CandlePowerForums
CPF Only
User Name
Password
Register
BugOutGearUSA
Reply
Thread Tools Display Modes
  #1
Old 09-28-2004, 07:50 AM
Phaserburn's Avatar
Phaserburn Phaserburn is offline
*Flashaholic*
Default How many lumens from a candle?
of the taper variety; the ultimate incandescent! Just curious how a candle stacks up to various flashlight outputs.
  #2
Old 09-28-2004, 08:32 AM
Doug S Doug S is offline
Default Re: How many lumens from a candle?
[ QUOTE ]
[/ QUOTE ]
It will of course vary with wick length, wax type, and probably other factors but it likely will fall in the 5 to 15 lumen range. The bureau of standards folks used to have a description of the construction of the "standard candle" from which intensity measurements were defined before they went to the definition using the black body cavity radiation involving a temperature defined by the melting temperature of platinum. If you search around you may find a description of that "standard candle".
  #3
Old 09-28-2004, 10:05 AM
jtr1962 jtr1962 is offline
A standard candle is defined as giving off one candlepower over 4*pi steradians. Even you do the math, this comes to 12.56636 lumens.
  #4
Old 09-28-2004, 10:37 AM
[ QUOTE ]
[/ QUOTE ]
Actually not true. The physical candle used for the standard for candlepower [a unit of intensity] was not an isotropic source. The candlepower was defined along a horizontal axis relative to the wick. jtr1962 is thinking of the unit Mean Spherical Candle Power [MSCP] another old unit that was in fact 4*pi lumens. The physical candle from which the intensity unit candlepower is derived would have emitted somewhat less than 4*pi lumens.
  #5
Old 09-28-2004, 10:50 AM
Actually, MSCP was what I meant. I wasn't referring to a physical candle in my post, just to the derivation of the unit candlepower. I know they're not uniform in their illumination.
  #6
Old 09-28-2004, 11:06 AM
BTW, if you want to build one of these candle standards at home, start by harpooning a Sperm Whale. The candle definition includes "constructed so as to burn 7.8 grams per hour of spermaceti..."
  #7
Old 10-03-2004, 07:46 PM
Polar_Hops Polar_Hops is online now
What about the parrifin wax and lox they are experimenting with for rocket fuels? how many candlepower does that put out i wonder. =(
  #8
Old 10-04-2004, 03:09 PM
capnal capnal is offline
Mark's Standard Handbook for Mechanical Engineers (10th Edition) page 12-99 defines "candela, cd (formerly candle) is the unit of luminous intensity of a light source. One candela is defined as the luminous intensity in a given direction, of a source that emits monochromatic radiation of a frequency 540 x 10(12)HZ (approx. 55 nm) and of which the radiant intensity in that direction 1/683 W per steridan (W/sr)." It goes on to show in table 12.5.1 that a single candle flame is rated at 6.45 cd/in2.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
