CandlePowerForums
CPF Only
User Name
Password
Register
Reply
Thread Tools Display Modes
  #1
Old 10-31-2004, 01:03 PM
alternety alternety is offline
Unenlightened
Default HIR Automotive Bulbs
Anyone know of a reasonably priced source of 9011 and 9012 HIR headlight bulbs.
  #2
Old 10-31-2004, 01:47 PM
liteglow liteglow is offline
Default Re: HIR Automotive Bulbs
read more aboyt HIR at: www.hidplanet.com
i dont know so mutch abotut HIR, but i have notice that it`s bad for the bulbs (they get broken faster)
try HID [img]/ubbthreads/images/graemlins/smile.gif[/img] that way u get amazingly light ... [img]/ubbthreads/images/graemlins/smile.gif[/img]
  #3
Old 10-31-2004, 04:14 PM
iddibhai iddibhai is offline
www.danielsternlighting.com, he has 9011 and 9012 for about 35-40 each. they will cost you three digits at your Dodge dealer (and you'd be lucky to find them at a Toyota dealer). if you live in farm country, then stores that carry the larger John Deere equipment will also have it, or GE retailers as well. Might want to call them and ask if a local source can be found, and if they are less pricey than Dan.
The rated life is:
9011 (high beam) 2500lms@13.2vDC (max drive volts), >235hrs to 50% fail rate @ 14vDC
9012 (dipped beam) 1875lms@13.2vDC (ditto) ~1000hrs to 50% fail rate @ 14vDC
Luminous values are +/- 15% variance.
They are *QUARTZ* glass, and therefore sensitive to touch. DO NOT touch the glass, if you do, wipe it off w/ alcohol and dry before installing. Finger oils will cause very quick failure at the temps these run. Also, GE is the *ONLY* maker of these lamps, if they NOT branded GE, then it is not legit and you are on your own. And GE only makes then in 9011/2 size.
Specs gotten from GE's website
http://www.gelighting.com/na/downloa...techsheet1.pdf
as for HID, unless the car come with an option from the factory, retrofits *may* be illegal. see
http://www.nhtsa.dot.gov/nhtsa/annou...e=pr43-04.html
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
