Re: Maxpedition compatablity
Hiya - My L4 and Leatheman Wave fit perfectly in a Maxpedition double sheath, and there's a fair bit of extra room around the Wave, so the slightly larger Gerber should fit fine. The double and single sheath have the same attachment mechanism, so the double is a little bit 'floppier' due to added width - you might consider if two singles would be a better fit for your needs - a bit less compact, a bit more flexible.
