CandlePowerForums
CPF Only
User Name
Password
Register
Surefire at Battery Junction
Reply
Thread Tools Display Modes
  #1
Old 02-19-2008, 09:10 AM
fxstsb fxstsb is offline
Default Do we have a resident physisist?
Is it harmful to look at 350nm through a defraction grating spectroscope?
  #2
Old 02-20-2008, 12:22 AM
NA8's Avatar
NA8 NA8 is offline
Default Re: Do we have a resident physisist?
You should ask over in the LED or GENERAL LIGHT DISCUSSION forums. More traffic there.
  #3
Old 02-20-2008, 12:53 AM
65535's Avatar
65535 65535 is offline
It's very dependent on the intensity of the source.
__________________
Hobbyist LED information Website
U2 work light
Shaky Emergency Light
The Mags
engineer in the making
  #4
Old 02-20-2008, 08:25 AM
Quote:
Thank you but it was moved here by a moderator
  #5
Old 02-20-2008, 11:04 AM
IMSabbel IMSabbel is offline
Quote:
Depends on the intensity.
Generally, 350nm is already in the energy range that starts to become ionising. So you might expect typical "welder eye" problems.
If its just a single non-power LED, or the UV spectrum part of a (not to strong) halogen lamp, no problem.
If, otoh, its something like a 100W mercury vapour lamp, or an unshielded hid, please let it be.
Basically, there is no difference between using the grating monochromator and looking directly at the source. Of course, opposed to prismas, you have to be careful when using higher orders: You might get invisible light from lower defraction orders without noticing it.
  #6
Old 02-20-2008, 04:58 PM
The_LED_Museum's Avatar
The_LED_Museum The_LED_Museum is offline
*Flashaholic*
If you're just looking at the 350nm line and little or none of the other light gets through, you might be playing with fire because your iris will be opened much more than it would be with visible light; thus exposing your eye to more UVA radiation than it might otherwise receive.
__________________
  #7
Old 02-20-2008, 05:19 PM
What I wanted to do was select LEDs in that spectral range for custom lights. So maybe if I use the Difusion Spectroscope, maybe I need to observe the results thru a camera. What od you think?
  #8
Old 02-20-2008, 08:27 PM
65535's Avatar
If they are LED's just run them at low current and use your spectroscope.
__________________
U2 work light
The Mags
  #9
Old 02-22-2008, 06:33 AM
yaesumofo's Avatar
yaesumofo yaesumofo is offline
Default Re: Do we have a resident physicist?
Don't you think that a lower current may alter the spectral output?
If he want to cherry pick emitters to work at a specific wavelength It would make sense to me to test at the driver power unless it can be established that a lower current drive does not alter the wavelength.
Just my 2.3 cents worth.
Yaesumofo
Oh and BTW please use extreeme care when looking at bright emiters regardless of the wavelength. A cool flashlight is no good reson to have permenantly dammaged vision.
Quote:
Originally Posted by 65535 View Post
If they are Leds just run them at low current and use your spectroscope.
__________________
Support your local flashlight builder.
Buy American. Stop crying and start Buying.
Flashlights are tools. Period.
  #10
Old 02-23-2008, 06:52 AM
Yaesumofo
Yo! Mo,
That is why I made the post to find out what my limits may be before doing the deed. 73
  #11
Old 03-19-2008, 03:09 AM
liveforphysics liveforphysics is offline
I've looked at lots of UV light sources through scopes. Tip the emmiter off axis a bit to reduce intensity if you are worried about it. Spectrum will be nearly uniform reguardless of angularity. For your eyes, 350nm is not really much different than visible light. This is another of those things where extreme prolonged exposure or very high intensity can cause a problem, just like with any light source. The trick with UV is that you don't recognize you are getting high intensity exposure, which is why people often have problems when dealing with it.
-Luke
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
