CandlePowerForums VISITOR MESSAGES
ARE NOT PRIVATE!!
Read more...
There has been an unwelcome increase in the number of threads and posts in this forum with no apparent purpose other than the advertisement of new products. As such, effective immediately, threads or posts that are considered by staff to be advertising, or solely for the purpose of providing links or pointers to new products, will stand to be closed, links removed, or deleted in their entirety, without warning or explanation.
For those wishing to introduce referenced new offers they've found, the MarketPlace is the board for discussion of commercial matters. There will most likely be a dedicated forum there for posting such threads.
Members who persist in posting or quoting such material are advised that their posting authority may be limited or withdrawn.
Go Back   CandlePowerForums > Flashlights > LED Flashlights
CPF Only
User Name
Password
Register
LedFlashlight8
Closed Thread
Thread Tools Display Modes
  #1
Old 08-04-2004, 10:33 PM
Anti_Candescent Anti_Candescent is offline
Default AAA Takes prolonged oil bath!
So, I had been looking for my AAA P for about three weeks, and I mean I turned my entire house over....when it was time to change the oil in the car. Something I use the arc for almost every time, and if I had only known how close it was!!!
It all came into focus when I was done, my oil basin was getting completely full (3 changes) so I got a jug and started pouring, when I heard it...I guess I had set the AAA somewhere near the radiator, and it took the plunge no less than 3 weeks ago. So, you know what the first thing I did was, give it a wipe and twist it on. No surprise, lit right up. However, the oil seems to have gotten into the led's plastic and its got a yellow/brown hue now. But I can't complain, its still bright and the o-ring let nothing inside. Well, at least I found it. I should get a job doing N.D.T. for ARC, where can I get an app?
  #2
Old 08-05-2004, 06:43 AM
Gransee Gransee is offline
Default Re: AAA Takes prolonged oil bath!
Thanks for the post AC, I think your's is the first for an extended oil bath.
Peter
  #3
Old 08-05-2004, 07:22 AM
d'mo's Avatar
d'mo d'mo is offline
Hey, does this mean the Arc needs an oil change every 30,000 hours?
Sorry, couldn't resist.
AC, was the oil hot? if so, that's one impressive torture test.
  #4
Old 08-05-2004, 10:27 AM
D'mo: The oil was very hot. Somewhat diluted with about 10 quarts already in the basin (the heat I mean) and yes, 30,000 hours or 3000 twists.
  #5
Old 08-05-2004, 04:01 PM
snakebite's Avatar
snakebite snakebite is offline
i did that a while back.
5 qts of hot mobil 1 and 5 of hot dexron atf
i drain the oil and atf hot as i come in from a 10 mile run on i-70.
didnt find it till later on that week.
the oil comes out approx 240f.
Closed Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
