CandlePowerForums
CPF Only
User Name
Password
Register
FoxFury Fire Helmet & Hard Hat Lights!
Reply
Thread Tools Display Modes
  #1
Old 02-13-2009, 02:45 PM
bshanahan14rulz's Avatar
bshanahan14rulz bshanahan14rulz is offline
Default Help with understanding aspherical lenses?
Ok, so I'm trying to find an aspherical lens with matching dimensions to one I am holding in my hand. If I hold it dome up and look at something on my desk, the point at which everything gets infinitely large and then flips around is one of the focal points, but which one, A or B?
It is measured in mm. but is it mm between focal point and the flat plane? perhaps the rounded side?
and what's this about two focal points? they are on the same side, correct?
I guess my main question is this: the focal measurement is the distance between the focal point and what?
Here's something I threw together with MSPaint to help explain my question. are the focal lengths the measurements in set 1 or set 2? or something else entirely? Thanks!
  #2
Old 02-24-2009, 08:51 PM
Default Re: Help with understanding aspherical lenses?
bump. Is the diagram above even correct? I'm just assuming, since I figure the focal point would be where i can be on the other side of the lens and see everything get infinitely large, the spot where the image flips.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
