This is a small review of the
NP350S - a flashlight of the new law enforcement series of
PEAK.
I posted the original review in the German flashlight forum and there it is a very little more detailed. I hope, the translation is at least good enough to understand the major part
The NP350S uses a P7-LED with up to 350 lumens in a single mode, it is capable of numerous different battery configurations and protected against cold and hot weather, rain, mud, impact.
size, finish, built quality
The NP has the standard size of 2xCR123 duty flashlights - small enough to carry on your duty belt all the time and big enough to hold it in your hand safely and comfortable.
Compared to Barbolight T04 or Surefire 6P, the NP is just a litlle longer.
The NP is thin and lightweight, but I never have the feeling, that the NP is fragile - in fact, the NP is very sturdy and well built.
On the head there are many cooling fins, these fins are doing a great job. After some minutes constant on, the head is getting very warm. A good thing, because the heat is transferred away from the LED.
The head has an anti-roll design which prevents the flashlight from rolling away.
An optional traffic cone can be screwed into the head.
The battery compartement (standard is 2x(R)CR123 or 1x18650) has no knurling, but grooves (fins?) on it. I was first sceptical about this design, but it does exactly what it should do: even with wet and slippery hands, you have a safe and firm grip, the NP won't slip out of your hands.
the shiny finish looks slippery, but it is absolutely not!
The forward clicky is protected by a delrin-sleeve. You can remove it, if you want. the clicky switch is loud, compared to others, but has a wonderful tactile feeling. It has a rather long travel from momentary-on to constant-on - a good thing, because you can control your momentary light burst, even if you have a lot of stress (room clearing, high risk custody ..)
led
The Night Patrol 350S uses a P7 LED and a small reflector, no optic.
The LED is protected by a unbreakable window (not glas). It is about 1mm thick, this is comparatively thin, a Barbolight or Hellfighter have about 4mm windows.
The front retaining ring can be removed. If unscrewed, a O-ring can be removed to. If so, the window and the reflector will fall out of the head. The reflector is not mounted but it sits loose in the head. It is fixed by the window and the retaining ring.
Good: You can easily change a scratched window.
Not so good: If you loose your retaining ring, you can loose window and reflector, too.
The LED and the head is sealed, so no moisture or dust can neter the electronic components.
Due to the small reflector and quad die LED, the NP produces a flood beam. Used outside, the NP350S reaches its limitations soon. In matter of throw it can't keep up with similar sized duty lights with e.g. Cree Q5 LED.
Used indoors th NP is a real winner. A very bright and wide beam illuminates whole rooms, nothing can hide in the darkness.
The NP350S is best used indoors or from small to medium distances. There you have plenty of light!
power
The NP can be powered by many different battery configurations. Standard is 1x18650 or 2XRCR123. With one 18650 you get about 300 lumen, if you use 2 cells with 6V or more, the NP will run full power with 350+ lumens.
holster
PEAK provides a optional holster for the NP. It is made from nite-ize, has a surdy plastic clip, which fits 50mm duty belts, and you can rotate the holster body for free hand illumination.
The holster holds the NP firmly, but reholstering needs some practice.
According to PEAK, the Surefire V70 holster can be used, too.
conclusion
Peak's Night Patrol 350S was designed for law enforcement use.
It is sturdy and reliable, it will survive the rough use out there.
With the modular system, you can build a flashlight exactly to your needs.
The NP is very bright, but i personally would like just a little more throw.
This is my first PEAK flashlight and for sure not the last one!
The garage is about 25m. All camera settings are manual.
*control*
*Barbolight T-04, SSC P4, 1x18650*
*Hellfighter X-15, lumensfactory D26 LED 3,7V, 1x17670*
*Surefire/Solarforce lego, Malkoff M30W, 1x18650*
*Barbolight T-15, 4xKLC8, 2x18500*
*Barbolight T09 SE, P7LED, 2xCR123*
*Night Patrol 1x18650*
*Night Patrol 2xRCR123*
Michael
