Looks like an interesting project. No need for fancy stuff.
I'd suggest this as a source for your white leds cheap and decent. I've purchased a few thousand LEDs from this guy and he's been great.
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=2594583740
Look at his other items for sale if you want 5000mcd whites or anything else. No shipping charges and he's pretty fast..
What is the space you have available? (How big is the plant around, how tall. How much space for batteries.)
Can you just bury a battery pack in the plant soil? (Use heavy-duty Ziploc bag.)
I did a one-shot thing like this before, where I used shirt cardboard, punched with a small awl, poked LEDs thru and bent the LED upwards, and the backside leads left/right and wired ut that way. Use a 3" high strip of cardboard/matteboard long enuff to run around the inside of the container/pot on edge. Hopefully the bottom at least an inch below the lip. Adjust the dimensions to suit. punch tiny holes near the bottom edge and thread LEDS thru from the inside surface. Bend LED upwards. The excess cardboard above the LED can be your glare shield. Wire LEDs from the outside, keeping the wires/resistors below the visible level.
Trying to keep this on the cheap, by the way. If you leave the leads on the LEDs long, you can easily recover them.
Trying to think of an easy power source. The easiest, if you have room for it, is the 6V lantern battery, cheapest you can find, and wire LEDS for 6V. each LED in series with a 100ohm resistor to the battery. Not screamingly effiecent, but easy, cheap and able to run the time you want for 6-8 LEDs per battery.
If you don't have the room, or have other options for batteries:
3 alkaline C cells would work. Use 33 to 47ohm resistors instead of 100ohms.
6 AA could work. wire LEDS 2 in series, and use a 68-82ohm resistor from each pair to battery.
Bunch of thots from a flu-ey technician.
Good luck!! If you have any electronics students at the school, you might be able to enlist a bit of help. I'd hate to try to build this remotely..
Hope this helps..
Yours, drs off for more Vitamin C...
