03-08-2004, 08:26 AM
AAA Works After 2 Mos lost in a Snowbank, But...
Lost my keyring with Arc AAA in early-January while shovelling snow. The recent warm weather in Ontario finally melted down the rock-hard snowbanks and revealed my long-lost property! [img]/ubbthreads/images/graemlins/grin.gif[/img]
Keyless entry unit for the car was toast, but the Arc fired up right away. [img]/ubbthreads/images/graemlins/bowdown.gif[/img] Was a little creaky turning on, but worked it a few times and lubed the threads - back to normal. [img]/ubbthreads/images/graemlins/smile.gif[/img]
Except, I cannot get the reflector back to its shiny self. [img]/ubbthreads/images/graemlins/icon23.gif[/img] It has that patchy dirty/ dull look when an untreated aluminum surface is exposed to the elements for some time. Did try an aluminum cleaner and Never Dull. Recommendations? [img]/ubbthreads/images/graemlins/help.gif[/img]
Would attach photos of the reflector, but haven't been able to figure out how to attach yet.
Thanks!
03-08-2004, 09:38 AM
Unenlightened
Re: AAA Works After 2 Mos lost in a Snowbank, But.
Hi ssb,
if there's residue of lime inside the reflector you might pour in some vinegar essence and leave it in there for 10 mins (in the reflector, not the light itself [img]/ubbthreads/images/graemlins/wink.gif[/img]). To remove other stains, just use some toothpaste on a q-tip as an abrasive to polish the reflector.
Has always worked like a charm... [img]/ubbthreads/images/graemlins/smile.gif[/img]
03-08-2004, 10:09 AM
*Flashaholic*
be careful about getting stuff on the led dome itself.
i'm not sure how resistant the domes are on the 5mm types, but i got a little bit of flitz on the dome of a luxeon, and it etched it a bit [img]/ubbthreads/images/graemlins/frown.gif[/img] [img]/ubbthreads/images/graemlins/mecry.gif[/img]
03-08-2004, 10:27 AM
maybe you could polish it with a dremel ,use one of the pointy shaped felt bits and some red rouge.
03-08-2004, 10:35 AM
If you plan to polish it, be sure to mask the LED well. The epoxy of the LED is VERY soft and susceptible to scuffing and scratches.
Flitz is softer than a Dremel and rouge, and can be used by hand. Perhaps some flitz on a small swab...
Just be sure to protect the LED. Take Roth's warning to heart. If any polishing compound or grit gets on the epoxy of the LED, it will scratch or cloud the diode.
03-08-2004, 10:36 AM
Glowing admin
Put a straw over the led to protect it. [img]/ubbthreads/images/graemlins/wink.gif[/img] I wouldn't recommend using a Dremel, but go slowly by hand. Worked fine for me, the reflector is like a mirror now. [img]/ubbthreads/images/graemlins/grin.gif[/img]
03-08-2004, 11:01 AM
Hey Beastie, the vinegar didn't do much though Crest on a q-tip seems to be slowly working [img]/ubbthreads/images/graemlins/smile.gif[/img] [img]/ubbthreads/images/graemlins/smile.gif[/img]. Haven't used flitz before, is it some type of polishing compound (get from a hardware store)?
Thanks for the straw idea, Bart![img]/ubbthreads/images/graemlins/thumbsup.gif[/img]
My light now smells minty fresh..... [img]/ubbthreads/images/graemlins/grin.gif[/img]
03-10-2004, 09:50 AM
Fights cavities, too!
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
