CandlePowerForums
CPF Only
User Name
Password
Register
PEAK LED Solutions
Reply
Thread Tools Display Modes
  #1
Old 06-30-2009, 08:48 AM
Neondiod Neondiod is offline
Default Same Watt bulbs differ in lumens for different voltage?
Hello CPF!
I've search the forum and read it quite a lot but never get to answer this question: Why do the same Watt incan bulbs have different lumen output for different voltages?
Ex 1 : A 20W 12V G4 bulb is rated 290 lumen, but a 25W 230V G9 bulb is only rated 190 lumen.
Ex 2: A 100W E27 120V bulb has higher rated lumens then a 100W E27 230V bulb.
Thanx in andvanced, great forum.
  #2
Old 07-01-2009, 08:34 AM
holiday light express holiday light express is offline
Default Re: Same Watt bulbs differ in lumens for different voltage?
Different manufacturers... no UL regulating what they put on the box... different housing design...
  #3
Old 07-16-2009, 05:06 AM
Quote:
Same manufacturer ofcourse. But a G4 and a G9 housing is quite a differ on the housing and the filament is totally differ and that's maybe why the light output is less with the higher voltage bulb?
Infact a 100W 230V bulb draw 0,44A and hence shall the filament give a resistens of 525 ohm. Where a 100W 12V bulb draw 8,3A and the filament is only 1,45 oms resistens. The low resistens filament is smaller and maybe better material and hence more effective.
  #4
Old 08-10-2009, 03:27 PM
ponygt65 ponygt65 is offline
That is incorrect.
A 75A/CL/130V lamp listed in OSI catalog as such:
@ 130V = 750 hours, 1190 lumens
Same lamp:
@ 120V = 910 Lumens, at 1875 hours (approx. 66 Watts).
This is due to filament resistance.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
