CandlePowerForums
CPF Only
User Name
Password
Register
Peak LES
Reply
Thread Tools Display Modes
  #1
Old 06-15-2008, 10:16 PM
QtrHorse's Avatar
QtrHorse QtrHorse is offline
Default Using a light meter
I have a Ideal Sperry 61-681 digital lightmeter. What is the proper way to measure the output of a light? The reading fluctuates so much every inch away from the sensor. The meter only measures in foot candles and lux. What is the correct calculation to convert that to lumens? Everything I Google states foot candles equal lumens 1:1 if measured in a square foot but I'm not sure what that means. Do I need to have the light 1 foot away from the sensor, make sure it is lighting up one square foot of area or is there another correct procedure to measure the light output?
I'm trying to check the lumens output of a Ebay P60 drop-in that I bought for my Surefire 6P as well as a few other lights that I have.
  #2
Old 06-15-2008, 10:37 PM
Probedude Probedude is offline
Default Re: Using a light meter
I'm interested too! I just received an Amprobe LM631A on Friday and am itching to try it out.
Dave
  #3
Old 06-15-2008, 11:24 PM
darkzero's Avatar
darkzero darkzero is offline
Lux is usually measured at 1 meter. I always take two measurements, peak lux @ 1 meter, & peak lux @ 1 meter after the light has been running for 2 mins. I read that somewhere here.
Measuring foot candles is closer, like 1 foot or something I forget.
You can not convert Lux into lumens, they are different type of measurements. Lux is the measurement of whatever the light sensor is reading, generally just the hotspot. Lumens is a measurement of the entire light output as in the hotspot & spill. You need an integrated sphere to measure lumens.
So you could have a P7 that puts out way more lumens than a single P4 but the P4 could give you a higher lux reading since it can focus into a tighter hotspot.
I never really use my light meter to compare the brightness of two different lights (unless they're the same type). I mainly use it for measure the difference in lux before & after upgrading a light.
There's a sticky about light meter reading. Maybe it will be helpful? http://www.candlepowerforums.com/vb/...ad.php?t=94232
__________________
-Will-
My Archive
  #4
Old 06-15-2008, 11:59 PM
QtrHorse's Avatar
Ok, so I measured 4122 foot candles at one foot. What does that convert to in lumens if there is a calculation? Would it be around 190?
  #5
Old 06-16-2008, 12:04 AM
darkzero's Avatar
Quote:
Read the post before yours.....
__________________
-Will-
My Archive
  #6
Old 06-16-2008, 07:01 AM
precisionworks's Avatar
precisionworks precisionworks is offline
You might want to build one ... not hard to do, under $50 in materials. See the thread in this section.
__________________
Barry Milton ... Surefire U2, A2, G2, E1L, E1B, L4, 6P, 9P ... NovaTac 120P ... Malkoff M60, M60LL, M60 MC-E ... Muyshondt Nautilus, Ion, Aeon ... McGizmo Sundrop-3S, Ti PD-S, Sapphire, C2 Pak+PR-T ...Cool Fall Spy 007 ... All Made in the USA
  #7
Old 06-16-2008, 07:40 AM
QtrHorse's Avatar
Quote:
I did but obviously not completely or I would have seen the part about the sphere. Thank you for the explanation. I'm going to look for a lumen light meter now.
I also recorded a Lux reading of 5100 for that same light at 1 meter.
  #8
Old 06-16-2008, 08:03 AM
BVH's Avatar
BVH BVH is offline
When you find a Lumen measuring light meter, let us know. There's probably 4,000 of us here on CPF that would like to buy one.
__________________
60" WWII Anti-Aircraft Searchlight (sold) Twin 150 Watt HID Vector, Barn Burner, Costco, 350 Watt HID "Locator's", LarryK14, L35, N30, Stanley HID
  #9
Old 06-16-2008, 07:19 PM
QtrHorse's Avatar
Quote:
I'm assuming that means there is no such thing or it's almost impossible to find?
How do all the light manufactures get the lumen output on their lights? There are a lot of garage type drop-in makers who list lumen output as well. Are they just guestimating a lumen output?
  #10
Old 06-16-2008, 07:40 PM
darkzero's Avatar
With an integrated sphere....
http://www.candlepowerforums.com/vb/...28&postcount=4
http://www.candlepowerforums.com/vb/...&postcount=947
Lots of makers just list when the lumen output of the emitter is rated at or like you said, guestimating.
__________________
-Will-
My Archive
  #11
Old 06-16-2008, 07:49 PM
QtrHorse's Avatar
Thank you;
I just went back and read a lot of the sellers listings. Most of them do state the following or a variation of it, "This LED is rated at 240 lumens at 1000ma". I honestly never really thought much of it until now that I actually want to know what the lumens is and find out it's not as easy as going out and buying a $150 lightmeter.
  #12
Old 06-16-2008, 09:37 PM
Thank you!
  #13
Old 06-17-2008, 01:37 PM
As well as quite a few eBay sellers that haven't a clue about luminous flux.
__________________
  #14
Old 06-17-2008, 07:32 PM
QtrHorse's Avatar
Quote:
Correct, just like the Ebay listing for the Solarforce 290 lumen drop-in that I bought. I know it is no where near that output but I just wanted to check to see where it was at.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
