CandlePowerForums
Go Back   CandlePowerForums > Beyond Flashlights > Transportation Lighting > Bicycle
CPF Only
User Name
Password
Register
Surefire at Battery Junction
Reply
Thread Tools Display Modes
  #1
Old 08-15-2009, 12:27 PM
jawnn's Avatar
jawnn jawnn is offline
Question Ultimate trike light
I have been looking for a good bright LED head light for my trike for a half a year. I finally learned enough to ask the right question and was directed to the vision x lights, they seem to be the most light for the watt per dollar. They don’t seem to have a reflector but the 15 degree Euro beam width is better than the flash lights. The weight is about 4 lbs but that does not bother me.
Now I want to know if there is any better per dollar?
__________________
Rude replys are not welcome here.
http://commutercycling.blogspot.com
  #2
Old 08-15-2009, 01:12 PM
John_Galt's Avatar
John_Galt John_Galt is online now
Default Re: Ultimate trike light
What model were you looking at? I assume by ~4lbs. that you mean the Solio model... Vision X seems to be the best lumens per dollar light system out there (in off-road LED lighting, anyhow).
But please define what you mean by "better" per dollar. More output, less weight, less power consumption, better beam pattern, etc.
__________________
Murphy's law: Anything that can go wrong, will.Murphy's Extended Law: If a series of events can go wrong, they will do so in the worst possiblesequence.
  #3
Old 08-15-2009, 04:18 PM
znomit's Avatar
znomit znomit is offline
Best light for the money is the magicshine P7, get it from GeoMan as it comes with a decent warrantee.
http://www.geomangear.com/index.php?...roducts_id=138
90$, 3 hrs on high. 38 for an extra battery.
If you do get it please post detailed reports in all of the dozen threads you have started on this topic in multiple forums over the last few months.
__________________
My LED Bike Lights:
A few Dynamo builds, Dual bflex road, Quad bflex MTB, Very small lights.
  #4
Old 08-16-2009, 12:58 PM
tiny68300 tiny68300 is offline
Unenlightened
znomit is right on, the chinese made light is the best for the buck. Buy two and for $170 US you get an unbeatable setup unless you build your own. I built a dual MCE light for my trike, and love it, but with the driver, emitters, charger and battery, I spent about $200. I think mine is significantly better, and more customized to my trike, but if I were to buy a set, I'd go with the Magicshine P-7's.
My trike lights
  #5
Old 08-17-2009, 11:11 AM
jawnn's Avatar
Naughty much better
This does look much better.... but is there any hidden falts????
__________________
  #6
Old 08-17-2009, 11:25 AM
jawnn's Avatar
Unhappy building
so far I have not seen exactly how to build thse things with out much trouble...or at least a shop, with machine tools.
Quote:
My trike lights
__________________
  #7
Old 08-17-2009, 12:23 PM
Unenlightened
Default Re: building
Understood, but I built mine with only a drill press and a chop saw. If I had only a hacksaw and a handheld drill, I could still build it. I don't have a mill or any machine tools. It's more a matter of figuring out what materials are available that need minimal modification.
The bodies are simply 38mm inside diameter aluminum tubing from onlinemetals.com, cut to length, closed on one end by a 20mm thick slug cut from 38mm diameter aluminum rod (also from onlinemetals) that also acts as the mount for the led and the heatsink. Easy-peasy. No shaping or sanding or milling or much of anything.
  #8
Old 08-17-2009, 02:10 PM
znomit's Avatar
Bikeled.org
__________________
My LED Bike Lights:
  #9
Old 08-21-2009, 11:36 AM
jawnn's Avatar
Christo Pull Hair Voltage regulator
well I got crazy and sent for one of the geoman magic lights, then later realized it doesn't have a voltage regulator...so does that mean I need one?
__________________
  #10
Old 08-23-2009, 10:09 AM
Linger's Avatar
Linger Linger is offline
iirc, the goe whatever is the same as dx p7 bike like, which Ktronic dissected and reported on here:
http://www.candlepowerforums.com/vb/...d.php?t=232163
Key point for you - heatsinking was horrible stock. You've got to reassemble it with a proper thermal path between the p7 and the heatsink, and improved path to casing would help too.
__________________
Let go of the mouse, go build: A triple Rebel__100, Linger's warm tint rendition of the famous Moddoo__ triple__ xpeOr a Luminus -50 thrower
  #11
Old 08-24-2009, 10:09 AM
jawnn's Avatar
Question HEATING?
The Geoman Magicshine lamp is much better than I thought, it even has a flashing mode for city traffic. And the light does not dim with battery usage.
As the voltage gets too low for the safety of the battery the tail switch color changes to red. However the switch cover looks like it is not waterproof.
The beam is a bit smaller than I would like and I think I need one or two more of these, one 15 degree beam flanked by two 30 degree would be the best.
The lamp head is smaller than the photo shows it, but that s a good thing. The instructions say that there should be 40% of “state of charge” for long storage. Does that mean I need digital volt meter?
It does get hot....possably too hot......
is there a conductive ointment? how can I fix this?????
I will try to open the light when I get home and look at it.....
__________________
  #12
Old 08-25-2009, 10:37 AM
jawnn's Avatar
Default Re: HEATING?
I don't think there is a problem with getting the heat to out side, but there is a problem with getting enough heat off the out side.
The head weighs only .5lbs (vision X weighs almost 4lbs) and it gets so hot that I can't hold it or more than a few seconds.
This may not be a problem in the winter while I am moving, but I sure can't use it as a work light.
__________________
  #13
Old 09-08-2009, 11:29 AM
jawnn's Avatar
Question Confused out of my mind
Even with all the tidbits of info I have gathered from other theads I still don't know what I want...and this data base doesn't help very much.
http://www.candlepowerforums.com/vb/...d.php?t=176131
Is all this true???
Depending on the your speed you will watch the road at different distances. I ride slow and watch the road at about 20ft.
The SST-50 with an OP reflector 20 degree beam and defuser lens to reduce the rings would be the best lite for me. But some wouold need a "thrower" beam found in the flashlights.
The SST-50, XP-G, XR-E, and XP-E leave no black hole in the center of the beam unlike the SSC-P7 and MC-E LED's.
So I think I want a light simular to the Martin lamp but with an SST-50 to eleminate the dark spot.... and coolling fins because it may make more heat?
__________________
  #14
Old 09-08-2009, 05:14 PM
znomit's Avatar
Default Re: Confused out of my mind
I run less light with this on fast twisty mountain descents on 25c tyres.
With an MC-E light and three wheels you shouldn't be having problems riding at speeds up to 30mph. Lots of guys use less light on MTB trails.
What exactly is the problem you are trying to solve?
__________________
My LED Bike Lights:
  #15
Old 09-17-2009, 01:30 PM
jawnn's Avatar
Question “hallelujah!” I see the light!
gosh its hard to learn about these lights. I was thinking that I could use three of the SST50's at half power to get 1500 lumins with out the heat problem.... now I see there is an even brighter LED: the SST-90!!!
And now even more? bridgelux C2000 for 3300 lumins, obviusly only good for motorized trikes.
http://www.candlepowerforums.com/vb/...d.php?t=242015
My ideal lamp would be 3000 lumens over a double wide beam to 30ft ahead (the wider the beam the less bright it is) then a longer beam to 75ft ahead, all driven at low enough power to not exceed 120 degree f ???
Three XP-G http://www.candlepowerforums.com/vb/...d.php?t=244110
I want to use two Martin lamps (martin-led ) with sst-90’s for efficiency but may need to settle for SST-50’s. Or build my own array.
Large batteries that will run the electric motor I am going to drive my trike with will power all this.
Battery packs http://www.candlepowerforums.com/vb/...68#post3116168
__________________
  #16
Old 09-21-2009, 02:12 PM
jawnn's Avatar
Exclamation beam shots
finally some good beam shots http://fonarevka.lux-rc.com/
__________________
  #17
Old 11-30-2009, 01:19 PM
jawnn's Avatar
Question Rain proof lamps
Warning! The Chinese light is not totally waterproof! It’s been raining so much that a friends Nite Rider light similar to it shorted out. I wonder how many other lights are not waterproof.
__________________
  #18
Old 11-30-2009, 08:30 PM
Linger's Avatar
Default Re: Rain proof lamps
Where are you at presently with this project?
__________________
  #19
Old 12-24-2009, 06:32 PM
Capo_au Capo_au is offline
You may find this of some interest.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
