CandlePowerForums
CPF Only
User Name
Password
Register
4Sevens
Reply
Thread Tools Display Modes
  #1
Old 09-29-2004, 05:19 PM
kayos kayos is offline
Unenlightened
Default LED ring light for camera
I would like to shoot short close up video clips and thought that I may be able to make a LED ring light runs on batteries and contans around 40 LEDs. Problem is that I am ignorant of how to design a LED circuit. Are there any curcits that I can buy or easily build that would allow me to build my light?
  #2
Old 09-29-2004, 08:34 PM
IlluminatingBikr IlluminatingBikr is offline
Default Re: LED ring light for camera
Kayos,
Welcome to CPF!
I was at the gum specialist's office yesterday, and got a picture of my gums taken. The picture was for the insurance company, because we are trying to get them to cover all/part of the cost of a gum graph I will be getting in January.
They had a Canon digital camera which they used to take the picture. I believe it was the A75, but didn't get a good look at it. Well anyways, they held it up close to the area where I need the graph, and took a picture. They had a ring around the lense of the camera, with probably about a dozen 5mm LEDs around it, that were on the whole time. I'm pretty sure they ran off of the camera's battery, rather than some external source.
I have a feeling that if a normal doctor's office has one of these, that they are probably being sold by a company. Perhaps you could try and aquire one, rather than having to make it.
Just thought I would share my personal experience with you.
  #3
Old 09-30-2004, 02:23 AM
Negeltu's Avatar
Negeltu Negeltu is offline
I made my own 5mm led macro light ring. I used some velcro strips. Unfortunately, I didn't get good results. It just wasn't bright enough for my purposes...so I took it apart and used the leds for something else.
  #4
Old 09-30-2004, 02:56 AM
reefphilic's Avatar
reefphilic reefphilic is offline
I was searching for LED ring light a few months ago.
Most places want a few hundred dollars for a bunch of 5mm LEDs and a pcb assembled.
With the Luxeon LED, you might be able to built one with say 3LEDs. Save you the trouble of the wiring up all the 5mm LEDs.
  #5
Old 09-30-2004, 08:41 AM
markus_i markus_i is offline
If you want to go for serious illumination, you might consider the Luxeon rings. But prepare for serious $.
Bye
Markus
  #6
Old 10-02-2004, 03:17 PM
Negeltu's Avatar
My next try is going to be with luxeons. The 5mm just didn't put out enough light for my camera.
  #7
Old 10-02-2004, 04:48 PM
PhotonWrangler's Avatar
PhotonWrangler PhotonWrangler is offline
*Flashaholic*
Luxeon-based rings...
  #8
Old 10-02-2004, 10:02 PM
greenLED's Avatar
greenLED greenLED is offline
If you're going to build a LED ring light for your camera, make sure you use a diffuser for it. Otherwise, you will get uneven lighting on whatever you're shoothing. This might be worse if you'll me doing macro photography.
The LS-rings might be too bright.
  #9
Old 10-03-2004, 04:20 PM
LED-FX LED-FX is offline
Leave long leads on the LEDs the you can focus them on the point of interest.
Get some perf board , radio shack, some LEDs possibly banner Ad here, presume white use this to find your resitor value, if your using 12V for instance wire 3 LEDs in series then use a 150 Ohm resistor:
http://linear1.org/ckts/led.php
Bit of hacksawing or use couple of hole saws to make the ring.
Solder LEDS to board , illuminate object, post some pics back ;-)
Adam
  #10
Old 10-03-2004, 07:41 PM
radellaf's Avatar
radellaf radellaf is offline
Digi-Slave makes one with 24 5mm LEDs, $150, and inexplicably powered by a 9V battery.
http://www.bhphotovideo.com/bnh/cont...937&is=REG
  #11
Old 10-05-2004, 10:33 AM
Unenlightened
Thanks for all the replys. I contacted Digi-Slave and was told that they will be coming out with a more powerful LED ring flash in a month or so. I think I will wait for that rather than going through the hassle of wiring something up myself.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
