CandlePowerForums
Welcome to the Dive Lighting forum on CandlePowerForums!
This forum is for the discussion of lights designed specifically for diving.
Please use the other forums for lights that are not necessarily specific for diving.
Go Back   CandlePowerForums > Beyond Flashlights > Special Application Lighting > Dive Lighting
CPF Only
User Name
Password
Register
FoxFury Fire Helmet & Hard Hat Lights!
Reply
Thread Tools Display Modes
  #1
Old 05-03-2009, 10:12 AM
gav6280's Avatar
gav6280 gav6280 is offline
Default "Cracken" - Quad XRE R2 Build Diary.
So here it is after many, many months of faffing about.....
"Craken" an umbilical style scuba diving light machined from a solid aluminium billet.
Initial idea and design by myself.
CAD drawings by Alex Joyce.
Machining by www.duckworthandkent.net , Precision Engineers.
Technical input and general advice CPF's!
The Spec:
4 XRE R2 WG Led's - http://www.dealextreme.com/details.dx/sku.15943
Quad Optic - http://www.dealextreme.com/details.dx/sku.1915
Custom made 1200ma output Blue Shark Driver - http://theledguy.chainreactionweb.co...oducts_id=1136
O'Rings - http://www.polymax.co.uk/
6mm ploycarbonate sheet for lens - http://hub.shop.ebay.co.uk/
Will have a 3 cell Lithium polymer battery pack 5000mah- http://www.swanghobby.com/product.ph...&cat=14&page=1
So here's the good bit:
I am now going to send this off to a friend to be anodized in a heavy coating of matt black, whilst i build up the electronics.
As you can see this is just the head unit at the momment i am still formulating a plan for the battery cannister.
I would like a piezo switch but have no idea how to implment this?
I am hoping this design will surpass 100 Meters depth testing...
__________________
SureFire TR-Q5, Peli Nemo 8C, 4 XRE DIY Can Dive Light, DX P7 (the ugly) Dive Light, Fami P7 conversion, 3 x UltraFire W200.
  #2
Old 05-03-2009, 10:15 AM
gav6280's Avatar
Default Re: "Cracken" - Quad XRE R2 Build Diary.
Reserved.
__________________
  #3
Old 05-03-2009, 01:59 PM
Packhorse's Avatar
Packhorse Packhorse is offline
So whats the beam angle of the optics like?
__________________
Dive lights by Packhorse
  #4
Old 05-03-2009, 02:19 PM
steve6690 steve6690 is offline
I've tested that optic with 4 x Q5's and it was surprisingly good. It gives a nice narrow hotspot with a fair amount of spill. 4 of the cheapo 18.5mm dx reflectors seemed to throw more light though, with a slightly narrower hotspot. Interesting design though Gav, I think it'll have a bit of a military look after it's been anodised. Are you going to design a goodman handle for it ?
  #5
Old 05-04-2009, 03:34 AM
aljsk8's Avatar
aljsk8 aljsk8 is offline
nice to see it done - seams like ages ago when i did the plans for it
how does it thread together is it smooth? does it have any play?
what about the seal - good?
looks just like the drawings - spot on
should be very nice when its done
did you get the battery canisters machined?
ill keep watching the thread
Alex
__________________
Lights - Not enough
  #6
Old 05-04-2009, 09:00 AM
MrSpock's Avatar
MrSpock MrSpock is offline
Unenlightened
Fantastic! What kind of heat sink you are using?
Are you planning to batch-produce these? I'd buy one or two if they priced reasonably.
Cheers!
  #7
Old 05-04-2009, 10:16 AM
gav6280's Avatar
Quote:
Not totally sure but would guess based on other peoples beam shots at around 8 - 10 deg. I will be sure to post some when it's done.
__________________
  #8
Old 05-04-2009, 10:18 AM
gav6280's Avatar
Quote:
Not got a clue about a handle yet but i think im heading that way, or maybe a simpler stretchy neoprene band.
__________________
  #9
Old 05-04-2009, 10:19 AM
gav6280's Avatar
Cheers!
No plans to yet but it's a possibility in the future.
As for the heatsink im not sure would have to go check the plans but i think it is a 10mm thick solid piece that press fits.
__________________
  #10
Old 05-04-2009, 10:22 AM
gav6280's Avatar
Alex
Thread is very smooth indeed with absolutely zero play in it, but i think they did tweak it a bit from your original drawings.
Battery cannister has not been done as i am still not really sure what to do about switch....
It's not been depth tested yet, im still working out a good way to do it.
__________________
  #11
Old 06-14-2009, 09:57 AM
gav6280's Avatar
Thought i would send it offer for a test in a marine engineers pressure pot and the result:
It leaked!
They made lots of recommendations though.
Put a step in the plastic lens so part of it is recessed in to the main body.
Add an O ring onto the new stepped part of the lens.
Remove the inside O'ring inside the top of lid piece.
Machine down main body front face O'ring groove so more of the O'ring is exposed
Reduce height of front lid section so as it screws down really tight
Thicker diameter O'ring on main body threaded section.
Dam what a pissa, and a major setback.
__________________
  #12
Old 06-14-2009, 12:38 PM
Packhorse's Avatar
Bugger.
Oh well just think how good it will be once its finished!
__________________
  #13
Old 06-14-2009, 06:04 PM
Flo1 Flo1 is offline
That's very disappointing!!
Did they say what pressure it leaked at?
  #14
Old 06-14-2009, 06:13 PM
gav6280's Avatar
Yeah it got to 26 Meters. Im looking to get it to past 100.
__________________
  #15
Old 06-14-2009, 06:24 PM
It's a real PITA when things don't go as they should!
What oring material are you using and are they thick enough?
  #16
Old 06-14-2009, 11:33 PM
Lumenz's Avatar
Lumenz Lumenz is offline
Is this light called the "Cracken" or the "Craken"?
__________________
  #17
Old 06-15-2009, 01:43 AM
SUBjohan's Avatar
SUBjohan SUBjohan is offline
Quote:
Is LiPo such a good idea
what happens when you get a leak and saltwater creates a full short circuit over your LiPo pack. I mean pressure build up in a closed enviroment is deluxe.
I would go for LiMa or nihm.
Greetz Johan
__________________
Live while you are alive!!
How to mod a W200 divelight
Building "my ultimate" divelight
  #18
Old 06-15-2009, 01:47 AM
DM51's Avatar
DM51 DM51 is offline
Moderator
Quote:
Kraken.
__________________
DM51
  #19
Old 06-15-2009, 02:51 AM
Sorry to hear this bit of news Gav. I wouldn't take too much notice of the recommendations though. I use a commercially designed head with just one o ring and it's rated to 150m. You've seen pics of my other head design which is a very similar config to yours. Testing of that head is going fine. Its done 50m without a problem. What specification is the o ring that the "glass" presses against ? If you want to have a look in the flesh at either of the heads I have just let me know. They're both completely different designs so you might find something you like
cheers
steve
  #20
Old 06-15-2009, 03:03 AM
J.D.'s Avatar
J.D. J.D. is offline
Greetz Johan
+1 on that...
or LiFe
__________________
  #21
Old 06-15-2009, 03:18 AM
gav6280's Avatar
Cheers steve i think i will definatly have a go at beefing up the O'rings and putting a step in the lens though.
__________________
  #22
Old 06-15-2009, 03:21 AM
gav6280's Avatar
Greetz Johan
You make sure it's had sufficient testing like im doing now so that it doesn't leak! And when it does the water must have gotten in some how, so i figure the expanding gasses will then take the same route out. Plus the housing is strong enough to contain the pressure anyway.
__________________
  #23
Old 06-15-2009, 05:52 AM
SUBjohan's Avatar
I have build 3 dive lights from scratch now none of them have leaked (all have been tested to 10bar) my light have made >100 dives, but 1 thing is for sure one day they will leak. In my opinion all dive lights will one day leak comercially or diy.
It is possible that the expanding gasses put the O-ring back in place so that the gasses are trapped again
I did not do the math on this one but if I see the movies about LiPo on fires the pressure insdie a small canister must be enorm >10bar.
Greetz Johan
Sorry for my poor english
__________________
  #24
Old 06-15-2009, 06:22 AM
gav6280's Avatar
If you have already built 3 lights, lets be seeing them,time to show them off i think.
__________________
  #25
Old 06-15-2009, 06:40 AM
Greetz Johan
One solution would be to use an overpressure valve set at 0.5 bar. I think I've seen a light with this feature somewhere on a German web site.
  #26
Old 06-15-2009, 07:45 AM
SUBjohan's Avatar
I am not trying to hijack your thread nor am I trying to upset you, if I did then I am sorry for this. I am only trying to give some advice.
Ok my first light is out of my hands so no pics for this one (I sold it).
canister style 50W halogen
14,4V 5Ah battery pack
2nd light I made (and my current)
Canister style 24W HID
14,4V 10Ah battery pack
Head is Type II anodised (did it myself )
Switch reed contact / BUZ11 combination
3rd light was for my girlfriend
Canister style 3x SSC P4 driven @ 1A
14,4V 2,8Ah battery pack
Switch is a reed contact / BUZ11 combination mounted in the head.
Later also a goodman handle was added.
I have some new plans for more divelights
Greetz Johan
__________________
  #27
Old 06-15-2009, 07:49 AM
SUBjohan's Avatar
I know this thing you can buy it here it is called Überdruckventil and costs €17,- I think that is a lot of money for something you should not need.
Greetz Johan
__________________
  #28
Old 06-15-2009, 03:01 PM
Greetz Johan
I agree. The dive lights I have made require you to open the case for charging. I make Li-ion packs using 18650 batteries with protection pcb and have not had any problems with excess gassing during discharge.
  #29
Old 06-16-2009, 03:44 AM
SUBjohan's Avatar
It leaked!
What kind of O-rings did you used? And what is the compression rate of the O-rings?
In my lights I used simple NBR 70° shore O-rings at a compression rate of 25% this means that a 4mm O-ring is only compressed 1mm maximum.
This means that the grove for a 4mm O-ring should be 3 mm deep and than I usely make it 5mm wide.
The reason for asking is because I think your design is very nice and it should have worked.
Here and here is some intresting O-ring information.
Greetz Johan
__________________
  #30
Old 06-17-2009, 07:15 AM
gav6280's Avatar
Cheers, yeah i agree it all seemed to be going fine...Standard NBR rings.
Going from this : http://www.divelight.co.uk/old.pdf
To : http://www.divelight.co.uk/new.pdf + http://www.divelight.co.uk/lid.pdf
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
