CandlePowerForums
CPF Only
User Name
Password
Register
Reply
Thread Tools Display Modes
  #1
Old 09-15-2003, 07:08 PM
NightShift NightShift is offline
Default Tanning with LEDs?
Do such LEDs exist? ...if you had a big enough array of them?
  #2
Old 09-15-2003, 08:58 PM
Steelwolf Steelwolf is offline
Default Re: Tanning with LEDs?
What's the point? At this time, the efficiency of UV LEDs is no where near as good as mecury vapour tubes, and because the UV degrades standard epoxy, the encapsulation has to be made with glass for any decent life, which means that it can't really fit in with current volume production which turns out epoxy encapsulated LEDs, which results in increased costs for the glass stuff or reduced life for the standard epoxy stuff.
To get the output of just one mercury vapour tube would probably mean a hundred UV LEDs and each LED would cost as much as one tube. So unless you're looking for a low powered, battery operated, shock resistant, hand-held tanning device, it just wouldn't make sense to use LEDs. Not yet anyway.
  #3
Old 09-15-2003, 11:25 PM
RevDavid RevDavid is offline
Then again, you could use very small UV leds in direct contact with the skin to create artificial freckles. Or would they be real freckles? Who knows? It could be the next big thing with college students.
David <><
  #4
Old 09-16-2003, 10:21 AM
IsaacHayes's Avatar
IsaacHayes IsaacHayes is offline
*Flashaholic*
you could make a UV tanning wand flashlight so you could tan under and in hard to reach uhm, areas? [img]/ubbthreads/images/graemlins/icon15.gif[/img]
Maybe a bad idea.... hehehe I'm sure someone would buy it though!
  #5
Old 10-01-2003, 08:24 PM
[ QUOTE ]
[/ QUOTE ]
Well actually thats kinda what i meant...not like a big booth of LEDs, like just an area tanner like for your face. Im just wondering would it work with regular UV LEDs?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
