CandlePowerForums
CPF Only
User Name
Password
Register
Reply
Thread Tools Display Modes
  #1
Old 07-05-2004, 02:56 PM
ABTOMAT's Avatar
ABTOMAT ABTOMAT is offline
Default Looking for an oddball 12V bulb
I'm trying to help a friend find a strange bulb. It's for a mast-mounted foredeck light (points straight down) on a sailboat. 12V, unknown wattage, has a two-conductor bayonet-mount base (like a car tailight) and _also_ has an integrated reflector of about 2" in diameter. I believe the light assembly maker is Guest, probably from the '80s, and local boat shops have been unable to help.
Anyone know what this is? I don't have photos or anything more specific. The only deck light bulbs you can find in local shops are either ~1" reflector with a pin base, or ~4" reflector with spade connectors.
  #2
Old 07-05-2004, 08:48 PM
BB BB is offline
Default Re: Looking for an oddball 12V bulb
Try aviation supply stores/web sites... I believe I have seen similar reflectored bulbs in light aircraft.
-Bill
  #3
Old 07-06-2004, 01:27 PM
capnal capnal is offline
Hey John,
Try this site...
http://www.mcmaster.com
Type in "bulb" or "light bulb" in the search on the left. It will start kind of an interactive product search, where you sort of select or fill in what you know about the bulb you are looking for. That might point you in the right direction....
Hope that helps...
al
  #4
Old 07-08-2004, 06:45 AM
SilverFox's Avatar
SilverFox SilverFox is offline
Silver Moderator
Hello John,
Another thought is to try a marine supply store like West Marine.
I checked on line and it looks like they have a halogen spreader lamp, but the bulb is almost as much as the whole lamp assembly. Spreader Lamp
Good luck.
Tom
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
