Re: Incandescent vs. Fluorescent Light Bulb Question
If you can get that monster of a CFL to fit in your light (biggest we get here is 26 watts and they`re pretty enormous), it`ll be fine - CFLs are significantly more efficient than GLS lamps and emit only a fraction of the heat in comparison.
However, some CFLs don`t like being in enclosed spaces because the heat they do emit can build up and go above the design rating of one or more of the components in the ballast, so the only thing you should be aware of is any warnings on the packaging of the bulb to avoid enclosed fittings. If it has no such warnings it should be OK.
Lights of America lamps have had a poor review from Light-bulb guru Don Klipstein. Poor colour rendering (maybe not so bad for an outside light), premature failures and iffy connections between the tube and ballast. Not to mention the proprietary bases in their CFL fixtures meaning that if and when the lamps are discontinued, you`re stuck with a useless lamp that won`t take any other bulbs. Not that it`s an issue in your case of using an incandescent-replacement type CFL with screw base, but it does say something about the company themselves.
Unfortunately I have exactly no American CFLs in my vast collection of bulbs (but would like some one day of course!) so am relying on 2nd hand information. LOA brand bulbs may have improved lately, maybe they havn`t. But they don`t seem to have a great reputation in the past.
Here`s hoping your bulb will be OK though.
[img]/ubbthreads/images/graemlins/grin.gif[/img]
