OK, the recent power problems in the northeast have made me look more seriously at one of my "emergency lights" here in my apartment.
As it is, factory stock, it has two 6 Volt, 5.5 Watt, Wedge Base lamps powered by a 6 Volt, 4.5 Ampere Hour Sealed Lead Calcium battery.
The battery is kept charged and healthy by a smart charger built into the fixture. The fixture is designed to meet the NFPA fire codes as an auto-switching emergency light providing roughly 12 Watts of lighting for a minimum of 90 minutes.
My objective is to turn this into a sixteen hour (or more) light (roughly .25A load). (That should be adequate light from this fixture, and it is NOT required to meet code.)
What I'd like to do is to very simply swap out the wedge base incandescents with some much more efficient LED units. You know, *unplug* *plug-in* *done* type of thing.
I've looked about and not found anything like that, so am considering trying to make some using bobby pins, LEDs, chewing gum, epoxy, solder, string and a few resistors ...
Unless someone knows of some readily available "wedge base 6V LED assemblies", I expect I'll be looking at three or four white LEDs (5mm Nichia White) per replacement assembly, a simple series resistor (100 Ohm) for each LED (yes, brute force and not elegant, but reliable design), and maybe a couple of simple home-made PCBs. Overall, letting each LED chew on about 25-30MA should let this work fairly easily.
Any suggestions?
Any "plug-and-play" solutions (replacement assemblies)?
Am I out of my mind? (OK, OK, calm down! Let's rephrase that question: Do you see any problems with this?)
Thanks,
(certified non-fluff) [img]/ubbthreads/images/graemlins/smile.gif[/img]
