CandlePowerForums
CPF Only
User Name
Password
Register
BugOutGearUSA
Reply
Thread Tools Display Modes
  #1
Old 11-13-2004, 01:58 PM
BatteryCharger's Avatar
BatteryCharger BatteryCharger is offline
Default What type of light gives the most lumens/watt?
Just wondering, which type of light gives the most lumens per watt? HID? Flourescent? LED?
  #2
Old 11-13-2004, 02:44 PM
Mark2's Avatar
Mark2 Mark2 is offline
Default Re: What type of light gives the most lumens/watt?
IIRC it's fluorescent, HID, LED, incandescent.
  #3
Old 11-13-2004, 03:21 PM
yuandrew's Avatar
yuandrew yuandrew is offline
Low Pressure Sodium
and
Microwave Sulfur (I don't think they're still researching this though)
  #4
Old 11-13-2004, 03:23 PM
jtr1962 jtr1962 is offline
Here are some of the typical ranges that I remember for each type:
low-pressure sodium: 125 to 200 lm/W (typical 150 lm/W)
high-pressure sodium: 80 to 125 lm/W
HID: 65 to 110 lm/W
T-12 fluorescent: up to 90 lm/W (typical 60 to 80 lm/W)
T-8 fluorescent: up to 100 lm/W (typical 85 to 92 lm/W)
T-5 fluorescent: up to 104 lm/W (typical 95 to 100 lm/W)
CFL: 60 to 70 lm/W typical (includes ballast losses)
mercury vapor: 55 lm/W
xenon arc: 30 lm/W
incandescent: 15 lm/W typical (as low as 1 lm/W for small lamps, up to 40 lm/W for short-life bulbs)
white LED: 15 to 30 lm/W typical, up to 60 lm/W next year (current record 74 lm/W)
colored LED: 5 to 55 lm/W depending upon color (current record is 102 lm/W @ 618 nm)
For large amounts of white light HID in the larger sizes (400W to 1000W) is currently the most efficient. For residential and office use T-5 fluorescent is the most efficient option although T-8 comes fairly close. For small uses LED is generally more efficient than incandescent. For colored light LED is the best choice regardless of size.
  #5
Old 11-13-2004, 03:31 PM
mattheww50's Avatar
mattheww50 mattheww50 is offline
Unless you happen to want yellow light, in which ase a Low Pressure Sodium (SOX) lamp wins hands down. Even a small 18 watt SOX is good for 100 lumens/watt.
  #6
Old 11-14-2004, 01:03 PM
Zelandeth's Avatar
Zelandeth Zelandeth is offline
Best answer to this I think is the chart at the bottom of this page at Lamptech.
http://www.lamptech.co.uk/Documents/...troduction.htm
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
