CandlePowerForums
Go Back   CandlePowerForums > Beyond Flashlights > LED
CPF Only
User Name
Password
Register
Reply
Thread Tools Display Modes
  #1
Old 09-06-2008, 04:18 AM
jeraldjunkmail jeraldjunkmail is offline
Unenlightened
Au Newbie doing a DIY homebrew HDTV projector, need advice please!
First post here. I am designing and building a homebuilt HDTV projector on the http://www.lumenlab.com/forums/ ... An simple example schematic follows:
http://www.distantvisions.net/images...oj-diagram.png
I have done all the research I need to build one of these. The only thing I need to do is to come up with a light source. Since I am trying to make it as compact as possible, I am interested in using LED lighting due to the lower heat output and directional nature of the light they throw.
Typically, I would throw a 400W metal halide light in the box and use a few fans to cool it down. I have always been interested in LED lighting, and thought that this would be a great hobby project for me, LEDs and all.
The LEDs are my stumbling block though, as I am not too knowledgeable about them. I only really know that they are cooler burning, longer lasting, use less electricity, and are more space efficient. Sounds ideal. Except I have no idea where to start.
I think that I should just get this made for me, and tell people about how and who made it. I am interested in LED lighting, but the learning curve is kinda steep... I have played with a breadboard in the past, but this exceeds my technical abilities.
So my questions are as follows:
Can this array be made for me for less than $400.00US?
Who do you recommend making it for me?
What kind of LEDS should I use?
Here is the specs for the LCD panel I will be using:
344.5mm max(W) x 222.5mm max (H) x 6.5maxmm (D)
Aparently, from what I have read, an LCD panel will only pass light through it at a limited angle (6-9 degrees). However, the ultimate goal is to get the most possible lumens through the triplet lens as is possible and onto the wall in as even a manner possible. Also, the desired light would be about 6500K 90CRI.
You guys (and gals) seem to know a heck of a lot about this stuff, so I thought you might have some fun with this one. Any help is appreciated!
Cheers, Jerald!
  #2
Old 09-06-2008, 04:35 AM
cdosrun's Avatar
cdosrun cdosrun is offline
Default Re: Newbie doing a DIY homebrew HDTV projector, need advice please!
Hello Jerald,
Firstly , you sound like you have an extremely interesting project under way. However, I don't think you will achieve your aim of using LEDs for the projector. Modern LEDs can be a little more efficient than a metal halide lamp but they can't compete when it comes to output. An example (Philips) 400w lamp I just looked at turns out almost 30000 lumens on average. Some of the upcoming multi-die LEDs are putting around 800 each so you would need quite a large array of them to produce usable light. Such light would also be from a large area rather than the 'point-source' of the metal halide lamp (making it difficult to focus the light coming from the LEDs).
When it comes to sheer output LEDs can't match the discharge lamps and whilst they are smaller I don't think you would have saved any space by the time you have a large enough array of them and the heatsinking/cooling infrastructure to match.
Good luck with the projector though.
Andrew
  #3
Old 09-06-2008, 04:58 AM
Unenlightened
Thanks for your reply. Actually, I was interested in using this type of array not as a point light source, but as an almost direct contact light source. I wanted to make an LED array that was placed as close as possible to the LCD panel. My design differs from the standard single point light source design, and I was hoping to do away with the first fresnel lens as having the LEDs that close to the screen would be more efficient.
Partly I am considering this because:
I don't think it has been done on the Lumenlab forum in the last couple of years and LEDs have made a lot of progress. They would be interested in this if it was possible.
I am interested in LED arrays and have played with breadboards and making circuits in the past.
I think I can replace the 400W lamp with a much lower wattage lamp.
I can cool this array with less fans and :. less noise.
I am trying for sure to one up major projector manufacturers.
I am convinced that if designed and executed correctly, it can be done.
I am a curious person, and would go through with this if the cost wasn't prohibitive.
With all that in mind, who do you recommend making it for me? What kind of LEDS should I use?
Thanks for the reply!
Cheers, Jerald!
PS, by that stat of 30,000 lumens, I would need about an array of 40 LEDs. I was thinking that a custom array would be able to fit quite a few more than that in there based on my desired array size of 344.5mm W) x 222.5mm (H) x 6.5mm(D)... Not sure though... thats why i'm here!
  #4
Old 09-06-2008, 05:36 AM
SemiMan SemiMan is offline
There are likely a lot of issues to consider here.
1) LEDS have a different spectra compared to Metal Halide. If you use most white LEDS, you may find that they are very lacking in red output and hence the colors that you get out are washed out. Though both the LED and MH may have the same color temp, the MH has a richer output across the whole spectrum. You may be able to use warm\neutral whites, but not sure.
2) When you put the LEDs close to the LCD, you will need to ensure that your LEDS are very consistent in terms of light output and color. At a minimum, you will need to ensure they are all from the same bin... binned for color and light output.
3) You WILL NOT one up the projector manufacturers. To get any sort of good light output, you need to concentrate your wide panel down to a small spot....pretty much need the fresnel for that. With just a projection lens, say a 7" lens imaging your screen, you would lose already 70-80% of your light since you have a big panel. Maybe if you got a 9" lens you could do better, but still would lose a lot. Whole host of issues w.r.t. backscatter, internal reflections, etc. that make getting a high level contrast very difficult. The best projector use lots of tricks including irises that change with the scenes to enhance contrast ratios well beyond what panels can do.
That said, it will be a fun project. When you look at high end LCD panels that are LED backlit, they actually use RGB LEDS, not white. They are not as efficient currently as white, but it is not just about efficiency, but color range. They are able to display a much much wider color gamut with very rich colors.
Semiman
  #5
Old 09-06-2008, 09:59 AM
snarfer snarfer is offline
Hey nobody has tried doing a DIY projector with a phlatlight evaluation kit yet. If you can get them to send you one it would really be an interesting first. Just to be clear, this is an LED source specifically designed for projectors.
Here is where to look. Best part for you is that they'll send out a complete solution with electronics and thermal management. So just be sure to come up with some sort of corporate identity, fake if necessary, in order to get them to sell it to you.
  #6
Old 09-06-2008, 10:21 AM
LukeA's Avatar
LukeA LukeA is offline
When the light passes through the panel, any evidence of its point nature is destroyed.
So I think it can be done. I think I would look to have about 8k-10k lumens.
Some MC-Es (12) in an array would do it. I'd mount them to something from here.
Driving them will be a little bit of a challenge. Someone else can chime in on how to do that efficiently from AC line voltage.
  #7
Old 09-06-2008, 11:16 AM
This is true of an LCD television, but not an LCD projector. If the panel diffused the light then how could the light be projected onto the wall as a coherent image?
  #8
Old 09-06-2008, 12:09 PM
LukeA's Avatar
Quote:
A converging lens creates a real image from any real object at or beyond its focal length.
If the panel did not diffuse the light, then the only image the projector would project would be the small circle representing the portion of the panel between the light source and the lens.
An infinitely small point source at the FL is only necessary to focus the lens at infinity, i.e. to create a parallel series of light rays for a light beam. A projector focuses at a finite distance and from an object of finite size (the LCD panel).
  #9
Old 09-06-2008, 01:46 PM
Unenlightened
Thanks for all the replies! Since this has gotten some attention, and you all seem to understand what I am after, I will put some more detailed information here about the projector itself.
First, the standard box:
http://diyprojectorkits.com/welcome/...0cb93611f4.jpg
http://www.hacknmod.com/pics/497-1.jpg
I want to mod this design by chopping off the back 6 to 8 inches and instead of using point lighting, using multipoint lighting. I was hoping to have an LED panel that was the same size as the LCD panel I was going to use. Here is a very rough schematic of the panel I am proposing:
http://img222.imageshack.us/my.php?i...edboardfk5.png
I'm not sure how realistic that is as far as a design goes, taking into account thermal management in between the LEDs, but that is the gist of what I am trying to do (i actually designed that one myself, a bit crude but shows what i am after)...
I plan on using this lens:
http://diyprojectorkits.com/welcome/...mart&Itemid=85
as well as a standard fresnel lens that is the same size as the lcd panel.
I looked at the Phlatlight, and it is used in actual projectors, and wouldn't be suitable for a DIY project if I understood what I am looking at.
LukeA, that would be a great site for finding the right heatsink or heatsinks...
Once again, thanks for your support!
Cheers, Jerald!
  #10
Old 09-06-2008, 03:52 PM
Maybe we are trying to say the same thing in a different way. All I'm trying to point out is that the eventual contrast ratio and brightness of the projected image will be proportional to the degree to which the light hitting the panel is collimated. This is why it is extremely difficult to use an LED array for this application - hard to collimate light from multiple sources.
The reason why the phlatlight was developed was in order to provide a high brightness LED light source that was also highly collimated, specifically for projection applications. As far as I know there is no other highly collimated LED light source commercially available, and no other LED light source used in professional projection applications. But I've been wrong before and anticipate being wrong again in the future!
May I suggest that you refer to this extremely thorough 14 page long thread on lumenlab for some more specific information on exactly how to go about this project from people who have actually executed it. Strangely enough it appears that the most satisfactory results were obtained not with an array of LEDs at all, but with a single P7! But please, don't take my word for it. Read the whole thread.
  #11
Old 09-06-2008, 05:33 PM
LukeA's Avatar
If we were trying to collimate the light, then, yes, a point source would be ideal. But we are not trying to collimate light for this project. We are focusing the light at a finite distance, not at infinity. No matter where all the light comes from, the image that the projection lens projects is that of the LCD panel. An evenly lit panel will project well. An unevenly lit panel will not. A poorly lit panel will not project well.
It seemed to me that the lumenlab guys were having trouble with their LEDs due to a lack of flux. Those crappy multi-5mm junction LEDs just don't put out enough light. The P7 worked better because it was their brightest solution.
Try this experiment: Take a flashlight and put a piece of paper over its bezel. Write something on the paper. Then take a large lens and focus the paper's image on the ceiling. It focuses sharply. Note that the effective light source is the entire circle of the reflector, not just the LED die. For large-panel projection, you want a brightly, evenly lit panel. It doesn't matter how you get that.
  #12
Old 09-06-2008, 09:41 PM
Oznog Oznog is offline
Well LEDs aren't remarkably more efficient than metal halide. It's kind of a toss-up, you have to take LED temp, ballast/driver losses and unused light into account. It could easily be less efficient.
On the nature of the panel: the LCD panel does not diffuse light. The first fresnel aims to focus the light into a plane of parallel light the same size as the panel and second fresnel. It is not diffused when transmitting through the panel in the way it would going through glass shower doors.
As such I don't think the plan to make a planar "backlight" of LEDs will work, because they're emitting light in all directions. This creates a very poor capture ratio on the lens.
As was said earlier, the ability of the lens to give a clear focus on the light depends largely on how much of a point the light source is. Unfortunately an array of LEDs doesn't act optimally for that purpose.
  #13
Old 09-06-2008, 11:10 PM
And if you read through the lumenlab thread you will find that the single P7 performed better than a much higher powered array, precisely because of the effect Oznog has pointed out.
Also, a point source is useful because it can be collimated. So actually a planar source radiating collimated light, such as the phlatlight, will also be optimal. But, again, an array of LEDs will neither produce collimated light, nor act as a point source, so it is not going to be very useful in this application.
This is not just theory but result of actual experimentation. People on lumenlab forum actually built these things.
  #14
Old 09-07-2008, 03:49 AM
Unenlightened
There is a solution though, and that is not to use a few extremely powerful LEDS passing through a lens, but about 190 5mm LEDS to form a planar panel of forward emitting light in extremely close proximity to the LCD panel (less than a 10mm gap between the LEDS and LCD). Also, just to point out, that the thread that is referred to here is not a "DIY Projector", but rather a mod of a commercial projector. That is a TOTALLY different animal. I am designing not to do a mod for a commercial machine with limited space constraints, but to simply shine a light through a 15.4" WUXGA LCD panel as intensely as possible. Uniformity is a bonus, but having the light pass through the condenser fresnel lens into the triplet lens should make the light more uniform. Not that big of an issue though, as I will have both the collimator and condenser lenses on hand to experiment with.
The higher powered array used in that projector mod is using different principles, mainly that it is trying to pass the light through multiple lenses before it even hits the lcd in the projector. My array will probably be lensless and as close to the lcd panel as I can have it without melting the LCD panel. It should look like this, but with a single color led and higher density:
or like this, but once again, higher density:
or like my reference design image:
I'd be willing to make a mistake as long as it didn't set me back too much money. You guys have the knowledge to help me minimize my error, and potentially produce some kickass results, which I would be proud to show you.
Things I have liked from your responses include:
"When you put the LEDs close to the LCD, you will need to ensure that your LEDS are very consistent in terms of light output and color. At a minimum, you will need to ensure they are all from the same bin... binned for color and light output." SemiMan
"Some MC-Es (12) in an array would do it. I'd mount them to something from here..." LukeA
"we are not trying to collimate light for this project. We are focusing the light at a finite distance, not at infinity. No matter where all the light comes from, the image that the projection lens projects is that of the LCD panel. An evenly lit panel will project well." LukeA
and Oznogs post makes some good points, but seems based on the idea that there will be a first fresnel lens to collimate the light. I'll have one on hand and will play with it, but think 190 points of 9 - 12 degree light would make the uneven distribution less of an issue.
So back to my original questions:
Like I said, the worst case scenario is that I end up blowing some money on a hobby project that produces mediocre results. I can use it as a light for my driveway if this doesn't work (another craftworking project), and throw in a 400w MH light.
Cheers, and thanks for your interest and advice, Jerald!
  #15
Old 09-07-2008, 09:47 AM
R33E8 R33E8 is offline
Have you seen Lamina's RGB Titan? They are bright and small plus I think they have 10 degree optics for them..
http://www.laminalighting.com/Produc...ies/Titan.aspx
They are $80 a piece though...
http://www.digikey.com/scripts/DkSea...me=521-1045-ND
They also have single colors which are ridiculously bright...
Red: http://parts.digikey.com/1/parts/138...51a0-0468.html
Green: http://parts.digikey.ca/1/1/1207894-...52c1-0470.html
Blue: http://parts.digikey.com/1/parts/138...52b1-0469.html
There is another company called Enfis that makes led arrays that might be even brighter.
http://www.enfis.com/products/index.htm
I don't have any experience with those..
  #16
Old 09-07-2008, 11:14 AM
Do some ray tracing and you will see why this will produce poor results. DIY projectors work on the same principle as commercial projectors. The only light that will end up in the triplet lens at the proper angle to produce an image will be the tiny percentage of the light from the LEDs that travels directly forward. All the rest of the light will just be contaminating the image. Also your image will probably not have uniform brightness. Good luck.
  #17
Old 09-11-2008, 07:04 PM
Unenlightened
I referred vaguely to this thread in an earlier post:
http://www.lumenlab.com/forums/index.php?showtopic=9136
This has been done before guys. In 2005. So here we are, 2008, LEDs have come along nicely, and I am asking for advice in the right place. I don't think that the guy that did this had the same idea as me, and ask for expert help.
Here is what we know:
Collimating the light is a challenge, if you actually decide to try to collimate it. A solution to this is probably needed, but the 2005 project got decent results without doing this. Possibilities include using lenses, shining the light through the LCD and hoping for the best, using small narrow angle LEDS, using large maximum power leds and than collimating them, using a diffuser before the collimator lens, and whatever else you guys can think of.
Not using a collimating fresnel works, because the guy that did the panel in 2005 did this and it worked. Efficiency is questionable. I think we can do better. Possibilities include using a different type of collimating lens that would be more compatible with multisource light.
We have MUCH better, brighter LEDS today than we did back than.
So here are my requirements:
Highest possible lumens hitting the LCD possible using LED lights. I am assuming this can be done using either a lot of small leds and creating a high density of lighting points, or using higher intensity, larger lights and some sort of higher efficiency lens to collimate the light.
SO let's go through the fundamentals.
1. Lots of smaller points of uniform light or fewer ultrabright ones?
2. Suggestions for lenses if it is determined they are needed?
3. Who would you get to fab this if it is feasable (and there is no doubt in my mind it is, as it has been done before).
Sound off here! Post up some recommendations for LEDs! Who would you have make this thing?
Cheers, Jerald!
PS, can you recommend a ray tracing program for me? Open source or freeware would be best...
  #18
Old 09-12-2008, 01:01 AM
I am still unclear on your lens setup.
I believe you wish to take a clear 15.4" WXGA panel and put a 15.4" backlight of perhaps thousands of T1-3/4 5mm LEDs behind it. How far behind it?
Where would the lenses be placed, and what size?
  #19
Old 09-12-2008, 01:49 AM
Unenlightened
The lens setup is something I will experiment with, as changing lenses is not as hard to do as changing LED arrays is.
You are correct about my intentions Oznog. I wish to place this 15.4" LED array of possibly thousands of LEDs behind a 15.4" WUXGA (HDTV quality) LCD screen. I have actually calculated that 3mm LEDs deliver more raw lumens per square centimeter than the larger 5mm or 10mm LEDs.
I was thinking of placing the LEDs as close to the WUXGA panel as possible to maximize light intensity. Probably less than an inch.
The lenses are typically the same size as the panel to be used, so both 15.4 inch, with a 450mm triplet lens at the focal point of the light to project it onto the wall.
Finally, the setup (light path) would be:
LED array------->1st Fresnel Lens to collimate the light *if needed* (probably in direct contact with the LCD panel)------------->LCD Panel----------->2nd Fresnel Lens to collect the light to a point --------> Triplet lens to project the light------------->Wall
I am NOT interested in using a single point of light. The whole reason I am wanting to do this is because it is a challenge that has not been completely solved. Doing this right would be a huge step forward for the LumenLab forum. Your help is massively appreciated.
Cheers, Jerald!
PS:
http://s384.photobucket.com/albums/o...NsLEDPanel.jpg
There it is, but we can do this better/right...
  #20
Old 09-13-2008, 12:48 PM
LukeA's Avatar
I think that you might have problems using epoxy-covered small-junction LEDs due to a lack of red in the emission spectrum and lack of heatsinking.
Also, 3, 5, and 10mm LEDs aren't as efficient as the newest high-flux LEDs. But in use, the delivered lumens/watt in an even pattern may be higher than say, MC-Es or XR-Es.
I think that you will still want to run a fan over the LEDs.
  #21
Old 09-14-2008, 05:13 PM
3mm LEDs are not a cheap way to make bulk light. See you can buy cheap 3mm LEDs on eBay or from KaiDomain/DX in large lots- but plan on a whole lot of color/intensity variation and on 5%-10% dying an early death (which in this case would probably take down a series string). Buying quality 3mm LEDs will get very expensive and honestly I'm not sure how much better their quality will be. No mfg I know of takes 3mm LED quality super-serious. The failure rate of very large arrays is not good.
They could overheat in high density. The 3mm T1 and 5mm T1-3/4 packages have very limited heat dissipation, generally relying on the leads to conduct heat away. With only a small amount of copper trace per lead pair the board will not be doing as much dissipation and yet you're pushing for a performance app.
The lens setup is important. It sounds like you must have a 15.4" Frensel lens right there on your panel otherwise much of the emitted light will be lost. Just look at it- a 6" lens 1 ft away for example only has a fraction of the emitted light going into the lens. But visually I think there's going to be a major optical quality problem of having the fresnel's prisms right next to the pixels. The fresnel should create lines of optical distorion in the projected image and those lines are going to be larger than the original pixels. We could use a non-fresnel type, but the specs get crazy huge and expensive.
  #22
Old 09-14-2008, 06:17 PM
actually a lens array (otherwise known as fly's eye condensor or hexagonal lens array), as opposed to a standard fresnel, would be needed, because each individual point source would need its own lens. such things are available in this catalog (pdf). The led array would also have to be matched to the lens array so that each led would be at the center of its individual lens. furthermore something would have to be done to reduce crosstalk between the led/lens pairs. something like a black honeycomb between led panel and lens array, also matched so that each led would be at the center of an individual honeycomb cell.
I appreciate your enthusiasm in attempting to solve this problem. This is not a problem that lends itself to a DIY solution. Oznog is right on the money with his analysis. A single failed led will ruin your image.
If you could fabricate something like the material described in this patent then you could collimate the light from numerous discrete sources and you might be able to avoid the single failure problem. It's not as hard as it looks. Probably just need to get a place with a laser to burn holes in a sheet of reflective sticker and properly align the sticker with the lens array from previously mentioned source. only problem is you might not get enough collimation.
  #23
Old 09-14-2008, 09:28 PM
You've taken a look at the poor man's projector, right?
Guys have taken LCD screens, removed the backlighting panel yielding a clear screen, and simply put it on an overhead projector along with some fan cooling to ensure the screen doesn't heat up due to the blocked light. While bulky, the resolution and light intensity is supposed to be really good.
Consider the setup- light source on bottom emits at wide angle, big fresnel redirects light towards the head on top which has a lens pair. There is very little leaked light that does not focus on that head lens. The lens head is focused on the image surface and has nothing to do with the fresnel focus though. In fact it's better that the image is above the fresnel because when the head is focused on the image the fresnel goes out of focus, which blurs out the residual lines created by the prism pattern. But, either way the fresnel is oriented to send all the emitted light onto the first capture lens on the head.
  #24
Old 09-14-2008, 10:15 PM
I did not see that, but yes that is the basic concept I was getting at. You need to use a backlight type optical arrangement for this to work. You could even use an actual backlight assembly if you could find one. It will have a lightguide and some film, perhaps 3M TRAF and/or BEF or DBEF. If you find one designed for CCFL tubes you could probably still use it, just substitute a row of LEDs for the CCFL. Look on the 3M Vikuiti site for some in depth information on how to use the various films. You can order the films themselves from Digikey. With this arrangement you no longer need a dense array of LEDs, nor do you need LEDs with lenses. You could use basically anything that gives you enough illumination. I would suggest using some reliable name brand LEDs in surface mount package so you can attach the thing to a heatsink. Probably using a lot of smaller LEDs will be more effective, as that is how LED backlights are made. Nichia may be more efficient, but OSRAM will be easier to order in small quantities.
  #25
Old 09-14-2008, 10:34 PM
oh look somebody did something similar, well not the projector part, but the backlight part. I hope you do better than this. Just use better and more LEDs.
  #26
Old 09-15-2008, 01:04 AM
The backlight is still doing the wrong thing- emitting light everywhere, not directed onto a lens. Easily 95% of the light could be lost.
That guy tried to wire his LEDs in parallel without ballast resistance- and somehow 9 out of 40 failed soon. Huh why do you think that is?
  #27
Old 09-15-2008, 01:35 AM
Well his purpose was not projection. But the point was that LCD backlights are designed to collimate diffused light from multiple sources. So you could use the backlight assembly that came with the LCD, add another couple layers of BEF, replace the CCFL with high power LEDs and at least you'd have an image that wouldn't be all swiss cheesed with dead LEDs.
And of course he didn't have a clue about how to power his LEDs, let alone where to buy LEDs. But even though he did a horrible job, the image on the LCD is fairly even, which shows you that the light guide was working.
Now if you could find a replacement array type LED backlight optical assembly that would probably work a lot better. I have just spent the last hour trying to find one for a different project. I know it must be possible, as several manufacturers are building them into LCD TVs, but finding the proper part numbers is proving difficult. Or perhaps they only sell the backlight assembly bundled with the LCD.
  #28
Old 09-15-2008, 08:09 PM
Unenlightened
The more I think of this problem, the more it seems that making the light source efficient will make the most benefit. Collimating the light would produce the best results. So here is what i have found so far that might do the trick. Since my technical knowledge is limited, I could be off the mark.
http://www.display-optics.com/pdf/RC...eetMarch08.pdf
Not much time to write a long post. What do you guys think?
Cheers, Jerald!
  #29
Old 09-15-2008, 08:46 PM
That's exactly what I was thinking. I am trying to get some of that material for another project. It is functionally the same thing as two layers of 3M Vikuiti BEF, which you can order from Digikey.
I think that if you have the backlight assembly from the LCD you're using you should layer more BEF or Reflexite, whatever you have, on there.
Keep in mind that you also need an extremely reflective surface for the light recycling to work. So you might order a sheet of 99% reflective 3M ESR as well. Or you could get 98% reflective silver mylar a lot cheaper.
  #30
Old 09-25-2008, 12:21 AM
Unenlightened
Default Backlight Enhancement Films, Prism Films, Collimating Films, Oh MY!
Found some good stuff, educated myself on this light collimation thing. These are indeed what I am looking for (now that I understand bettter what it is that I needed). Sourcing them is going to be another story. Your opinions on these products are appreciated, and I would like to thank you all for the help you have given me.
As I understand it, these films are applied to the LCD to collimate the light as it enters the panel. Furthermore, it collimates this light no matter what the source or how many sources the light comes from. Diffusing the light comes either before or after it enters the prism film (typically before it enters the prism film). Typical brightness gains range from 120-160% on the other side of the panel due to the amount of usable light.
It is than AFTER the light exits the panel (on the other side) that it is commonly diffused to increase the viewing angle. So, to get the most out of the lights I use, I will be using one of these film on my LCD. Here is the list:
http://solutions.3m.com/wps/portal/3...ary/optics101/
This taught me everything I know about this subject. Awesome.
http://multimedia.3m.com/mws/mediawe...6EVs6E666666--
The original 3m product. It is available, as snarfer said earlier, through digikey. Availability counts for alot. Kinda pricey though i think, but whatever... The Reflexite stuff seems better...
http://www.brightviewtechnologies.co...ta%20Sheet.pdf
That is a microlens sheet, designed for a wider viewing angle. Not sure I like it. This company also offers light management films for luminaire design which might be useful to you guys and gals.
http://www.reflexite.com/pix/pdf/RCF...eetMarch08.pdf
A prismatic film that seems like it would be an almost ideal collimator. 160% increase in brightness on axis.
http://www.fusionoptix.com/PDFs/PF/PF9048-250_d.pdf
They only claim an increase of 120% (including the light diffuser film).
http://www.gammaopto.com/bgp_en.html
Not sure how efficient this is, but claims to assist with color correction, which seems to be a unique feature...
http://img.b2b.hc360.com/handbook/4-1-1001141.pdf
A chinese company. 1.45 (145%) claimed gain from what I can tell.
http://www.wft.bz/index.htm
This is an american company that does some REALLY interesting stuff. Of all the companies that didn't list product specs, this is the onyl one that I would consider following up on. Best website of all the other companies listed. They claim to do custom films for 250.00 a kit...
Well, that is about all the useful info I could find. I got it from this web page here:
http://64.233.169.104/search?q=cache...ient=firefox-a
Please let me know if I have the right idea. So a big part of this puzzle has been figured out. Picking one and sourcing it will be a challenge. With the basic premise that I can use any type of light, do you guys have any recommendations? Should I go with an array or with one of the 100-500w. led packages? Also, adding some red leds somehow would potentially make up for the CRI issue if I used a diffusion film. Man, so many ideas...head about to explode... Goodnight~!
Cheers, Jerald!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
