CandlePowerForums
CPF Only
User Name
Password
Register
Surefire at Battery Junction
Reply
Thread Tools Display Modes
  #1
Old 07-06-2004, 08:26 PM
DLG's Avatar
DLG DLG is offline
Default Full spectrum lights
Comments about what are called full-spectrum lights?
Verilux / Ultralux are a 2 brand names. I'd guess there are others.
  #2
Old 07-06-2004, 10:22 PM
NewBie's Avatar
NewBie NewBie is offline
*Retired*
Default Re: Full spectrum lights
A regular incandescent is a *very* full spectrum light, emitting all wavelengths from ultraviolet on down through infra-red, with no gaps.
  #3
Old 07-06-2004, 10:39 PM
Joel Joel is offline
Dave:
It really depends on what you mean by comments. I've used both brands you mention both for room lighting and growing indoor plants. The T-8 UltraLux bulb with a good electronic ballast seems to last the longest and put out the most light. I personally prefer a warmer color temperature bulb for room lighting than the full spectrum bulbs, though. If you give me a better idea of what information you're looking for maybe I can help.
Joel
  #4
Old 07-07-2004, 04:32 AM
jtr1962 jtr1962 is offline
I've tried 4-foot T-12 GE Chroma 50's (CRI = 92) and 4-foot T-8 Paralite Maxum 5000s (CRI = 91). They both produce a much better light than either CFLs or even good triphosphor linear tubes. The GEs seem to bring out deep reds slightly better, and have a slightly lower color temperature overall than the Maxum 5000s. Other than that, however, I find they both produce a very nice light which is quite close to daylight. Eventually I'll convert all the lighting where I live to full-spectrum. I like the great color rendering as well as the color temp. Incandescent may be full-spectrum in a manner of speaking, but the color temp is too low. One thing I've noticed is that all fluorescents, even full-spectrum, are somewhat deficient in the deep red part of the spectrum. Perhaps using full-spectrum fluorescents combined with enough incandescent to fill that part of the spectrum might duplicate sunlight almost exactly although I have no intentions of trying that. Regardless of make, I recommend running all full-spectrum fluorescents on an electronic ballast.
I've heard Solux halogen lamps, which are color corrected for 3500K, 4100K, or 4700K (and have CRIs of 98 to 99), are indeed more "full-spectrum" than any full-spectrum fluorescents. In fact, when the 4700K version is overvolted by about 20% it comes extremely close to duplicating sunlight. However, heat, lifetime, and power consumption are three reasons why I would never consider using them except for small task lighting applications. For me full-spectrum fluorescents strike a good balance between power consumption, lamp life (the Maxum 5000s are rated for 34,000 hours!), and light quality. Perhaps in a few years we'll have LEDs that are as good as Solux lamps in duplicating sunlight but consume less power per lumen than even today's best full-spectrum fluorescents.
As an aside, I think all interior light should strive to duplicate sunlight as faithfully as possible. I've strongly voiced my disagreement in the past over the use by lighting designers of "warm" lighting to create moods. I feel creating moods is best done by selecting appropriate decor rather than choosing a type of light to which the human visual system is poorly adapted. Interestingly, I've never seen lighting designers go in the other direction to create mood. Assuming the ideal is around 5500K, then incandescent is about 2700K too warm but I've never seen lighting which is 2700K too cool (this would be around 8200K) used by lighting designers to create moods. I find it curious why strongly yellow-tinted light isn't considered objectionable while strongly blue-tinted light is (I find them both to be equally annoying, especially if visual clarity is a prime concern).
  #5
Old 07-07-2004, 06:21 AM
Lurker Lurker is offline
The full-spectrum linear fluorescent tubes I've tried have been good, but a little dimmer than the standard tubes I've replaced with them. I don't remember the brand I used. You might want to keep that in mind when making the change.
Also, I think absolute brightness and then color temperature are far more noticeable and important to me than wether a light is full-spectrum.
  #6
Old 07-07-2004, 11:13 AM
DLG's Avatar
DLG DLG is offline
Joel: Was interested in a new desk lamp and/or reading lamp, saw these and thought I'd ask people here about them.
And have been generally curious about home lighting. Been replacing high wattage filament type bulbs with lower wattage fluorescent.
I could be wrong, but when Mother Nature invented sunlight, she got it right imo. For example, when I read outside, its simply better. Be nice to emulate this inside when #1 the sun is elsewhere #2 rain......
  #7
Old 07-07-2004, 12:15 PM
Glenn Glenn is offline
The GE "Reveal" bulbs are a cheap way to get close to daylight type lighting.
They are MUCH better than the regular "soft white".
I have replaced almost every bulb (except flourescent) in my house with them.
Glenn
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
