CandlePowerForums
Go Back   CandlePowerForums > Beyond Flashlights > LED
CPF Only
User Name
Password
Register
4Sevens
Reply
Thread Tools Display Modes
  #1
Old 10-19-2008, 11:25 PM
ahorton's Avatar
ahorton ahorton is offline
Default MC-E Spot Optics Intensity Plots - Now General Intensity Plots
I was looking into the MC-E optics and I realised that all the intensity plots look the same because they scale the axis to fit the relevant part of the data.
So I decided to compare them all on the one plot. This doesn't actually add any info, but I like how it represents the data all together.
I took the info out of various data sheets for spot/tight optics, plotted a few points, made cubic-Hermite splines, integrated the splines and scaled them appropriately. All the optics I scaled down by 15% (relative to the raw MC-E) since they all claim about 85% efficiency.
So in the plots below if you integrate across all the optics you will get 0.85. Integrating across the MC-E spline gives 1.
The two aspherics were from my own experiments. They give roughly 4 and 2 degree beams.
I made the assumption that 90% of the light hitting the aspheric was transmitted. I calculated the amount of light hitting the aspheric by integrating the MC-E spline from -45 to 45 degrees for the 4 degree beam and from -35 to 35 degrees for the 2 degree beam (that is, a 30mm lens 15mm from the MC-E and a 50mm lens 36mm from the MC-E). This revealed that my 2 aspherics were picking up about 77% and 63% of the available light. Not that much in my opinion, but of course you can't beat them for tightness of beam.
Integrating across two aspheric splines gives 0.69 and 0.57 for the 4 and 2 degree beams.
The two aspherics ruin the plots so I zoomed in to show some detail.
I like this view. Can anyone confirm or deny some of my results?
  #2
Old 10-20-2008, 04:14 AM
ahorton's Avatar
Default Re: MC-E Spot Optics Intensity Plots
On the logic that throw length is proportional to the square root of intensity, I figure this plot should show relative throw lengths.
I'm not sure that I believe that my narrow aspheric throws less than 5 times as far as the raw MC-E, but that's what the maths tells me. It may be that the aspheric seems to throw further because you can always see the definite contrast. Then when I stand outside with a raw MC-E, my nightvision is ruined by the local flood and I don't realise that it is actually putting some photons on a tree 20 or 30m away.
  #3
Old 10-20-2008, 04:31 AM
znomit's Avatar
znomit znomit is offline
Ahorton, thanks for that.
Could you normalise the central intensity to 1 and replot for comparison.
__________________
My LED Bike Lights:
A few Dynamo builds, Dual bflex road, Quad bflex MTB, Very small lights.
  #4
Old 10-20-2008, 05:00 AM
ahorton's Avatar
Happy to, though it doesn't show any more info. These are the intensities, not my predicted throw lengths.
  #5
Old 10-20-2008, 05:35 AM
Holzleim's Avatar
Holzleim Holzleim is offline
Great idea, to create this plot based on the square root of the relative intensities. So one get get a good feeling what the usability of the resulting beam will be concerning relationship of throw and flood.
I think you are right with the assumption that the raw MC-E prevents you from seeing as far as expected per math in relationship to the asphere due to the fact that the near by objects are enlightened by the extreme food beam that way that your eyes sensitivity is pulled down.
I can confirm this from my own self made aspheric lights that the very small amount of side spill light you can achieve by using aspheres is very useful for looking at very far objects is the spot of your light.
I'm planning to use the CARCLO PLAIN TIGHT 26,5mm optic in my multi MC-E light. Would be very nice if you could integrate this one in your comparision .......
Thanks for your effort,
Holzleim
__________________
David (10000LUX at 18x55mm size):
Or something slightly bigger: Mr.Beambastic ... 500W LED power
  #6
Old 10-20-2008, 05:50 AM
ahorton's Avatar
Quote:
I would if I could find a datasheet from Carclo that includes a relative intensity plot. All I could find from them were FWHM figures.
  #7
Old 10-20-2008, 06:29 AM
Holzleim's Avatar
Yes, you are right.
I just asked there sales for a more detailed datasheet containing relative intensity plots.
__________________
  #8
Old 10-20-2008, 03:53 PM
liveforphysics liveforphysics is offline
Great work! Awesome job! Very useful data for helping with lens choice!
Thank you!
  #9
Old 10-20-2008, 04:24 PM
Hack On Wheels Hack On Wheels is offline
Hmm, I was thinking of making a couple dual MC-E lights with the Boomerang optics to be my only two lights. Now I'm worried that the Boom MC-S won't have enough throw. Then again, relative to the intensity that a Ledil SS optic for a R2 would give, it would still be an upgrade, especially with two of them. Hmm... how spotty is too spotty? How much is not enough??
  #10
Old 10-20-2008, 05:29 PM
ahorton's Avatar
Quote:
Good idea. The next set of plots I make will start comparing different LED / optic combinations (scaled according to rated flux). In particular, I want to see the comparison with my aspheric'd XR-E R2s. I won't get to it for a little while yet, but am happy to take requests for other comparisons.
  #11
Old 10-20-2008, 10:22 PM
Quote:
That would be great! I would be most interested to see comparisons with the R2 + Ledil Square optics: RS, SS, D, and M. Though, naturally, anything would be good. Thanks for doing this.
  #12
Old 10-21-2008, 08:17 PM
netprince's Avatar
netprince netprince is offline
ahorton: would you mind giving a little more info about the aspheric lenses you are reviewing? Perhaps a link?
  #13
Old 10-21-2008, 09:01 PM
ahorton's Avatar
For this one, I'm not sure the specs are right. You'll notice a difference in the focal length I mentioned above.
2 degree: http://www.surplusshed.com/pages/item/l3033.html
4 degree: http://www.surplusshed.com/pages/item/l3461.html
  #14
Old 10-22-2008, 02:09 AM
Holzleim's Avatar
Hi ahorton,
if you could provide me with an email adress I could send you .ies and .ldt data for some of the CARCLO optics.
I'm new to this kind of data format and found a viewer for the .ies data. If you like, I can provide this to you, too.
Hope you are more experienced with this kind of data than me....
Regards,
Thomas (Holzleim)
__________________
  #15
Old 10-22-2008, 03:22 AM
ahorton's Avatar
Ledil Square Optics for the XR-E, the R2 doesn't matter here.
  #16
Old 10-22-2008, 04:57 AM
ahorton's Avatar
Default Re: MC-E Spot Optics Intensity Plots - Now General Intensity Plots
This one was of particular interest to me.
I thought that given the amount of light that an aspheric lens doesn't pick up with the MC-E, maybe a tight optic might give better throw. If my assumptions are correct, then I'm better off sticking to the aspheric.
I've assumed my XR-E R2 at 1A puts out 250 Lumens and my MC-E M at 0.7A puts out 750 Lumens. So the plots are scaled according to their cubic inverse.
The aspherics transmit 90% of light that hits them but I've only given the optic 85%.
  #17
Old 10-22-2008, 07:24 AM
netprince's Avatar
ahorton: Have you seen this lens? I was thinking about trying it on a mag with mc-e. Its got a 16mm fl from back plane, which would help collect more light, but I'm not sure how well the multi-emitter would project.
http://shop.mellesgriot.com/products...01%20LAG%20010
  #18
Old 10-22-2008, 08:27 AM
ahorton's Avatar
That's a nice lens. It would be a bit more efficient, but I think I'll save my money and use the ones I have for now.
  #19
Old 10-22-2008, 08:57 AM
ifor powell's Avatar
ifor powell ifor powell is offline
The plots are nice but I think some caution is needed, it's all from the datasheats and to be honest from the simple testing I did 12 mounths back with various XR-E optics the datasheat and reality sometimes leaves a bit to be desired. I had some optics from one manufacturer that had differnt half angles but you could not tell the differance in reality by eye or with a camera or a lux meter. Others looked to be speced very similarly e.g. very similar half angle very similarly shaped plots but the max lux reading from one was twice that of the other...
I am waiting for my MCE's and varios optics with interest.
Ifor
__________________
pictures of my lights
  #20
Old 10-23-2008, 01:20 AM
ahorton's Avatar
Quote:
Especially if you count the assumptions I have had to make along the way.
I assumed all the optics were 85% efficient. If one is 95% and another is 75%, that's a big difference.
  #21
Old 10-23-2008, 01:49 AM
..any chance of a Ledil CRS to Ledil Boom comparison? The aspherics seem to make the other options not look so great due to the nature of their intensity, would it be possible to do some more plots without them? I'd be curious to hear from people using aspherics though... do you find the beam pattern to be too weird/odd to use? I couldn't imagine using something like that for a bike light... flashlight maybe though.
  #22
Old 10-23-2008, 08:10 PM
ahorton's Avatar
You'd have to tell me what LED you mean. CRS and BOOM for XR-E I'm guessing.
  #23
Old 10-24-2008, 08:27 PM
Oh, you mean you aren't telepathic?
Yeah, my brain skipped right over some details there... haha, I was thinking CRS for R2, to Boom with MC-E... Basically the setup that I'm using right now.. to the setup that I'm looking at using.
  #24
Old 10-26-2008, 09:56 PM
ahorton's Avatar
I've assumed 750 Lumens for the MC-E and 250 for the R2.
I hope you are not looking for throw from the MC-E.
  #25
Old 10-28-2008, 10:55 PM
Thanks!
Ah, oddly enough, I was kind of hoping for some decent throw... I was hoping it could replace my triple R2 setup with one RS, one SS, and one M. Looks like even 2 MC-Es with S reflectors won't match that. That's a shame... but I can't say I'm a huge fan of the RS, as I do notice the artifacts quite a bit and obviously the distribution of intensity isn't very even...
Hopefully someone has an option that would give more throw though.. I would like to at least have that option before I finalize my housing design.
  #26
Old 11-10-2008, 10:34 AM
phantom23 phantom23 is offline
Ledil RGB-X-MC optics looks quite throwy.
  #27
Old 11-10-2008, 11:21 AM
gibby_z gibby_z is offline
Unenlightened
Quote:
Anybody have them on the shelf yet?
  #28
Old 11-10-2008, 12:40 PM
Ledil Eva - quite big but also throwy.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
