CandlePowerForums
CPF Only
User Name
Password
Register
Wicked Lasers
Reply
Thread Tools Display Modes
  #1
Old 08-08-2004, 10:34 AM
flownosaj's Avatar
flownosaj flownosaj is offline
Default Under cabinet lighting
I was looking at all the home improvement stuff I can do for my new house and I began to think of installing about 5-7 feet worth of undercabinet lighting. I first looked at those halogen "cans" that can be installed--I'd prefer something thinner and less focused. I looked at the flicker-free thin flourescents --don't care for those either. Then I saw those rope-lights--gret idea and kinda what I'm looking for, but I don't care for those because if a bulb blows, I'll have to reinstall a whole new section.
So, does anybody have any suggestions for a thin, led based undercabinet light made primarily for accent lighting?
-Jason
  #2
Old 08-08-2004, 11:00 AM
NewBie's Avatar
NewBie NewBie is offline
*Retired*
Default Re: Under cabinet lighting
GELcore, the joint venture created by GE Lighting and Emcore, announced the availability of "Flexible LED Accent Lighting System" at WalMart stores. Based on GELcore's Tetra Lighting System, the patented new systems feature five advanced cool white LEDs. It is a bendable 18-inch product that uses adhesive for installation. Designed for mainstream commercial accent lighting applications, the system does not produce any heat or UV output. GELcore reportedly purchases the die used in this product from a variety of suppliers and then packages it for sale.
More info here: http://www.gelighting.com/na/pressro...ed_accent.html
Here is another solution like it:
http://www.sylvania.com/canada/directions/dir16.htm#one
  #3
Old 08-08-2004, 08:33 PM
flownosaj's Avatar
NewBie, you just made my day! That GELcore system seems just like what I was talking about. If I can just find a way to hook a few of them together I'll be set.
After I finish painting and playing mister-fix-it I'm going to make a trip to Walmart. Odd that they don't sell it at Home Depot or Lowes [img]/ubbthreads/images/graemlins/icon3.gif[/img]
  #4
Old 08-24-2004, 12:47 AM
McShawn McShawn is offline
BTW, wal-mart sells those GE under cabinet led lights.
  #5
Old 08-24-2004, 07:22 AM
James S's Avatar
James S James S is offline
*Flashaholic*
I've got several rope lights that I use for over cabinet night lighting of the kitchen. (fancy home automation, dims up when you walk into the room after dark, I am so cool [img]/ubbthreads/images/graemlins/grin.gif[/img]) I purchased them for undercabinet lighting a year or so ago, but they are not bright enough for any kind of task lighting at all. And they are very inefficient. The strands I've got use 80 watts when they are not dimmed and are only good as a nightlight. (although layed across the top of the kitchen cabinets they make a very nice nightlight, but not one that you would want to run all night as they sink 80 watts!)
So all in all I'm not impressed with rope lights except for slightly more robust christmas lighting applications or cove accent lighting or something.
I've been wanting to experiment with luxeons as undercabinet lighting. I would also like to do some shelf lighting in the living room with them. Unfortunately I want enough of them to actually make task lighting useful and so they haven't been in the budget yet [img]/ubbthreads/images/graemlins/wink.gif[/img]
But I do have to go to walmart today to return a dead CF bulb that I bought there the other day and so I'll keep an eye out for this stuff.
  #6
Old 08-24-2004, 07:43 AM
NewBie's Avatar
*Retired*
I saw them first at Walmart, then ran into the info, trying to find out their specs. At my store they were in the lamp section and not the light bulb area.
  #7
Old 09-05-2004, 03:30 AM
flownosaj's Avatar
I checked both local Walmarts the other day--none of those led based units around at all... [img]/ubbthreads/images/graemlins/frown.gif[/img]
  #8
Old 09-05-2004, 08:02 AM
James S's Avatar
*Flashaholic*
I spent quite a bit of time going through the lamp and lighting sections the other day and found nothing here either [img]/ubbthreads/images/graemlins/frown.gif[/img] Guess I'll have to build my own afterall! Just a little expensive when you are buying several dozen luxeons...
  #9
Old 09-08-2004, 08:57 PM
stump stump is offline
Walmart no longer carries it. Found a GE website claiming that Home Depot carries it. The lighting dept person at my local HD ended up calling GE and learned that this item was pulled from sale to the public and, subsequently, discontinued.
  #10
Old 09-12-2004, 12:46 AM
flownosaj's Avatar
figures [img]/ubbthreads/images/graemlins/icon6.gif[/img]
  #11
Old 09-12-2004, 10:21 AM
evan9162 evan9162 is offline
Well, you can still grab a bunch of 1W luxeons and build one yourself. I think Future sells 1W luxeons for around $6-$7 each. You can use my cabinet lighting as an example of how to set them up: http://www.candlepowerforums.com/ubb...?Number=654718
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
