Here is some information on locomotive lighting. Specifically, we have:
[ QUOTE ]
The FRA requires that the locomotive headlight (steady burn) used for road service have a luminous intensity of at least
200,000 candela. The headlight light focus angle in the horizontal plane in relation to the centerline of the locomotive must illuminate the track so that the locomotive engineer can identify moving or stationary objects or conditions at a distance of 244 m (800 ft) in front and ahead of the locomotive. The reduced luminous intensity (60,000 candela) and distance requirements (91.5 m [300 ft]) for railroad yard headlight operation is required to reduce excessive glare for railroad employees.
[/ QUOTE ]
and
[ QUOTE ]
Typical steady burn locomotive headlights are defined by wattage, style of headlamp, and voltage available. Locomotive headlight wattage was determined to range between
200 and 350 watts.
[/ QUOTE ]
Short answer-locomotive headlights are blindingly bright and visible for miles. I used to watch trains at Princeton Junction on the Northeast Corridor when I was in college. In the
daytime you would see the headlights of the AEM-7 locomotives about 2 or 3 minutes before they passed through. At the 125 mph speed they were traveling, this translates to a distance of four to six miles out. At night they probably could be seen from ten miles out or more if you had a straight line of sight.
