CandlePowerForums
All "reviews" threads are to be posted within their applicable forums. If administrators or moderators wish to have them published in the Reviews forum, they will move them there. If the reviewer, when posting, wishes to request inclusion in the Reviews forum, they may attach a notice as the first line in their post such as "for submission in the Reviews forum". Alternatively, they can omit such a first line, and simply PM a moderator or administrator asking that it be considered.
Go Back   CandlePowerForums > Flashlights > Flashlight Reviews
CPF Only
User Name
Password
Register
LED Flashlight at GadgetTown.com
Reply
Thread Tools Display Modes
  #1
Old 03-26-2008, 09:48 AM
Handlobraesing Handlobraesing is offline
Banned
Default Brinkmann Corporation 3W CREE digital dimming flashlight
Summary, better dimming function than any Fenix(so far one of the very few competitors with variable output for <$100) more output than my Lowe's Task Force 2C CREE, but poor build quality
The Brinkmann 3W LED flashlight is the first dimming light I have seen in the mainstream market.
I found mine at a Target store for $25.
Model 809-3000-1
This is an LED flashlight powered by two D cell batteries with 4-level dimming control and a LCD indicator.
In my opinion, the performance is good and beam quality is good. The four dimming levels provides a relative wide range of output with each level providing clearly noticeable dimming.
Operation is very simple. Install two D batteries.
- Use the power button to turn on and off independently of dimming.
- + and - buttons provides dimming control, independent of power switch and the setting sticks after power cycling.
- Test button gives a battery level read-out while the flashlight is turned off. The battery status remains lit whenver the light is turned on.
CREE X-Lamp® 7090 gives this product a technological leap over the many now common Lumileds Luxeon® based products.
The one and only major downer in my opinion is the build quality. This light is supposed to be openable, because the two halves are glued together. Well the gluing sucked on mine. It was no harder to split apart than pulling the foil lid from a cup of yogurt. The plastic has that CHEAP steoreotypical "Made in China" and my gut feel is that if you drop it 3' onto cement, it will shatter and disintegrate.
This flashlight is powered by two D batteries and has a push button operated dimming control with LCD indicator showing current output setting and status of battery. The battery indicator is similar to the indicator on cell phones, with three status bars.
There are 4 buttons:
-on/off
- Test (used to test status of battery while the light is off)
Buttons have a definite feedback like the buttons on VCR. They do need to be pushed pretty hard and if you use your fingernail, the finish gets scarred. It's purely cosmetic, however.
LED:
CREE X-Lamp® 7090 Star. The star is riveted onto an aluminum heatsink with some thermal compound. There are vent slots cut on both sides of body by the heatsink to help keep the LED cool.
Driver:
Proprietary digitally regulated boost converter. Some competitor products, such as Fenix uses 100% duty cycle variable current drive which can shift the color of LED. This one uses PWM, pulse-width-modulation at ~850 Hz If you swing the light rapidly you can see the flicker, but under normal use it should not be a concern. I should have taken duty cycle measurements at the LED for each setting, but I forgot to do that. Oh well.
Current levels at input with fresh cells in ascending order of dim settings are:
0.1A
0.3A
0.5A
0.85A
Reflector:
Deep, textured plastic reflector with vapor deposited metal reflector.
  #2
Old 03-26-2008, 09:56 AM
Phaserburn's Avatar
Phaserburn Phaserburn is offline
*Flashaholic*
Default Re: Brinkmann Corporation 3W CREE digital dimming flashlight
Very cool pics and review. Nice to see this type of light hit the marketplace. Funny how everyone else seems to be the innovators with new product releases, but no one has equaled Mag's build quality as of yet in the consumer retail channel.
How do the buttons feel when pressed; do they click?
__________________
The Phaser: A nice EDC with great throw; heat and runtime can be issues.
  #3
Old 03-26-2008, 10:01 AM
jirik_cz jirik_cz is offline
Beam looks nice and smooth. But what about overheating? Plastic body is not very good for cooling high power LEDs. And if the build quaility is so low, it is probably better to buy something from DX than this.
__________________
Olight SR90 Intimidator beamshots.
Feni_Nitec_Oli_Raidf_Rega_Tia_Zebra_Deree_Wolf Solarf_Streaml_G&P_MTE_Romis_Ultraf
  #4
Old 03-26-2008, 10:09 AM
Banned
Quote:
The star is mounted on an aluminum heatsink with heat sink paste and there are vent slots cut on the body on both sides of the heat sink.
  #5
Old 03-26-2008, 10:18 AM
Banned
It is aimed at the mainstream consumer. After paying CREE their asking price for the LED and using a rather high-tech PWM regulator, I think they have to cut corners on construction to quality to be able to sell for $25 and still have a reasonable contributing margin.
  #6
Old 03-26-2008, 11:21 AM
What is so high tech on PWM? According to Newbie's results it can be twice less efective than constant current dimming.
__________________
  #7
Old 03-26-2008, 11:40 AM
rotototo rotototo is offline
Unenlightened
That LCD indicator...is it backlit?
  #8
Old 03-26-2008, 11:46 AM
Cydonia's Avatar
Cydonia Cydonia is offline
Quote:
That's a good question. If it's not, then how does one see the display in the dark? Or do you require a second flashlight to read the display?
Nice review Handlobraesing on an interesting light
  #9
Old 03-26-2008, 01:38 PM
DaveG DaveG is offline
Thanks,for the info.
  #10
Old 03-26-2008, 02:58 PM
Banned
I find the LCD rather useless and I think the better allocated on improving the body quality.
  #11
Old 03-27-2008, 12:25 PM
Banned
No, it's not.
He also says that there's less color shift in PWM dimming. What he's saying is that the LED itself becomes more efficient at lower current, however a PWM dimming circuit is usually more efficient.
I have not taken the effort to purchase a Fenix to reverse engineer the regulator topology and I'm not certain what it is, however the owner of Atlanta, GA based Fenix products dealer says that it is not a linear dropper regulator.
  #12
Old 03-27-2008, 01:25 PM
HKJ's Avatar
HKJ HKJ is offline
Quote:
I have not taken the effort to purchase a Fenix to reverse engineer the regulator topology, but if it's a linear dropper type regulation, it is basically an electronically controlled variable resistor that dumps the excess energy as heat.
A pwm circuit only have a high efficiency when output and input is working at the same voltage, if your need a resistor to drop output voltage, the efficiency will go down.
I your look at the specification for P2D and P3D, your will see that P3D has nearly twice the runtime of P2D and with a higher light output, that would not be possible with a pwm, but requires a buck regulator.
I am a bit curious about the flashlight your are testing, I can not see a inductor (coil) on the PCB in your photo. Does it have a inductor?
  #13
Old 03-27-2008, 01:33 PM
I didn't say anything about Fenix so I don't understand why you are still talking about it. Btw. your claims look quite speculative to me
__________________
  #14
Old 03-27-2008, 01:48 PM
Banned
Quote:
A PWM circuit can use inductance to limit current instead of resistor since inductance limits dv/dt.
The inductor is quite big and it's externally mounted with wires and dangling inside the case. I should have posted that pic.
  #15
Old 03-27-2008, 01:55 PM
HKJ's Avatar
HKJ HKJ is offline
If that is the case, then your statement:
"but if it's a linear dropper type regulation, it is basically an electronically controlled variable resistor that dumps the excess energy as heat."
does not apply.
Anyway, the P3D (2 batteries) puts out about twice the energy of the P2D (1 battery), that means that the regulators has about the same efficiency.
  #16
Old 03-27-2008, 01:58 PM
HKJ's Avatar
HKJ HKJ is offline
I forgot: Thanks for the picture.
Your get a lot of electronic and assembly work for the $25 that the light cost.
  #17
Old 03-27-2008, 02:13 PM
Banned
I wasn't even supposed to be able to take the light apart without destroying the case but I was able to, because the gluing between the two halves was not done adequately. As I said, I'd give up on that silly LCD in exchange for a better construction.
  #18
Banned
does not apply.
And I said that I do not know, because I've yet to reverse engineer it.
  #19
Old 03-27-2008, 02:25 PM
HKJ's Avatar
HKJ HKJ is offline
Based on the efficiency of P3D compared to P2D, I do not need to reverse engineer it to say that the circuit in P3D is not a just a resistor and a pwm control.
I am curious: Have your seen any quality lights that uses 6 volt input, that do not use an inductor to drop the voltage (I suppose they exists, but I have not seen any yet)?
  #20
Old 03-27-2008, 07:20 PM
PlayboyJoeShmoe's Avatar
PlayboyJoeShmoe PlayboyJoeShmoe is offline
*Flashaholic*
I saw that light at two different Targets and it looked interesting.
But I was after an X5 and finally found one at 10 bucks off.
__________________
http://img32.imageshack.us/img32/2640/usflaghalfmastmdwht.gif
PBJS
  #21
Old 03-28-2008, 05:09 PM
Phaserburn's Avatar
*Flashaholic*
Checked two Targets near me, and no luck.
Does this light have the same external build as the Maxfire lights from Brinkmann?
__________________
  #22
Old 03-28-2008, 06:01 PM
Banned
Oh no. I think the Maxfire is made of nylon. This thing is made of two halves of some cheap plastic (ABS with cheap casting maybe? ) glued together.
It is a very new product and I've only seen it at one Target. Mine was buit on the 9th week of 2008.
  #23
Old 03-28-2008, 10:49 PM
Canuke Canuke is offline
I saw two of these at my local SoCal Target. The only difference was that the emitter in them were the ones with the phosphor only on the die instead of everywhere inside as we see in the one pictured here.
Does that mean some of these shipped with Q5's?
  #24
Old 03-29-2008, 09:04 AM
Khaytsus Khaytsus is offline
No, it's not.
Until you do, how about giving up on the Fenix bash, period.
__________________
4Sevens Quark 123 R2, Fenix Tk10, NiteCore Defender Q5, Fenix P2D CE (P4) Natural, Fenix L0D Q4 (Copper??), Surefire E1e with McLux head and Luxeon 3, Black 4D Mag with TerraLux SSC Drop-in, Deep Purple Mag AA with TerraLux 1W UV Cree, Arc AAA
  #25
Old 03-29-2008, 02:21 PM
4sevens's Avatar
4sevens 4sevens is offline
Wrong answer.
Please do not spread dis-information through vague guesses.
Fenix drivers are NOT electronically controlled variable resistors.
They also do NOT dump excess energy as heat.
And what does "topology" have to do with regulators? Do you even know
what that word means? Or are you just dropping fancy words that have no
relevance? Linear dropper type regulation? What is that?
Perhaps you should do some studying so you don't appear like an armchair
electrical engineer. If you're going to poo-poo Fenix, at least do it with
facts and NOT insult people's intelligence here.
  #26
Old 03-29-2008, 02:46 PM
Banned
Quote:
Originally Posted by 4sevens View Post
Wrong answer.
Hence the conditional statement "if it is". I didn't say it is.
relevance?
No relevance? You got to be freaking kidding me. Circuit topology is the electrical layout of a circuit. You should know better than saying it's a word of no relevance.
http://focus.ti.com/lit/ml/sluw001a/sluw001a.pdf
A type of regulator that monitors the current/voltage at the load, then use it as a feedback to control the series resistance to maintain the current/voltage to the load at a desirable level. A series transistor/MOSFET based constant current regulation and LM317 based voltage regulation are some common examples of linear dropper topologies.
I think that goes for you. You haven't a clue what you're talking about other than the product specific information that the Fenix' regulator is not a variable resistor (linear regulator), but I didn't claim it is.
  #27
Old 03-29-2008, 03:04 PM
4sevens's Avatar
Exactly! I said you are spreading dis-information through vague guesses
(i.e. you suggested fenix drivers being variable resistors)
Whoopie doo. So you found some pdf that uses the world topology.
Topology is primarily a geographical term that Ti used. It's not common.
So can you google again and define what you mean by dropper type regulation?
hmm? My kids can google anything too.
Well I happen to have a degree at one of the top engineering schools.
And you?
By the way, I didn't say you claimed that. I said you SUGGESTED
something that is absolutely not true. Just fess up and admit your statement
was wrong.
You had nothing to go by anyway - so why would you suggest such except
to poo-poo Fenix. I make a factual statement to refute your guess and
Ask you nicely not to spread dis-information. The spread of dis-information
doesn't necessarily have to be truthful - it could be lies, or simple baseless
guesses designed to damage - such as what you have done.
btw - I don't think I'm going off topic since the very first post mentions
Fenix as a comparision. But if I am OP can correct me.
  #28
Old 03-29-2008, 03:05 PM
*Flashaholic*
I can't see what the last three posts have to do with the Brinkmann light in the title.
I almost bought one, but now that I know it's made of icky plastic I will pass for sure.
It sounds like a neat concept. Just seems like the execution leaves a lot to be desired!
Poor Fenix haters. Don't know what they are missing. But it does leave more for us....
__________________
PBJS
  #29
Old 03-29-2008, 03:14 PM
Banned
Exactly, I said you are spreading dis-information through vague guesses (i.e. you suggested fenix drivers being variable resistors)
I'm free to guess what I want and it is not spreading disinformation unless I claim it as fact.
Says you. It's quite a common term in power supply, ballast, etc designs.
Quote:
So can you google again and define what you mean by dropper type regulation? hmm? My kids can google anything too.
I didn't have to Google anything to tell you what a linear dropper regulator is. Bugger off.
And you?
So you can be a flashlight salesman? hahahahaa!
was wrong.
I don't feel that's necessary, because I wasn't wrong. Had I said "Fenix' so and so is this" I'd be in the wrong, but that's not what I said.
guesses
I'm free to guess what I want. You're not being nice by trashing my review thread. Do I go to your MarketPlace Dealer's thread and trash your stuff?
  #30
Old 03-29-2008, 03:20 PM
4sevens's Avatar
I'm not trashing your thread.
Just pointing out that what you're suggesting in this thread is grossly wrong...
It cannot be further from the truth. You brought up Fenix in the first post.
You said...
If it's [Fenix] a linear dropper type regulation, it is basically an electronically controlled variable resistor that dumps the excess energy as heat.
Keep in mind libel law does not require the accused to make a statement of
fact. Actually, any false malicious public statement published that
damages a person or entity's reputation is a case for a libel suit.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
