I found
this article describing how it is possible to parallel the outputs on a multi-tube
electronic ballast to drive one tube at increased output. A good candidate for doing this with is Home Depot's very low cost shoplight (SKU # 140904). Using two shoplights it is possible to use each ballast to drive a single tube at about 1.7 times the normal power level. Of course, you have one empty fixture left over, but that can come in handy. Although I put everything back to stock configuration after testing, I did try it and it really does work. I can get ~5000+ lumens out of one of my F32T8 full-spectrum tubes (rated output at 32 watts is 2950 lumens). Input power per tube is about 55 watts, and the tube does get somewhat hotter than normal but still not too hot to touch. This is a great way to save money on tubes if you need a very bright light and don't care about getting rated life. For 110 watts power input you get a shoplight putting out ~10,000 lumens. Tube life
is reduced, but those who made this mod say they have had tubes burning 12-14 hours per day for almost a year with no burned out tubes yet. I would guess life might be cut by half or even two-thirds, but since my full-spectrum tubes are rated for 34,000 hours, they should still last at least 10,000 hours. I've heard mild overdriving(up to 15%) produces no reduction in tube life at all.
