Re: New and hoping someone can help
>I beleive that an led solution will work.
LED will give you enough light for a good picture, my concern is that your colors will always be a little off. You might have a cross section of different LEDs, take pics in visible, UV and IR lighting if you care to. If you use UV on paper, fabric, painted objects keep exposure short so you don't fade the item. You might use LED to set up the shot, flick on the power hungry Solux to take the pic, flick it back off, get more battery life.
>Seeing some threads on this site that talk about High CRi lights
>being used in flashlights.
So track them down, see what bulb they use. Incan is good for CRI, bad for power usage, heat.
> I s there som way I can repose the questions to get more discussions?
Not sure.
>Also, I am curious about your comment of cross posting being bad form?
>Could you explain. Yes I have posted othis qusestino on sother sites
Other sites we don't mind.
> I posted it on a very specialied forum and one of the forum admins
>recommended that I repost it under the general forum area.
Just take down the first when when you post the second copy.
I think you might want to get a small case with wheels and an extensible handle to build all this into. I'd like to suggest you consider 12 volt DC for your power supply. There are lots of standard parts available in this range. If you travel by car you can plug it into the lighter, recharge the battery while you drive. Not sure which battery chemistry you want, but probably not lead-acid (cheap but heavy.)
The components you need, my first impression:
The housing, something like an aluminum attache' case.
AC power adapter either 120 or 240 depending on where you'll be
12 volt power cord for vehicles
Battery, maybe NiCad or NIMH for good power/weight ratio. Having a battery means you can set up anywhere, anytime no outlets required.
Stage where objects will lie, perhaps a flip surface with black velvet on one side, white on the other, you use whatever gives best contrast. Perhaps a second/third surface with other colors.
Camera stand that holds camera at proper distance from stage. You might be able to mount your light(s) on the stand also.
Pockets for camera, diffusers, reflectors, spare bulbs (if incan) spare batteries and memory for camera.
All of this is perfectly doable and should fit well into the limits you want.
