CandlePowerForums
CPF Only
User Name
Password
Register
Botach Tactical
Reply
Thread Tools Display Modes
  #1
Old 10-01-2004, 09:54 AM
Kirk Kirk is offline
Default T4 Compact Fluorescent Question
We have ceiling fixtures at work that are supposed to take two 7-watt or 9-watt fluorescent bulbs. We've been replacing the burned out bulbs with 5-watters to save energy. The 5-watt bulbs are supposed to last 10,000 hours. They've been lasting maybe 2500 hours (10 hours a day for 8 months). Are they blowing because they are being over-driven or are fluorescents different and as long as they fit in a fixture you are good to go? Any info would be greatly appreciated.
Regards,
Kirk
  #2
Old 10-01-2004, 11:05 AM
Chris M.'s Avatar
Chris M. Chris M. is offline
Default Re: T4 Compact Fluorescent Question
It`s more than likely they are burning out from being overdriven. And I doubt the fixture is taking less power in that configuration either, not significantly at least. Some fluorescent tube ballasts (usually built in to the fixture) are designed to drive a wide (ish) range of wattages, but others are very strict on what tube they must be used with. I`d go back to the required 7-watt tubes - not only should they then last the specified lifetime but also the ballast stands less chance of being damaged or havintg *its* life reduced too.
[img]/ubbthreads/images/graemlins/grin.gif[/img]
  #3
Old 10-01-2004, 04:32 PM
Chris M.,
Thanks for the info. I guess I'll start buying the 7-watt bulbs and replace the 5-watters as they go bad.
Regards,
Kirk
  #4
Old 10-02-2004, 05:53 PM
Brock's Avatar
Brock Brock is offline
Administratior
As Chris said most likely they will actually take the same wattage running 7w or 9w in there. They did that all over campus here and after about 18 months replaced all the ballasts.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
