Re: You Know You\'re a flashaholic when ....
You start to really wonder whether you need a $900 HID flashlight.
You spend over $100 for a flashlight, use it once, and begin planning for it's replacement.
You try to explain the significance of Luxeon bin codes to non-flashoholics.
Your battery run-time requirements, which used to be two hours, fall below 30 mins. (After all, you're always going to have another flashlight available and batteries not too far away.)
You start using a flashlight inside when you could simply go over and turn on the light.
