CandlePowerForums
CPF Only
User Name
Password
Register
OLight at Battery Junction
Reply
Thread Tools Display Modes
  #1
Old 07-20-2003, 01:54 PM
Hogosha Hogosha is offline
Default What is the brightest H4 headlight bulb?
Hey guys, antone know what the brightest H4 headlight bulb is? Also is H4 the same as 9003? I converted my Vespa to have a H4 but when I went to go buy a bulb (55/60w, preferably the "Blue") got real confusing. Any help?
Defectfully
Patrick
  #2
Old 07-20-2003, 04:08 PM
hawkhkg11 hawkhkg11 is offline
Default Re: What is the brightest H4 headlight bulb?
Yes, 9003 is H4. If you're just looking for sheer brightness, you'll probably want to stay away from tinted lamps, even good ones like Silverstars, as they will reduce the total light output with their absorbing/reflecting tint. I'm thinking you should go for one of those "increased output" lamps like the Sylvania XtraVision or Philips HiVisibility.
  #3
Old 07-20-2003, 05:33 PM
T-Rex T-Rex is offline
55/60
55/100
80/100
90/130
100/150 Never actually seen one.
  #4
Old 07-21-2003, 08:45 PM
Banshee's Avatar
Banshee Banshee is offline
Im running 80/100's in my Caprice SS now. But they are connected via a very heavy duty custom wire harness and emit the light through European spec t84 glass headlight capsules made by GM. Any higher than stock wattages and one risks burning up the headlight wire system and possibly an underhood fire. To avoid those hazards one needs to minimally upgrade the wires to handle the extra load..and also pay attention to the capsules to avoid melting or distorting the OEM plastic headlight capsules with the additional heat generated by higher wattage bulbs..
  #5
Old 07-24-2003, 03:37 AM
DHCrocks DHCrocks is offline
like hawkhkg11 said, if you want maximum brightness don't get a "blue" bulb which has a tinted capsule, it only blocks a portion of the light being emitted, the rest is reflected back within the lamp and the extra heat becuase of this is why they always burn out sooner then a regular bulb. If you go with a higher wattage bulb like 80 or 100W then the output is whiter then the regular 55w and you can get regular "non-blue" bulbs and still get a white output. upgrade you wiring though with new relays and at least 12ga wire.
  #6
Old 07-29-2003, 10:54 PM
lildave lildave is offline
the PIAA super plasma or APC 90/135 I like the PIAA better color.
  #7
Old 08-14-2003, 01:25 PM
Anyone know where to buy high wattage H4 bulbs (non-tinted)?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
