CandlePowerForums
Go Back   CandlePowerForums > Custom & Modified Flashlights > Homemade and Modified Flashlights
CPF Only
User Name
Password
Register
Led-Replacement
Reply
Thread Tools Display Modes
  #1
Old 06-05-2004, 09:47 AM
The_LED_Museum's Avatar
The_LED_Museum The_LED_Museum is offline
*Flashaholic*
Default Class 4: The Toylet
Here is my Class 4 entry in the H&M flashlight contest that BC0311 (Britt) started:
The Life Cycle of a Pink Plastic Toilet: Turning a toilet into a Toylet
1: Start with a trip to Right-Aid a few weeks before any Christmas. Pick up their Pink Plastic Toliet piggybank (with digitised flushing sound!), and remove it from the base. Place the base on the floor, and stomp on it with spiked golf shoes until the pieces are small enough to go up the vaccuummnne. Unscrew the cover on the back of the cistern. If the screws are stuck, use a Dremel with a cutoff wheel; if you don't have a Dremel, then drill those suckers out.
Solder up a Luxeon Star /O (I chose yellow for the Toylet) to a length of heavy-gauge zip cord and shove it up through the trap and into the bowl. Be sure the lens pops off the LS at least three times, and gets stuck in the Toylet's trap at least once. If you have deep pockets, be sure to cram it in there so forcefully that you end up breaking at least one LS, so that you'll have to go make up another and start all over.
Yank firmly on the wires until the LS's PCB becomes lodged in the waste opening, thus clogging the Toylet. The LS is now "secure".
Cut some of those colored wires you find in the cistern. Using a 200 watt Weller gun with a broken tip, solder one of the LS leads to one of the wires that looks like its going to the flush handle switch. Solder the other to the battery holder, and solder the remaining switch wire to the remaining battery post. Use plenty of solder; a good rule of thumb is to use 4" to 6" of heavy-gauge rosin or acid core solder per connection. Ensure that the soldering gun slips at least once and burns a hole in your shirt or in the Toylet itself. Be sure to lean in really close and inhale lots of burning flux.
Mmmmmmmmmmmmmm... fluuuuuuuuuuxxxxx...
Tape up the wires, using gobs of black electrical tape. Don't bother with resistors, diodes, or any of those other little colored things with wires sticking out the ends, and don't bother to solder anything else back together unless that's what turns your crank.
Test "flush" of the Toylet before screwing all the pieces back together. Looks like electric piss. At least it has the right color. When affixing the two halves of the cistern back together, be sure you pinch at least one of the wires hard enough to cut it, so you have to go back inside and make repairs.
Finally the vaccume you've alwa.... o wait, wrong infomercial!!
Finally, the Toylet lives!
Beware of the Toylet.
Flush the Toylet.
Fear the Toylet!!!
Stomp on the Toylet!!!
A shot of the Toylet splattering my ceiling with its urine-colored "light".
Important notes:
1: Do not "flush" the Toylet after midnight.
2: Do not expose the Toylet to light.
3: Do not expose the Toylet to water.
If you fail to comply with these three points, the good Toylet will go bad, and come at you with a sharpened plunger handle and a rusty fire axe. Only a silver Duracell can kill the Toylet if this has occurred.
  #2
Old 06-05-2004, 11:38 AM
Icebreak's Avatar
Icebreak Icebreak is offline
*Flashaholic*
Default Re: H&M Flashlight Contest: Class 4 Entry
I'm not sure why, but that kinda freaks me out. [img]/ubbthreads/images/graemlins/eek.gif[/img]
Well it's unique and it emits light.
I like the hinged bezel decrementing loosabilty concerns.
I like it!
  #3
Old 06-05-2004, 11:44 AM
Fitz's Avatar
Fitz Fitz is offline
Priceless! [img]/ubbthreads/images/graemlins/smoker5.gif[/img]
  #4
Old 06-05-2004, 01:27 PM
tvodrd's Avatar
tvodrd tvodrd is offline
*Flashaholic*
No $h*t!! [img]/ubbthreads/images/graemlins/smoker5.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img]
Larry
  #5
Old 06-05-2004, 01:36 PM
BC0311 BC0311 is offline
LOL! [img]/ubbthreads/images/graemlins/crackup.gif[/img] I love it! Best of luck with it, Craig!
You're gonna have to raffle that darlin'. [img]/ubbthreads/images/graemlins/thumbsup.gif[/img]
Britt
  #6
Old 06-05-2004, 02:49 PM
JonSidneyB's Avatar
JonSidneyB JonSidneyB is offline
*Flashaholic*
wow..... [img]/ubbthreads/images/graemlins/eek.gif[/img]
  #7
Old 06-05-2004, 10:59 PM
TheBeam TheBeam is offline
Mr. Museum, that is quite fascinating. Are you going to give it the suction test?
  #8
Old 06-05-2004, 11:22 PM
14C's Avatar
14C 14C is offline
A light for where the sun does not shine...lol.... [img]/ubbthreads/images/graemlins/thumbsup.gif[/img]
  #9
Old 06-05-2004, 11:48 PM
Xrunner's Avatar
Xrunner Xrunner is offline
[img]/ubbthreads/images/graemlins/thumbsup.gif[/img]... is it waterproof? [img]/ubbthreads/images/graemlins/grin.gif[/img]
-Mike
  #10
Old 06-06-2004, 12:14 AM
Atomic6 Atomic6 is offline
Your Toilet Light Stinks [img]/ubbthreads/images/graemlins/wink.gif[/img]-Good job [img]/ubbthreads/images/graemlins/thumbsup.gif[/img] [img]/ubbthreads/images/graemlins/clap.gif[/img]
  #11
Old 06-06-2004, 09:49 AM
SilverFox's Avatar
SilverFox SilverFox is offline
Silver Moderator
Hello Craig,
That is great!!!
Any possibility of making it into a "head" lamp?
Tom
  #12
Old 06-06-2004, 09:56 AM
*Flashaholic*
[ QUOTE ]
[/ QUOTE ]
I don't think it would be a very good idea to suck on a Toylet. It's probably not very water-resistant anyway. [img]/ubbthreads/images/graemlins/icon15.gif[/img]
[ QUOTE ]
[/ QUOTE ]
Very mildly splash-resistant maybe, water-resistant and waterproof no. [img]/ubbthreads/images/graemlins/jpshakehead.gif[/img]
Thank you all for your compliments on the Toylet.
I know of somebody in the UK who could possibly beat the Toylet with his entry of the Merferator Lite, aka the UnSureFire. [img]/ubbthreads/images/graemlins/tongue.gif[/img] [img]/ubbthreads/images/graemlins/blush.gif[/img] [img]/ubbthreads/images/graemlins/tongue.gif[/img]
But I won't spill the beans here...let him come forward on his own, if he dares. [img]/ubbthreads/images/graemlins/wink.gif[/img]
  #13
Old 06-06-2004, 11:53 AM
PhotonWrangler's Avatar
PhotonWrangler PhotonWrangler is offline
*Flashaholic*
Now the ty-d-bowl man won't need a flashlight! Er, flushlight. [img]/ubbthreads/images/graemlins/tongue.gif[/img]
  #14
Old 06-06-2004, 03:36 PM
Icebreak's Avatar
*Flashaholic*
Double post.
  #15
Old 06-06-2004, 03:39 PM
Icebreak's Avatar
*Flashaholic*
[img]/ubbthreads/images/graemlins/hahaha.gif[/img] He said flushlight.
I think we all have a flushlight or two. I'm tellin' ya the lights in the upstairs bathroom burnt out and it was 2 months before they were replaced. EL Tri-Star for showers, MadMax for evening whizzes. Arc AAA for middle of the night trips, flash....'s MicioBigio 4AA 3W DB 800 for the fun of it.
This could almost be a topic, PhotonWrangler. "How many flushlights do you have?"
Flushlight. [img]/ubbthreads/images/graemlins/crackup.gif[/img]
  #16
Old 06-06-2004, 03:52 PM
*Flashaholic*
[ QUOTE ]
[/ QUOTE ]
I have enough spill from a nearby electroluminescent nightlight to be able to find my way around in the bathroom at night, as long as I keep the door open to the hallway.
I guess that counts as a flushlight! [img]/ubbthreads/images/graemlins/smile.gif[/img]
  #17
Old 06-06-2004, 05:05 PM
*Flashaholic*
A "flushlight" would be informally defined as a commercially produced flashlight that's so foul and horrible, it doesn't even deserve to be flushed away.
One such flushlight is right here, another is right here. [img]/ubbthreads/images/graemlins/icon15.gif[/img] [img]/ubbthreads/images/graemlins/smoker5.gif[/img] [img]/ubbthreads/images/graemlins/icon15.gif[/img]
  #18
Old 06-06-2004, 06:46 PM
McGizmo's Avatar
McGizmo McGizmo is offline
Just changing the title here, nothing to see [img]/ubbthreads/images/graemlins/smile.gif[/img]
Where you, flush or flushing? [img]/ubbthreads/images/graemlins/tongue.gif[/img]
  #19
Old 06-06-2004, 08:27 PM
Sigman's Avatar
Sigman Sigman is offline
* The Arctic Moderator *
Default Re: Class 4: The Toylet
Written well Craig! ROTFLMAO! You're a "sick puppy"! [img]/ubbthreads/images/graemlins/grin.gif[/img]
  #20
Old 06-06-2004, 11:30 PM
andrewwynn's Avatar
andrewwynn andrewwynn is offline
*Flashaholic*
good fun, love the descriptions... this is definitely one funky toilight. Hope it's not a model-size meant to be scaled up for actual use [img]/ubbthreads/images/graemlins/wink.gif[/img]
  #21
Old 06-14-2004, 10:21 PM
idleprocess's Avatar
idleprocess idleprocess is offline
Craig wins on description alone - at least a trip to detox for inhaling heavy-duty plumber's solder fumes in quantity.
  #22
Old 06-15-2004, 06:42 AM
NewBie's Avatar
NewBie NewBie is offline
*Retired*
Does it come in Shortwave UV for the sanitizing cycle?
  #23
Old 06-15-2004, 11:54 AM
*Flashaholic*
[ QUOTE ]
[/ QUOTE ]
Sorry, nope. The Toylet produces only urine-colored light. How to clean and sanitise it is up to the end-user.
  #24
Old 06-15-2004, 06:27 PM
3rd_shift's Avatar
3rd_shift 3rd_shift is offline
Great job Craig!
Looks like that project pooped out just fine in the end.
Any plans for a life sized toylet? [img]/ubbthreads/images/graemlins/ooo.gif[/img] [img]/ubbthreads/images/graemlins/yellowlaugh.gif[/img]
A couple of splash resistant flushlights taped under the seat, or placed in an empty bowlclip-on toilet mint holder might work for that. [img]/ubbthreads/images/graemlins/bowdown.gif[/img] [img]/ubbthreads/images/graemlins/smoker5.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img]
Good luck. [img]/ubbthreads/images/graemlins/knight.gif[/img]
  #25
Old 08-01-2004, 09:27 AM
*Flashaholic*
BTTT (Bash Toylet Toylet Toylet)
Seems appropriate for this particular modification. [img]/ubbthreads/images/graemlins/smile.gif[/img]
This "flashlight" won 3rd Place in the H&M Flashlights Class 4 contest. [img]/ubbthreads/images/graemlins/grin.gif[/img]
  #26
Old 08-04-2004, 08:32 AM
Likebright's Avatar
Likebright Likebright is offline
[img]/ubbthreads/images/graemlins/hahaha.gif[/img] [img]/ubbthreads/images/graemlins/smoker5.gif[/img]
That would look good on the desk at work.
Urine colored light and all.
Yea.
Good job!
Mike
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
