03-22-2009, 11:57 PM
Homemade 24" scratch built & designed reflector
__________________________________________________ __________________________________________________ _______________________________________
SNEAK PREVIEW: Rotating 24 inch homemade LightSward with 100 watt HID.
Click the Image for Video
Rotating beam shots from the 24 inch LightSward searchlight
This video shows the 24 inch homemade LightSward rotating on it's new gear box.
I have finally finished design/ building my 24 inch reflector and temporarily mounted a 100 watt short arc pulse ignition metal halide lamp from Home Depot. I am very pleased with the results.
At the same time I was completing the 24 inch reflector, I installed a 35 watt HID from a fog lamp, into my old incandescent Cyclops. This made it appear much brighter with a much thinner better focused beam. It has a much longer run time now, (it is about one third the brightness as the 24 inch reflector with the 100 watt HID. NOTE: I plan on changing to a 400 watt HID, budget permitting.)
There seems to be some 'threshold' that is achieved at some point, that allows the beam to become bright enough to be seen easily for some distance more than a few blocks. The original Cyclops is on the verge of doing this, but not quite. The 35 watt HID modifications seemed to have done the trick...perhaps the bluer light color and the much more focused and brighter beam crosses this line into an easily seen beam.
The 24" reflector homemade light is bright enough to easily cross the "beam threshold" and to be seen for a dozen blocks or so. The large reflector (24" homemade Using (TRIM BRITE) Chrome Brite@ Metallic Tape came in 3" x 60" strips, ...it looks like it reflects at least 75% of the light), it took several pakages to complete the 24" reflector.) allows me to make some mistakes that a smaller one would be less forgiving of. I can experiment with many different household bulbs...including a tin can sized CFL (Compact Fluorescent Light bulb), which surprisingly with the 24" reflector, makes a pretty nice flood/spot light for lighting part of a ballpark, basketball court or play field for night time sports. I really intend to use it to periodically paint the sky with a beam of light or light a distant hillside when out enjoying the night. The 24" reflector, (LightSward), battery pack and ballast hopefully won't weigh too much.
The Cyclops 35 watt HID modification was actually achieved while watching Late Night Comedy shows. (When finished It looked 3 times brighter and had a much tighter Hot Spot and last at least twice as long on a battery charge as the original 100 watt incan., bulb.)
For me, the best way to find the focal point, after the standard geometric and mathematical calculations and measurements, is to build a "Delta Focusing Plate", or often just using spacers and washers, is, (to verify focus point I sometimes, I first carefully hold the operating bulb base with pliers in one hand and steady the reflector with the other hand, and gently move the the bulb in and out and back and forth a little, to find the sweet focus spot on a wall a hundred feet or so away. Then I memorize the exact spot of the bulb base relative to the bottom mounting area of the reflector. I have someone photograph this if needed. I can usually measure and confirm the exact focus spot using a laser as well. From this I can then design very good bulb positioning hardware, sometimes with the aid of Auto CAD).
I did successfully design and build, rather easily, a 24" parabolic reflector for about $35.00 plus time...and I used a slowly spinning 'screed' shaped like a deep parabola to apply the final surface of Dry Wall Joint Compound on fiberglass and Styrofoam framed reflector. I used this design to harness as much light from a standard HID Home Depot Metal Halide Lamp 100 watts, as I can. I get a very well focused brilliant beam that goes out several miles and the beam can be seen for about one and a half to two miles especially when the light beam is moved across the sky.
At the same time I was building the 24" reflector, I modified an incandescent [Supposed 15 million candlepower (what is it really?)], Cyclops with a 35 watt HID fog light. I removed the bulb and ballast from the fog light...and lucked out on the focus with a home made sheet metal washer I made from scrap metal, and some banding wire. Very tightly focused beam compared to the original Cyclops and much brighter too.
As mentioned earlier, the 24 inch parabolic reflector was designed and built completely from scratch, using rigid foam insulation, fiberglass, dry wall compound and chrome tape. I was very impressed with the tightly focused beam I get using a 100 watt regular metal halide pulse ignited 1/2" arc discharge bulb. I intend to dramatically increase the wattage when budget allows. Currently This light can operate on battery power and auto as well as household current. Currently when I aim the beam into the sky at a 45 degree angle, I can drive two miles and see the beam in the night sky. Hopefully some not so sharp, low quality photos and beam shots will show the modified "Cyclops" and the homemade 24" reflector searchlight. I need a better night camera.
I took more beam shots of the 35 watt HID modified Cyclops, simply because it is much easier to pose the beam for photos. The 24" homemade reflector LightSward is still temporarily sitting on a box.
I am very satisfied with the results of both lights. I got many of the ideas from "CandlePowerForum" Once I finish the 24" assembly and can manipulate the light more easily, I will get better beam shots. I'm excited to see what happens when I install a 400 watt HID.
LightSward
The totally from scratch, homemade 24" parabolic reflector on temporary stand, (cardboard box), next to the modified, HID added, Cyclops
24 inch reflector is chrome tape finished and ready for first test. 2bc
First test run of 24 inch parabolic reflector. 2bc
The lower spot is the modified 35 watt HID Cyclops, ( Cyclops was originally 100 watt incandescent), compared with the upper Homemade 24 inch reflector (LightSward) light beam spot. Both lights are about 30 feet away from wall. The picture frame around carpet is 36 inches tall!
The HID modified Cyclops and 24 inch homemade reflector amongst others. 2bc
Searchlights at 45 degree angle from horizon and aimed overhead towards camera. The New brighter 24" homemade reflector, with 100 watt metal halide short pulse arc tube, is on our (viewers) left and modified 35 watt HID Cyclops on our right.
The two Light beams compete with the street light. The bright beam on our (viewers) right is 24" Homemade reflector ("LightSward") and the beam blazing to our left is the modified HID Cyclops
Tree is 200 feet away
The Hot Spot from the modified 35 watt HID Cyclops is actually smaller than shown, (Camera easily overexposes). I need a better camera
The Modified 35 watt HID Cyclops beam competes with street light
Beam Shot of Modified 35 watt HID Cyclops on the left versus the much brighter New Homemade 24" LightSward beam
Cyclops HID warming up to full brightness
Beam from 35 watt HID modified Cyclops paints the night sky
Beam is easily seen for a mile or more in the night sky. When lights are moved or rotated back and forth, the beams can easily be seen almost two miles. Once I get a better camera, I can photograph the beams from a mile or so. I plan to upgrade the 24" LightSward from a 100 watt metal Halide to a 400 watt metal halide (pulse ignition with 1/2" arc discharge tube). The partial purpose of the large 24" reflector was to allow experimentation of using ordinary household light bulbs etc., for fun!
I will get better beam shots when I have access to a better night camera.
Reason: photo clarification
03-23-2009, 01:31 AM
Re: Homemade 24" scratch built & designed reflector
Nice work. Looks like you used a mylar film to coat the reflector? Hope you can get some long distance beam shots with a good camera. BTW have you tried using it with an LED?
__________________
OMG Lumens, Inc....maker of the DEFT the worlds longest throwing LED flashlight
03-23-2009, 01:34 AM
BTW this really should be in the homemade and modified section. Might knock on the door of one of the Mods and have them move it for you.
edit Maybe this just needs to be locked as you have posted this at least four times. One here and three times in a different thread.
__________________
03-23-2009, 07:39 PM
Quote:
I used The newest most mirror like heat resistant chrome metallic tape I have ever seen. Very flame resistant, after installed...I held a flame up to it for several seconds and there was no change. Many stores and national chains had something almost as mirror like but most brands either didn't reflect as much lite or were dull and gray in comparison and/or wrinkled easily. This (TRIM BRITE) Chrome Brite@ Metallic Tape came in 3" x 60" strips, (it looks like it reflects at least 75% of the light), it took several pakages to complete the 24" reflector. Easy to cut into wedges that apply nicely to the parabolic shape. This brand is found only in a local auto parts store here in Portland, Oregon or find it online?! There has been two very big break throughs in spray paint. I've tried one, though very mirror like now, still slightly grey and I don't know the longevity of it. About six dollars a can and takes a large amount on a very smooth surface to get the desired results. There is also a pint of some very good stuff that costs in the hundreds of dollars, I hear is very good (see CPF).
I'm working on better beam shots.
I have tried using different LEDS with very good results...Just wish they made them in the thousands of lumens or a very small cluster of bright LEDs or a very bright single LED. The focus, of one of the LEDs I used, was actually the way I calibrated the focal point of the 24" reflector. I have an LED 4 watter that is more than twice as bright as a 3 watt LED. Phantom Photon educated me on the 'efficiency' factor of the LEDs, and that wattage is not the predictor of brightness with all the recent developments in LED technology! The 4 watter throws one heck of a beam from a three inch reflector several hundred yards. I have many inexpensive LEDs, and buy them often...almost like a junkey. They seem to have improved the last few years in leaps and bounds. I intend to finish a reflector that I recently designed, that will actually use most of the light from a typical forward firing LED and place it into the beam, and not have a "shadow" or waste any of the light.
LightSward
Jared
Reason: clarifications
03-23-2009, 07:48 PM
 I'm usually computer literate, but sometimes I end up duplicating an effort when I am frustrated  by a simple task such as posting photos. I actually intended to put this in the Homemade section...
I'm new to CPF, How do I contact a Moderator to move this or eliminate it?
LightSward
Reason: Clarification
03-24-2009, 08:06 AM
Re: 24 inch homemade reflector
Very cool design! This has given me some ideas, thanks for sharing!
03-24-2009, 10:34 AM
Wow - I'm impressed.
__________________
Homebuilts - "BREEZE" RCR2 sidexside, "Tornado" 4 x 18650 side x side, Streamlight SL20x LED module (under development)
03-24-2009, 07:38 PM
Its a little vague in the thread, but I think you made a 24" Homemade parabolic reflector searchlight called lightsward?
Ha ha ha, just messing with ya! Nice work and looks cool!
03-24-2009, 08:14 PM
It was fun to build and I learned much and now have many ideas to try as a result of this effort. When I built the 24" reflector, I made some slight variations in the exact lateral focal plane to allow experimenting with LEDs, and other potential light sources, that may not have quite a zero axis emitting area.
When the 24" Reflector LightSward is finished, it should look something like a giant "HID Cyclops".
I'm experimenting with another, modified, smaller design of the 24" reflector (about 12" size) that when finished, should use almost 100% of the available light from a large LED, using a specially designed off axis parabolic reflector, that with the first test, is very bright and well focused, (about 200 lumens) I haven't had the funds to try bigger.
LightSward
03-24-2009, 11:10 PM
Thank you for sharing your work. As I said in the other thread you needed to contact a moderator to get them to move the other thread not start a new one. This is called cross-posting and is not allowed on CPF.
__________________
03-24-2009, 11:23 PM
Originally posted by saabluster:
saabluster
Nice work on your light by the way, I took a look at your site.
 I'm sure it is easy...but how do I contact a moderator to move the extra threads?
Reason: quote / smileys
03-25-2009, 12:14 AM
When you go to the forums if you look down at the very bottom and right you will see the respective moderators. In this forum it looks like this. js, DM51, Radio, Robocop
How did you find out about my site? Your not supposed to know about my site. It was done some time ago and is woefully out of date. I have not intended for it to be known as I don't do business on there and all the information on my light is here at CPF. Oh well.
__________________
03-25-2009, 12:25 AM
I sent a message to a moderator. BTW, I meant your post on CPF: DEFT and the Black Tie, not your original web-site. Thank You for helping me with the posting issues.
03-26-2009, 12:50 PM
I have been in contact with a moderator, about a resolution.
03-28-2009, 06:22 AM
Do you have any interest in putting up tutorial on how exactly you make these reflectors? I for one am curious. I should mention that this business with sprinkling underlines and boldface through the article should be used sparingly so as to not distract from what you are actually saying.
03-28-2009, 02:14 PM
Quote:
Yes, I am interested in putting up a tutorial. I will begin placing one shortly.
Thanks for the advice on the appearance of my article.
Thank You
LightSward
Jared
03-28-2009, 11:33 PM
 The 24 inch reflector searchlight (LightSward) makes a nice beam spot on the clouds above. (here in Portland, Oregon the clouds are often only one to two miles above ground level).
I will be building several more 24 inch reflectors and experiment with different methods and techniques. I plan on increasing the tolerances of the final reflector sub-layer.
LightSward
03-28-2009, 11:34 PM
As budget allows, I will also start 'spinning' my own reflectors out of steel or aluminum.
Soon, I will begin a tutorial on; several design and construction methods for constructing parabolic reflectors.
LightSward
Reason: Additional thoughts
04-17-2009, 02:00 AM
Reason: arranged photos and text
04-17-2009, 02:41 AM
Soon: I'll show the design, layout, cutting and lamination of the rigid foam frame.
04-22-2009, 01:34 AM
I've just purchased a 400 watt metal halide lamp and ballast kit. I'll be hooking it up and installing it into the 24" reflector, replacing the successful 100 watt HID lamp. I'll do this the next couple days! I'm excited to see the results! The issue is the arc area of the 400 watt HID is twice the size as the 100 watt HID arc. The 400 watt arc size is about twice the size of the carbon arc on the big 60 inch searchlights. I don't expect as focused a beam, but it should still be a respectable two mile beam. I'll let everyone know with in the week.
Reason: updated info
04-22-2009, 01:37 AM
400 watt HID works very well.
Reason: erased duplicate
04-22-2009, 02:29 AM
Hey that is some really cool work. Almost no one ever thinks about trying to make their own reflector, especially not the way you went about it. As far as I can tell in your shots, there is no significant artifact issues which seems almost impossible, given the visible strips. Can you verify that result on a practical basis, or is the camera just not capturing the artifacts?
Again, big kudos for making something like this from scratch! It is what is the best about modding, and why
04-22-2009, 07:24 AM
Moderator
I've merged your 2 threads about this and deleted the 2nd version of your opening post. As pointed out by others, cross-posting is not allowed.
Having got that advisory note out of the way - this is superb! A fascinating project, and it looks as if it works very well indeed.
You should get some excellent throw from such a big reflector - it would be very interesting to see it lighting up some distant targets, at 500 yards or more, compared to other big lights.
I completely agree with LuxLuthor - it's ideas like this that make CPF the great place it is!
__________________
DM51
04-22-2009, 11:12 PM
It was fun and I have several more, homemade reflectors, I'm working on. The artifacts actually came out to a minimum, I'm just as surprised. I really did not think the beam would be as nice as it is.
I am currently changing out the 100 watt HID for a 400 watt HID with a slightly larger arc area. Hopefully the beam will be somewhat as focused as it was with the 100 watt HID.
04-22-2009, 11:25 PM
Thank You for taking care of the threads.
I will get the reflector out where I can light a row of trees that are about 500-600 yards away from my home. With all the Spring leaves coming out now, on the trees around my home, I will have to get a little creative. for portability; the 100 watt HID can work off the 12 volt system of my car or a "Cyclops" battery, but the 400 watt HID is just a tad too much for standard power converters, etc. Budget, right now, tends to drive my projects, more than I like.
My fantasy goal is to make the "LightSward" 'green friendly' such as with solar power to charge some large batteries, and/or a bicycle powered large generator to supplement the charge. I'll have to look into how to do this.
04-23-2009, 02:08 AM
u are the first to make yr own reflector this BIG !!!!
well done!
i wish i had thought of trying it ... :|
btw, the tape is rated to withstand yr new 400w hid?
04-23-2009, 10:45 PM
Quote:
well done!
 I actually designed and built the 24 inch reflector due to budget concerns...I have little money right now...didn't cost very much in materials...just time.
I am about to test drive the 400 watt HID and may need a small cooling fan just for the reflector material, (the reflector material is CHROME BRITE METALLIC TAPE by: TRIMBRITE 3" x 60" cut 14 inches length then cut into two wedges: 1/2" one end 2-1/2" the other. Takes three or so rolls for the reflector). I Already have a special location to place the fan and ducting, so the fan will not blow air directly on bulb, just onto the adjacent reflector area. ....Here goes....
Reason: Reflector Tape information
04-24-2009, 01:28 AM
Again, this is one of the coolest projects I have seen here in a long time!
04-24-2009, 04:51 AM
Awesome!  The LightSward looks like a bright pro searchlight, (of course not as bright and slender as a 60 inch carbon arc searchlight but...), it has a nice bright beam...though a slightly thicker beam because of the 1-1/4" arc length of the 400 watt (Lowe's 35,000 lumen Sylvania $25.oo bulb), compared to thinner beam from the 1/2" arc length of the 100 watt bulb, (Home Depot 9,000 lumen Lithonia $28.00 bulb)
The 400 watt HID upgrade can be seen nearly two miles away. Has a nice attention getting beam.  (Shines a nice bright, yet small spot on a tree 450 feet away.) Appears about three or four times brighter than the 100 watt HID, and about ten times brighter than the 35 watt HID Cyclops I converted last month.
If I could afford a bulb with a smaller arc length, the beam would be thinner and appear brighter. Still I am stoked!  I might make the LightSward easily switchable from 100 watt mode to 400 watt mode, with hardware that changes easily depending on power availability, etc. (by the way, the 400 watt ballast kit was $60.oo at "Portland Lighting", and the 100 watt light with ballast was $79.oo including bulb...replacement bulb is $28.oo).
I took some decent photos...I'll put them up later today.
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
