Differences between high CRI fluorescents
I've been using 5000K, 91 CRI fluorescents for about the last year and I'm generally very pleased with them. Lately, I've been doing some research and comparing spectrums. It seems that some are superior to others, at least on paper. For example, the Philips TL-D 90 Graphica Pro T-8 has a CRI of 98, a CCT of 5300K, and an efficiency of 64 lm/W. This compares to the tubes I'm using which have an efficiency of 92 lm/W. On paper the CRI 91 or 93 tubes seem to be much more spiky than the CRI 98 tubes. The more common commodity CRI 85 or 86 tubes have even more discontinuous spectrums.
Has anyone tried some of the very high CRI fluorescents? Is the difference even noticeable compared to CRI 91 tubes for most applications? While the higher CRI is an obvious benefit, the drawbacks include a much lower efficiency and a much higher price (frequently over $15 as opposed to the $7 I paid for my tubes). Is it even worthwhile to consider switching at some point in the future? Please note that my main use here is general lighting. I'm using or plan to eventually use some type of high CRI tubes in all the rooms where I live. I'm curious as to whether or not I should standardize on CRI 98 tubes or just stick with what I have. Please note that headaches or other physiological effects are not a problem here. In fact, I'm fine even with commodity grade CRI 86 tubes (although anything much less than that causes problems). I'm more concerned with the general color and appearance of things.
