight: FP01JP, FT01X SE
As bspofford notes you should add a note to clarify that the Cree X-RE version of the FT01XSE will not accept a P60 drop in, and only the Luxeon III version.
01-19-2008, 06:53 AM
I have two of the older Huntlights. I just ordered a Dereelight DI(Digital Infinite) WC Q5 drop in w/(OP). Just hope it works...
01-19-2008, 07:07 AM
I really hate all the non P60 info going on in posts like this.
I wish all the banter and discussion could be deleted (eventually) to come up with a clean list.
Perhaps some sort of form with lines that a poster could paste and then fill in so it didn't all look the same, as in people who don't know how to form paragraphs and such.
Some mod stick up a from with lines that can be copied and pasted and filled in to make actual info easier to see please.
My grocery list would be pretty damn confusing if it read..
MILK
EGGS
are those the brown eggs or the white eggs?
white eggs
large medium or small?
BREAD
small
but you know that there is more egg in the XL right
but they cost more
BUTTER
I think the brown taste better
RICE
fine, brown
ok, what size?
PEANUT BUTTER
A list should be a list.
Not a debate over what is on the list.
Crap, now I've added my own non P60 stuff....
01-19-2008, 07:24 AM
gratewhitehuntr,
Refer to post #1, ..that's the most current list.
This list will be updated.
01-19-2008, 08:44 AM
Sticky please! and thanks for the list!!
01-19-2008, 08:45 AM
Quote:
Actually, the pill is threaded into the neck of the body. If you unthread it, with some difficulty, you should have the same host. The real question is whether or not you would want to upgrade a 5-mode CREE P4 for something else at this time. The Lux III U-bin host last cost about half the CREE X-RE model, so it makes more sense to upgrade it with a Q5 P60 module. Regardless, the concept of upgrading any of these hosts for only $10 - $35 is wonderful!
01-19-2008, 01:58 PM
I have the Cabelas XPG 6V Camo. It is a metal body flashlight with a rubbery coating that the camo is on. I tried the P60 incandescant bulb from my SF G2 and it worked. Not sure what LED drop-ins work in it though.
__________________
Fenix P2D/L1D RB100 & E0 & LOD SE & P3D-R Ol, WE 9D Raider, XPG 6V w/DRL 3SM 5A Q3, SF G2 Yl & Z2, POB HID, Tiablo MA6, FM TL-3 2X18650, 4Sevens Quark 14500 NW, Quark RGBNW 18650, Quark 17670 Tac...
01-19-2008, 02:46 PM
thanks for the list! awesome info…
HAGO,
__________________
No.... Maybe a 2nd job.... But that's about it. - Monocrom
01-19-2008, 02:56 PM
The Wolf-Eyes Raider is P60 compatible too, not to mention various PILAs.
01-19-2008, 08:18 PM
Quote:
Every Dereelight module, including the multimode Q5 modules, work fine in my older Huntlight hosts. The CL1H has a forward clicky while the Huntlight FT01X has a reverse clicky, but the mode changing seems to work just fine. I've also ordered some digital infinite modules and assume that they too will work just fine with the reverse clicky. Don't forget that most Dereelight modules are 4.2V maximum, so you can't use 2X16340 or 2XCR123A.
01-20-2008, 04:32 AM
... and one more suggestion:
Not only should this be a sticky, but perhaps it might more appropriately be integrated with the current sticky "P60 sized LED drop-in's" since the subject matter is virtually identical.
It would make a great match up if the information in the first post of this thread could be added into the first post of the other (sticky) thread and then the first thread be re-titled: "P60 sized LED drop-in's and hosts".
Just tryin' to be useful and look busy because I couldn't find a broom...
01-20-2008, 08:04 AM
Quote:
HAGO,
Thanks!
List updated.
01-20-2008, 12:22 PM
Does anybody know if the Romisen RC-E4 is P60 compatible?
01-20-2008, 03:29 PM
Great List
01-20-2008, 04:10 PM
The Cabelas extreme lights series( 2,3+4 cell ) also take P60 drop-ins.At least the ones from DX I have.
DON
01-27-2008, 03:20 PM
Unenlightened
Hmm.... As much as I like Wolf-eyes, I'd remove them from this list. Their drop-ins will fit just fine in most lights intended for P60s (with the extra spring). However, you couldn't possibly fit, for example, one of Dereelight's drop-ins in a Sniper.
01-27-2008, 07:41 PM
Add Surefire 6Z.
01-27-2008, 08:44 PM
Updates in place.
Also, this List is now located within the Sticky thread ' p60 sized led drop-in's
Reason: add
01-29-2008, 10:36 AM
Quote:
Originally Posted by harddrive
For what it is worth I can back up the Solarforce L2.
The two I ordered arrived today. Put a 17670 in and tried a few dropins.
Surefire P60L = worked fine
Older 3.7 volt incandescent from AW = worked fine
Malkoff Devices Q2 version = worked fine
BOG-USA Cree Q5 = not the best voltage and needed the extra contact spring but worked fine
02-02-2008, 12:14 PM
Just thought I'd confirm a couple of lights from the list.
Today I received a Huntlight FT-01PJ (Luxeon version) and installed a 3SD w/ SMO reflector. Quality switch and solid build.
Note: the FT-01PJ will take most protected 18650, protected 17670 for sure.
Also an UltraFire WF-502D w/ a DX SSC P60 drop-in that will run from (2) 18650 protected cells.
I know its a slightly odd looking light, but should run for hours.
Reason: edit
02-02-2008, 01:07 PM
Today I received a Huntlight FP-01PJ (Luxeon version) and installed a 3SD w/ SMO reflector. Quality switch and solid build.
Note: the FP-01PJ will not take protected 18650, but protected 17670 fine.
Do you mean Huntlight FT01PJ? I have a number of them, and all my protected 18650 cells (AW, Ultrafire, Trustfire, Battery Junction) fit just fine.
02-02-2008, 02:01 PM
Quote:
I meant the FT,..typo.
My protected cells could fit, but I'd have to take the FT apart to get them out, they wouldn't slide out.
No big deal.
02-02-2008, 02:39 PM
No big deal.
Maybe you can tune up your cells. Roll them between to boards to align the internal components of the cell. Often they seem wider because the various cylinders are like an old Greek column that has segments that aren't aligned with one another.
02-02-2008, 02:49 PM
Thanks, I corrected my post #26....
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
