I received the LumaPower Signature TurboForce Q5 a couple of weeks ago from
Battery Junction.
I purchased the Turbo Head version.
The Signature TurboForce comes with an SMO reflector and the OP is also included. For this review I just shot beam shots with the SMO. Maybe later I can do some shots with the OP reflector. Using the SMO reflector this light has some throw. The beam has the usual Cree rings. The hot spot on my light is slight off centered. The beam looks nice and white. There is GITD o-ring installed behind the lens. BTW this uses a Cree Q5.
On the side of the body is the the 4 mode switch. The order of the modes is high, medium, low and strobe. The UI is very easy to use.
The on off switch in the rear of the light is a forward clickie that almost sits flush the tail cap assemby when in the off position. In the off position the rear rubber switch cover sticks out about 1.5mm. When the rear switch is turned on the light will sit on it's tail. The forward clickie is very easy to push. Positive click no mush. There is some lanyard holes in the tailcap assembly.
Also included is a holster. On the sides of the holster a thinner material is used. It's flexible and it's elastic. The velcro holds very good. The velcro on the holster is 1 3/8" x 3". The velcro on the flap is 1" x 2 3/4". There is a belt loop on the back which can be opened my a snap with a small piece of velcro on it. Wearing the holster on my belt with the Signature TurboForce installed the holster feels well balanced.
O-rings and a spare black rubber switch cover is included. A GITD rear rubber switch cover is installed on the light.
The finish is a shiny black Type III Hard Anodize. The finish is excellent no difference in colors between the body parts. Signature is printed on one of the flats and on the other flat is the word LumaPower with the serial number.
The fit is excellent. Threads are smooth.
The LumaPower Signature TurboForce fits my hand very good. Feels well balanced. It has one of the thinner battery tubes for a 18650 or a 2 CR123. The light does feel kind of slippery in my hand.
High Circuit Efficiency Without PWM Flickering. I cannot see any PWM fickering at any levels.
Wide Range Input Voltage (Fully Regulated At 4v to 10v, 2.4v-3.9v Semi Regulated). I did get a higher lux reading with one AW Protected 18650 than 2 AW Protected RCR123's in high mode. Usually it's the other way around, higher lux readings with 2 RCR123's. The lux readings in medium and low were higher with the AW Protected RCR123's.
Pros
Throws very well.
Comes with a OP reflector, holster, o-rings and rear rubber tailcap.
Uses a 18650 and RCR123's batteries. I had no problems with the batteries not fitting.
Easy to use UI.
Forward clickie.
Cons
Wish the light had some aggresive knurling. Feels slightly slippery in my hands.
Hot spot slightly off centered.
Comes with o-rings.
Comes with a holster.
Comes with the SMO reflector installed.
Comes with an OP reflector.
Uses a Cree Q5.
Rear view of the Cree Q5 module.
Fits my AW Black Protected 18650 and AW's RCR123's with no problems.
Inside view of the rear forward clickie.
It's very easy to change the reflectors. Just unscrew the lens bezel assembly.
Left, SMO Reflector. Right OP Reflector
___________________________________________
Size comparisons.
Left to right, LumaPower Signature TurboForce Q5, Olight M20 R2, Fenix TK11 Q5
Left to right, LumaPower Signature TurboForce Q5 SMO, Olight M20 R2, SMO Fenix TK11 Q5 SMO
I took lux readings of the above lights.
LumaPower Signature TurboForce Q5 SMO 18650, (high) - 11,820 lux @ 1 meter
LumaPower Signature TurboForce Q5 SMO 18650, (medium) - 1040 lux @ 1 meter
LumaPower Signature TurboForce Q5 SMO 18650, (low) - 300 lux @ 1 meter
LumaPower Signature TurboForce Q5 SMO 2 RCR123's, (high) - 11,520 lux @ 1 meter
LumaPower Signature TurboForce Q5 SMO 2 RCR123's, (medium) - 2140 lux @ 1 meter
LumaPower Signature TurboForce Q5 SMO 2 RCR123's, (low) - 920 lux @ 1 meter
Olight M20 R2 18650 (high) - 8,380 lux @ 1 meter
Fenix TK11 Q5 18650 (high) - 7,310 lux @ 1 meter
Beam Shots
LumaPower Signature TurboForce Q5 SMO 18650 @ 96"
Olight M20 R2 SMO 18650 @ 96"
Fenix TK11 Q5 SMO 18650 @ 96"
Left, LumaPower Signature TurboForce Q5 SMO 18650, Right, Olight M20 R2 SMO 18650 @ 96"
Left, LumaPower Signature TurboForce Q5 SMO 18650, Right, Fenix TK11 Q5 SMO 18650 @ 96"
Left, LumaPower Signature TurboForce Q5 SMO 18650, Right, Olight M20 R2 SMO 18650 @ 96" Stepped down exposure
Left, LumaPower Signature TurboForce Q5 SMO 18650, Right, Fenix TK11 Q5 SMO 18650 @ 96" Stepped down exposure
LumaPower Signature TurboForce Q5 SMO 18650 @ 32'
Olight M20 R2 SMO 18650 @ 32'
Fenix TK11 Q5 SMO 18650 @ 32'
LumaPower Signature TurboForce Q5 SMO 18650 @ 146' or 44.5 meters
Olight M20 R2 SMO 18650 @ 146' or 44.5 meters
Fenix TK11 Q5 SMO 18650 @ 146' or 44.5 meters
LumaPower Signature TurboForce Q5 SMO 18650 @ 210' or 64 meters
Olight M20 R2 SMO 18650 @ 210' or 64 meters
Fenix TK11 Q5 SMO 18650 @ 210' or 64 meters
