CandlePowerForums
CPF Only
User Name
Password
Register
Reply
Thread Tools Display Modes
  #1
Old 10-24-2009, 02:41 PM
Mike cz's Avatar
Mike cz Mike cz is offline
Unenlightened
Arrow 3444 lm red "light"
To finish secondary school(in nineteen years), I made timekeeping. Timekeeping is to use fire sport. Each timer is running independently.
For example this video (this is a night competition), but it is not my timekeeping. Segments are not bought, but laboriously soldered to the PCB! Digits are attach on a black
chipboard (cheap 5$, plastic board 50$/m). Display frame(casing) is made of two pieces of 2,5 mm metal plate into the U and welded together.
On the edge is screwed Al profile. Lacunae are paste together silicone => rain resistant.
Technical parameters:
Digit height: 255mm (10")
Display Dimensions: 102x70x5cm (40"x 27,5"x 2")
Number of LED in the digit: 56 pieces
The total of LED in the display: 574 pieces
LED type: SSC HR310(6 lm/70mA, 10cd)
Light flux: 3444 lm (the current 10A)
Candle-power: 5740cd (the current 10A, cca 5740lx/m)
Power: 12V(7,2 A), 14,4V(10A)-max
=>This display is visible in direct sunlight without any problem!
Photos are very large,but I do not want to shrink photo.
Control:
I bought a metal box and I made the necessary holes in the box. I soldered the necessary circuits.
Start Timekeeping:
-blue button or
-IR sensor or
-microphone
Stop Timekeeping: the signal from the magnetic contacts, that are located elsewhere (in the target, at the end of the runway).
IR sensor, a microphone ....
For more information on the Czech forum http://forum.fotonmag.cz/index.php?s...t=40#entry8211 on 6/1/2009(in Czech) or in my documentation (only in Czech)
__________________
I made Romisen, 4500lm!
  #2
Old 10-24-2009, 03:39 PM
apontes's Avatar
apontes apontes is offline
Default Re: 3444 lm red "light"
Quote:
You'd better resize them, or they will end up removed...
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
