Hi, I would ask two questions please:
1) I'd like to know if it is possible to use the Z.Smart Charger (0.5A) for 14.8 V Li-Ion battery Pack (4 cells) with Alligator Clips
with Polymer Li-ion Battery Module: 12v 14.8V 5700mAh (84.36Wh) prewired with PCM .
These are the links of battery charger and battery:
http://www.batteryspace.com/index.as...OD&ProdID=2791
http://www.batteryspace.com/index.as...OD&ProdID=3702
2) Is it possible to use Polymer Li-ion Battery Module: 14.8V 5700mAh (84.36Wh) with a 20W Dichroic reflector halogen lamp?
For my dichroic lamp some years ago I used 2 packs in parallel: Li-ion 18650 Battery: 14.8V 2200mah (32.56Wh) battery module ( Flat) Prewired with PCB:
http://www.batteryspace.com/index.as...OD&ProdID=4270
thanks for your reply.
