CandlePowerForums
The name of this forum was changed from "Modder's B/S/T" to "CPF's Custom & Mod B/S/T" in order to include custom items which are not necessarily flashlights but are flashlight related.
In addition, sales and auctions are not limited to the creators of items. If you own a custom item or mod, it can be resold here at a fixed price or auctioned off with a portion of the proceeds donated to the CPF coffers.
This forum is NOT for Give-Aways!!! Please use the CPF Auctions, Give-Aways & Fund Raisers forum at the MarketPlace for such events. Be sure to read the policies of that forum before attempting to start a new thread. Do not start a thread in this forum expecting it to be moved there. Regardless of how far the thread has progressed or the intent of the thread, it WILL be deleted!
Please contact Greta to set up auctions and to agree on what portion will be donated to CPF. We would like to keep auctions spaced out so as not to have too many going at once which could possibly effect the amount you could get for your auctioned item. Any questions can be directed to Greta's email... sasha@candlepowerforums.com .
Please also note that you are not allowed to bump a sales thread more than once per day.
Go Back   CandlePowerForums > Custom & Modified Flashlights > CPF's Custom & Modified Flashlights B/S/T
CPF Only
User Name
Password
Register
Led-Replacement
Reply
Thread Tools Display Modes
  #1
Old 11-15-2009, 03:39 AM
nailbender nailbender is offline
Default XPG modules plus SST-50 -90 & MCE/P7 P60 dropin Modules for Sf product (part 4)
PART 4 !!! P60 Style Custom Drop - in modules for SF and other Products. (part 3 can be found here)
Here I am offering P60 Style drop ins, they are available with Leds from the following manufacturers with some of the leds that will be offered are below.
SSC Seoul
- P7 , P4
Cree - MC-E , XP-E, XRE , UV THE NEW XPG are here
Osram - Diamond Dragon , Golden Dragon Plus, GDP IR/ Ostar IR
Luminus - SST -50, SST -90
Nichia - UV
K2 TFFC
Rebel
Ledengine- UV
Please refer only to part 4 for prices and current selections.
These modules will fit any flashlight that accepts a standard P60/D26 Style module.
IF a host is needed here are some great hosts by Five Mega to look at (HERE)
Here are some pictures of a couple of modules
Here is one of the emitter in the base and converter board
View of the module from the top and typical beam shot
You can still see a bit of a doughnut hole in this picture but most of the time we can focus all or most of it out.
This is a picture of the new reflector made for the Cree XPE & XPG This gives a very smooth and concentrated hotspot.
All of the modules end up being as close to standard length as possible The large die leds are much thicker and there is a small possibilty that there will be a crack at the head and body. I keep all as short as possible so if there is a crack there is probably nothing that can be done.
All hosts are slightly different and one module may fit tight in a SF product and a bit loose in a FM Nite clone or an FM C but they will fit all. One may have to have the spring cut down to allow the head to close more or a whole spring may be needed to keep the module from rattling.
Here are some of the modules that can be purchased with some of the configurations.
Most LED's are carried in Cool White, Neutral White, or Warm white. Please ask if available for your led.
ALL LEDS BELOW ARE STOCKED
Seoul P7 $65 -
3.6v - 6volts /1- 3 or 5 levels /Cool or warm tint
Seoul P4 $ 30 - 3.6 - 6 volts (14V?) 3 or 5 levels/ Neutral White
Cree XRE - XPE - $30
- 3.6 - 6 volts 3 level/ 3.6 -8.4V 5 levels / XPE R2 available in Cool / neutral (Q4 5B) and warm tints plus new XPE Green , Red
Cree
XP-G R4 -$35 C1 tint Cool white only / 3-6volts 3 levels / 3-8.4volts in 5 levels.
Cree MCE $ 75 - 3.6 - 6 volts/ 1 - 3 or 5 levels / Cool - Neutral - Warm bins
Cree UV XL 7090 $45
(395nm) 3v-6volts /1 level
Osram Diamond Dragon $40 - 3.6 -6 volts / 1 level / Ultra White and WARM WHITE/True Green / Red
Osram Golden Dragon Plus $40 -3.6 - 6 volts -/ 3.6 - 8.4v 5 level only/3 or 5 level/ Ultra White, White, Warm White tints
Osram Golden Dragon IR $40 (850 & 940nm)-3.6v- 6 volts /1 level
Osram Ostar IR (850nm) 9-12 volts 1 level
Luminus SST-50 - 3.6 -6volts /1 - 3 or 5 levels / Cool White
(PM for Quote)
Luminus SST -90 - 3.6 -6 volts /1 - 3 or 5 Levels / Cool White / 5700K neutral- Green - Red(PM for Quote)
K2 TFFC - $40 - 3V- 6 volts / 1 level / Cool White - warm white
Rebel - $30 -3v-6volts /3 and 5 levels /cool white , neutral white
Nichia UV 365nm (PM for Quote)
Ledengine UV 5&10 watt 405nm14 volt 1 level
These are very powerful quad based die that are made for curing adhesive. I also offer one that is part UV part Dental Blue that is a professional led for curing adhesive for the dental industry. These are in the Nichia price range. (please PM for quote)
ANY MODULES LISTED AS 6 VOLTS MAX CAN NOT BE USED WITH LIFEPO4 BATTS. THERE HAS BEEN TOO MANY PROBLEMS WITH THESE BATTS AND PROPER CHARGING METHODS. WARRANTY WILL NOT COVER BOARDS BURNED UP BY USING THESE BATTS.
I am sorry for any inconvenience it has caused.
Low power special. I have a new driver that is a boost driver and works with XPG quite well, I can now make modules that will work full power with a AA battery or 1Xcr123 primaries.
I try to buy and test the newest bins as they come out such as R4 flux bin 1C tint in the XP-G or R2 flux bin WD tint in both XPE and long throwing XRE or the new Luminus products SST 50 or SST 90
I have Neutral whites for most of the leds I stock including Q4 5B in XRE and Q3 4C , 5B in XPE. I also have neutral whites in MCE with Kbin 4C & 5B. Don't forget UBin P4's
I also have a wide variety of Warm whites in stock from most manufacturers. Plus high CRI led's are available
I have LOW POWER modules for long running leds. These are a great substitute for Incan lovers who want more runtime and a bulb that won't burn out. They even have incan tints.
If you have 3P one cell lights that are your favorites I have great long running lights with buck boost converters that will give some of the longest run times you will find in lights like XRE, XPE, GDP.
Just remember if you don't see it or don't understand something just write and I will
help.
Please specify what host and batts you are using when inquiring about a module or led. There are many driver configurations and the change regularly as demand changes.
IN NEED OF A HOST HERE ARE TWO GREAT FORUM MEMBERS THAT CAN HELP
On marketplace get Fivemega 18mm Bodies in 5 Sizes
Jason will be glad to help you with these great hosts
When ordering please post your order in the thread plus put details of order and address in PayPal notes. Also please list CPF Nickname in paypal notes. paypal has been bad lately about not sending shipping addresses please make sure it is listed in paypal or in paypal notes.
MY Paypal info in biography or PM for.
Credit card users please add 4%
When funding with cash please use personal tab and gift as the option.
Beam shots are posted below and new products will be posted below.
I will also have a spot for users to post beams shots or better yet links to beam shots
D36 for M STYLE lights are (HERE)
Here on BST get Five Mega 1 & 2 X 26500 host (Here) These are some of my favorites
On marketplace get Fivemega 18mm Bodies in 5 Sizes Here
Jason will take care of you.
__________________
  #2
Old 11-15-2009, 03:40 AM
Default Re: XPG modules plus SST-50 -90 & MCE/P7 P60 dropin Modules for Sf product (part 4)
New Products
Linger Special, this is a module that was conceived through member Linger. Out north of the border friend asked me to put 2 XP-G leds on a 10mm board side by side. So I was somewhat worried about heat and the small board and becuase of design of the board and extra mass I went with a 14mm board.
These are mounted side by side on one board and they work perfectly.
They produce 510 lumens out the front of floody yet very bright light. There is a small doughnut hole in the beam pattern on the wall but little if any is noticed outside.
This has become my wifes new light of choice. As she says I want the bright one.
Wild looking are they not.
Price will be $45 and will be using a 2.5 amps 3 level driver which pushes them pretty hard.
Dave
New Low Power Special I now have a good boost driver that will work with several of the leds and with voltages from 1.2v to 4.2v. These will push a XPG at 1 amps on a AA battery. I am going to try it out using a Diamond Dragon and a 16340 as I believe it to power it fine on one cell.
So anyone who has a single AA cell light I have a good driver for it. These also will be great with one primary for pocket rockets.
More on this one later.
  #3
Old 11-15-2009, 03:41 AM
beam shots
SST-50 on left and SST -90 on the right
Warm MCE on Left & Mbin Cool White on Right.
XPE Beam shot / XPE R2 VS Diamond Dragon
XRE R2 VS K2 TFFC Warm / P7 VS XPE R2
P7 beam shot / MCE warm
Red Diamond Dragon on left / Green Diamond Dragon on right
Green SST 90
XPG R4 looks great with very smooth beam in these reflectors
  #4
member beam shots and supplied information by members
If any of you all want to submit some beam shots of your modules PM me and I will post here. Several of you did in the last section and I will try to transfer them in the next couple of days.
MEMBER BEAM SHOTS
Great outside Beam shots from member ELHO showing SST 50 and SST 90 modules in use. This has some great outside shots
http://www.candlepowerforums.com/vb/...d.php?t=247547
Thank You Elho
  #5
Old 11-15-2009, 03:43 AM
These are some Chinese cloned Lamp Holders they fit all C & P Surefire models and most clones I would imagine. I bought some to fill some FM C hosts & FM Nite hosts I had that needed heads, I bought a couple of each while I was getting some.
The quality is quite good I thought. There may be a speck of anno missing where the aggressive flutes and ribs are but very little as you can see by the pictures.
The ribs and flutes should help cool the heads some.
Any bezels you have for your C or P surefire or clones will fit these just like they do any SF product.
Here are pictures, hopefully most detail can be seen since they are black it is harder to show.
Left side I call bottom ribbed and hex shape. Right side is bottom ribbed & fluted
Left side I call top ribbed & fluted (out of stock for one week) is my favorite although may be to aggressive for some. Right side is top view as top is same on all
Here they are on a FM C style host and a 18650 FM Nite host
Prices are the same for any of the three.
Price of heads are $ 30 shipping included CONUS
Any Questions let me know
  #6
Old 11-15-2009, 04:51 AM
bugsy714's Avatar
bugsy714 bugsy714 is offline
What are the driver options for the sst90? The p7?
I am debating if I want another 4.2-6v dropin or if I want to try having you rig a dual cell direct drive sst90
__________________
FS: Surefire C2-HA & 6P Hosts for 18650 Batteries!
Yes that is a flashlight in my pocket but I'm still happy to see you
  #7
Old 11-15-2009, 05:37 AM
elho elho is offline
Quote:
Feel free to also use those that I posted separately here.
__________________
AELight 25W Xenide Class 1 Division 2 // Wolf-Eyes 6AF Sniper R2 WC low Vf
Wolf-Eyes MC-Explorer // SureFire C2 CustomLites SST-50 & SST-90 // Inova T1-MP
SureFire 6P CustomLites Nichia UV & GoldenDragon IR // Jetbeam Jet-µ // Arc AAA-UV
  #8
Old 11-16-2009, 02:04 AM
OfficerCamp's Avatar
OfficerCamp OfficerCamp is offline
Dave, what color temps do you have available for the R4? Anything close to 5000k?
__________________
Who the hell would spend $50 on a flashlight? - My Mother
  #9
Old 11-16-2009, 02:23 AM
Quote:
Hi Chris
These are so new there are few color temp choices, 5000k is quite neutral and I don't know of any being released yet. Now as I say that someone may jump up and say so and so has some but they would be the exception to the rule.
I have the 1C tint which is more neutral than alot with more grey in it than blue.
Dave
  #10
Old 11-16-2009, 02:33 AM
Hi Buddy
I will help you out anyway I can. I will in the next two days have a working 2X18650 in a maglite. PM me and I will let you know how it went.
I just finished a 4D maglite with sst90 and WOW
Dave
  #11
Old 11-16-2009, 11:52 PM
djans1397's Avatar
djans1397 djans1397 is offline
Nailbender,
Hey. I just sent you a PM. Please read.
Thanks,
Dan
__________________
" Trust in the Lord with all your heart... Seek his will in all you do and he will show you the way." Proverbs 3: 5-6
  #12
Old 11-17-2009, 12:03 AM
tropic1 tropic1 is offline
Unenlightened
Dave got the SST-50 and XPG R4. Turning them on inside the house is spectacular on the walls, can't wait to use them outside!!!
Roger
__________________
SF G2/XPG R4 * Mag2C->3x123 * Olight T20M Tactical SE Cree 7090 XR-E Q5 * Romisen RC-N3 Cree Q5 * SF6P SST-50 * Malkoff MD2
  #13
Old 11-17-2009, 01:07 AM
Quote:
Originally Posted by djans1397 View Post
Nailbender,
Thanks,
Dan
PM replied
thanks
dave
Quote:
Roger
glad they arrived safely, I am sure you will enjoy them. Those two are a good compliment to each other.
Dave
  #14
Old 11-17-2009, 02:04 AM
Cat-Man-Do's Avatar
Cat-Man-Do Cat-Man-Do is offline
Unenlightened
Dave,
About your XP-G drop-ins....just wondering...are you over-driving the emitters or is high just 1000ma ? either way, do you have a projected run time for these on high ( before noticeable dimming with standard 2600mah 18650 ). I'm worried that if I run one of these on high for an extended period ( ie...bike helmet use ) that it might damage the LED. I would of course only turn the light on high while moving. Lastly, your xpg drop in is using the R4 bin. How does that compare to the R5's being used by others. ( note: I did browse a bit before asking ...)....Oh, and while I'm at it...same question with the P-7/MC-E drop-ins...can they handle the heat with an extended run time..??
If heat dissipation is a problem, is there a host ( you recommend ) that would work best?
  #15
Old 11-17-2009, 02:25 AM
Quote:
Originally Posted by Cat-Man-Do View Post
Dave,
Hi
I can run the XPG at what ever you want, most of the time we are overdriving it a bit. I use a 1.2 amp driver the most for it with single level being 1.4 unless less is asked for.
I have never had a problem with these running at these levels. They may shorten the led life some but I doubt it much and if they do when rated at 50,000 hours if I loose a few OH WELL there will be something new long before I use up the hours.
At 1.2 you really don't have to worry, but I do have 1 amp if one wants to keep to specs'
Heat will not be a problem with it in most hosts. the only host that might get hot would be like a AA sized light 6P or more no problem
The P7 and MC-E will get hot when left on high for extended periods of time.
One host that I have found to dissipate heat well is FM's 26500 or the new 26650 which would be my choice now.
I often run MCE or P7 or SST 50 for 45 minutes on high and seldom have heat problems with this host. If head is needed the heads on this thread work well with his host.
Back to the leds, you really dont' have to worry about burning out the leds at what I push them at. I have members and friends that use these powered like this for bikes and have no problem on high for extended periods of time.
As for the difference between R4 and R5 lumen wise is about 12 to 15 lumen at best. You would have to have good eyes to tell the difference, now when the S2's come out then there will be an upgrade path.
Thanks
Dave
  #16
Old 11-17-2009, 03:11 AM
djans1397's Avatar
fopr 1 x XPG4 and 1x XRE warmish tint , d26 dropins = $65
Thanks,
Dan
__________________
  #17
Old 11-17-2009, 05:00 AM
guardpost3's Avatar
guardpost3 guardpost3 is offline
nailbender, PM sent about a warm tint drop in, thanks
  #18
Old 11-18-2009, 01:13 PM
guardpost3's Avatar
for one Neutral white (Q45B) 3-Mode drop in
  #19
Old 11-18-2009, 05:13 PM
djans1397's Avatar
Thanks,
Dan
Hi Dave,
I'm sure you're slammed with work, but when will these ship? I was hoping I could get them in time for my buddys B-day next week.
Thanks,
Dan
__________________
  #20
Old 11-18-2009, 05:42 PM
Hi Dave,
Thanks,
Dan
I am trying for tomorrow but with the forum being down yesterday and not being able to get to PM's so it may be Friday.
Dave
  #21
Old 11-18-2009, 06:18 PM
djans1397's Avatar
No worries. Thanks for the update.
Dan
__________________
  #22
Old 11-18-2009, 07:27 PM
Hey Dave,
I just got my D26 SST-50 warm 4000k high CRI drop in, and.... this thing is very cool, as in, the tint is very cool. I think there might have been a mix up with the LED's, 4000k is on the warm side of neutral, and my neutral MCE drop in you just did for me is MUCH warmer. Any thoughts? Could there have been a mix up?
OC
PS: GuardPost3, good to see you are getting into the good stuff!
__________________
  #23
Old 11-18-2009, 09:28 PM
mbrown mbrown is offline
Unenlightened
Dave,
My son, tundratrader, received and forwarded the SST-50 module he ordered for me.
He said it was "the death star" and he was right. It stomps all over my Malkoff drop in.
The throw is awesome and the spill is top notch too. Focus is spot on. No holes whatsoever.
Thanks for the great product and the great service. This gives me a much better idea of what to order for my SF M900 weapon light.
Michael
  #24
Old 11-18-2009, 09:54 PM
Hey Dave,
OC
Every company bins their leds different. Osram 4000 is not as cool as Cree's either . Your MCE warm is 3800 lumen as you did not specify a exact number or tint. The Cree is the same JE6 i have used for awhile.
Luminus's warms have a yellowish tint to it while Cree's a beige for neutral and a rosy for warm.
Osram will range from rosy to beige but all companies bin different and have different specs for warms and neutrals
No mistake different leds
Dave
  #25
Old 11-18-2009, 09:58 PM
Quote:
Originally Posted by mbrown View Post
Dave,
Michael
Hi michael
i am glad it arrived OK and you like it. He told me this was for you and he thought you would love it.
They really are a great led with a great beam profile.
Thanks for letting me know and enjoy it up in tundra land.
Let me know when you get ready to upgrade that weapon light.
Dave
  #26
Old 11-19-2009, 12:23 AM
Gotcha, Dave. Not complaining, just wanted to know the reasoning for the difference in tint. Once agian, a great drop in from a great manufacturer. Fits perfectly in my C2 also. Thanks for the post and the clarification. This thing cranks out some serious lumens too!
OC
Dave
__________________
  #27
Old 11-19-2009, 02:56 AM
Check out the Linger special which is a new product
Just above the beam shots
Dave
  #28
Old 11-19-2009, 11:45 AM
leroy82646 leroy82646 is offline
Unenlightened
__________________
Dave:____________
PM sent RE: RED drop in recommendations.
Kind regrds,
LEROY
  #29
Old 11-19-2009, 07:21 PM
guardpost3's Avatar
Dave
Wow, thats cool, and 510 OTF!
I was buying drop-ins for my hosts but now it looks like i might need a few more hosts for these drop-ins
  #30
Old 11-19-2009, 09:15 PM
outersquare's Avatar
outersquare outersquare is offline
heh you should try cramming 3 XPGs into one reflector next...
__________________
"invest in lead and aramid"
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
