Re: UV light bulb
Fluorescent germicidal bulbs are cheaper, but then you've got to buy the ballast and fixture, or you could retrofit an existing fluorescent desk lamp with a germicidal bulb. You're probably looking at $20-$35 at the least for a germicidal tube.
The next cheapest alternative is direct sunlight. It also contains UVB rays, although at lower levels.
BTW, forget about doing it with UV LEDs. Shortwave UV LEDs are extremely rare, extremely weak and unbelievably expensive. It would cost you many thousands to do it that way, and it wouldn't work nearly as well as the other lamp technologies.
