CandlePowerForums
CPF Only
User Name
Password
Register
Reply
Thread Tools Display Modes
  #1
Old 09-05-2004, 07:46 PM
jtr1962 jtr1962 is offline
Default Plastic fluorescent tubes?
After reading the thread about the LED worklight I was wondering if there is any technical reason why we can't make fluorescent tubes out of plastic instead of glass. There are UV resistant plastics so that's not the problem. Cost likely isn't the problem as plastics would be easier to mold and probably cheaper. Heat likely wouldn't be a problem either-some plastics like Teflon are usable at 450°F, well above what even an enclosed tube reaches.
Unbreakable plastic tubes would have lots of advantages, especially in industrial environments or around children. I'm wondering why they haven't been made.
  #2
Old 09-05-2004, 08:59 PM
brickbat brickbat is offline
Default Re: Plastic fluorescent tubes?
I don't know of any plastics that provide a true hermetic seal. That is, on a molecular level, air will diffuse into the lamp over time.
  #3
Old 09-05-2004, 10:01 PM
The_LED_Museum's Avatar
The_LED_Museum The_LED_Museum is offline
*Flashaholic*
I was just going to say that. No plastics that I know of could maintain very low pressures (near-vaccume) in a tube or bulb without a very slow influx of atmospheric gases.
  #4
Old 09-06-2004, 12:21 AM
evanlocc evanlocc is offline
Well, i would say yes there are plastic tubes light but not in fluorescent manner. Use of a different light source (eg.LED) base could be or already in production.
  #5
Old 09-07-2004, 12:38 PM
Not being hermetically sealable certainly give a reason as to why nobody has made plastic fluorescent tubes. Yes, you can make plastic LED-based light tubes, and in a manner of speaking these are "fluorescent" because white LEDs are fluorescent light sources, but that's not quite what I had in mind. I meant the usual mercury-vapor based tubes.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
