CandlePowerForums
CPF Only
User Name
Password
Register
Advertising on CPF!
Reply
Thread Tools Display Modes
  #1
Old 12-26-2004, 01:52 PM
Stream Stream is offline
Default Energizer X focus (AA)
Do any of you own one of these? If so, what's your opinion of it?
  #2
Old 12-27-2004, 05:11 AM
BayMoe BayMoe is offline
Default Re: Energizer X focus (AA)
From what I can see from the image, it looks nicely built.
There's even a single AA one as well.
  #3
Old 12-27-2004, 09:33 AM
Flying Turtle's Avatar
Flying Turtle Flying Turtle is offline
I think those may be old models. I got a few of the single AAA models a few years ago at Big Lots. They are pretty nice for an incandescent, but for similar size and shape the Dorcy AAA beats them.
Geoff
  #4
Old 01-02-2005, 04:31 PM
Thanx for the replies [img]/ubbthreads/images/graemlins/smile.gif[/img]. I actually own the 2 AA X-focus (the one in the top picture). I bought it very recently for about 16 dollars. It shines a lot brighter than my factory-standard 2 AA MiniMag -- which costs about 33 dollars in stores over here in Norway. I was just curious to see if there were any others who might have owned it for a longer time and what their opinion of it might be. It's made of plastic but doesn't feel cheap or poorly built. It has a very bright krypton incan. bulb, focusable beam and it has a convenient tailcap switch. I can't find much info about this incandescent anywhere on the net, except for a picture and a short description at energizer-eu.com but not on the US Energizer website. So I was starting to think that this was maybe a European model only.
Generally speaking, though, I think that Energizer makes pretty decent flashlights. They may not be as advanced as the regulated and more expensive SureFires or Streamlights, but they give you good value for your money. I own about six Energizer flashlights, I also have a weird-looking aircraft aluminum double barrel 4+AAA one with a Xenon lamp which is very bright.
  #5
Old 01-03-2005, 03:58 PM
PJ's Avatar
PJ PJ is offline
I have had the 2 AA flashlight here at work for about 2 years now. It looks to be the same configuration in the picture, only it is a dark red color. The contacts in the switch need to be reformed every so often or it won't shut off. Other than that it is a decent light. I had 2 Mag AA lights stolen, but this one seems to stick around.
  #6
Old 02-05-2005, 12:52 PM
Hey I found the specs for the X215 at energizer.com:
http://data.energizer.com/PDFs/X215.pdf
It says the light output is 7 lumens (MiniMag is 5.3). So I was right in that it is brighter than the MM. Only thing I don't like is the short lamp life.
PJ, how many bulbs have you replaced during the 2 years you've used it? Also, how do you reform the contacts in the switch, is it the little copper plate on the inside of the battery chamber that has to be moved in order to allow the tailcap switch to break contact? BTW, does yours have the tailcap switch that twists on and off?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
